Question about Whirlpool Duet GHW9150P Front Load Washer
How far should the drain hose be put into the waste pipe?I was painting behind the washer. I did not notice that I may have pulled out the drain hose, but during a wash cycle water started to spray everywhere. I immediately turned off the machine and then noticed the drain hose was NOT in the waste pipe. How far should the drain hose be pushed down the waste pipe? Does it matter? I don't want to have all the water again.
  • 4,059 Answers
Most have a hooked shape which can't be inserted too far. If yours is the flexible type it should be from 4 to 6 inches. If it's too far it can siphon the water out of the tub during the wash.
Posted on Sep 10, 2009
  • 11,896 Answers
5-6"
Water dripping under the rim, into the tub
Sounds to me like you have a siphoning problem You probably have your drain hose too far down in the drain pipe. When this happens the drain hose goes into the trap of the drain pipe. It then pull the water from the drain pipe back into your washer cause it cant break the vacuum. Pull your drain hose up so that on a little bit of the pipe is sticking down the drain pipe
Aug 25, 2012 | Maytag Washing Machines
Tip
Clothes Washer won't stop filling with water?
If your washer continues to fill with water and does not overflow onto the floor where is that water going???
The water is siphoning from the machine as fast or faster than it it filling. This is caused by one of two situations both have to do with how the drain hose is routed.
The most common is that the drain is too low. The drain for your washer must first rise above the height of the tub or highest water level before it enters the house drain or drainage sink. This height is typically a minimum of 30". So if you are trying to drain the washer into a low pipe, a short sink or down hill you must first raise the hose or piping to that 30" before it heads down hill.
Second cause is where the drain hose is pushed too far into the house drain. A typical drain pipe in the home has a water trap at the bottom. If you put your washer drain hose down into the pipe too far and contact the water in that trap you will also siphon the water from the machine. The drain hose should hook and be secured to the drain pipe and go inside about 6", that's all that is needed.
Other washer issues:
SUDS http://www.fixya.com/support/r4621260-many_suds_in_clothes_washer
ODOR http://www.fixya.com/support/r4621314-odor_from_towels_or_clothes_washer
Control Locked http://www.fixya.com/support/r4624473-control_locked
on Apr 23, 2010 | Washing Machines
Drain stand pipe Washer fills and drains at same time. Manual says the drain stand pipe must be greater than 30 degrees. I would like to have a description of the drain stand pipe and it's...
30 degrees or 30 inches. The drain stand pipe is separate from the washer and usual plumbed in behind the washer. You bring the the drain hose up to the top of the standpipe and then push the end (forming an upside down U at this point) into the top of the open 2-3" diameter PVC pipe and secure it so that it won't back out (but do not seal the opening). Nylon ties or hose clamps will work. The height requirement is so that the bottom of the hose in the standpipe is above the water level in the washer - this avoids the drain siphoning the water out of the washer. Check how far into the standpipe the drain hose has been pushed. If it is below the level of the water in the washer, back it out. Check the height of the standpipe. Many washer manuals recommend a 34" standpipe (max height of 48") based on the drain hose length on the down side of the U. Also make sure no one sealed the top of the standpipe against air entering the pipe. (Often this is done because of a back up in the drain, pull the drain hose out and get the pipe cleaned out and then put the hose in to the proper distance. Then leave the top of the standpipe open.)
For a picture of the standpipe, see http://www.appliance411.com/faq/washer-drain.shtml .
There is a parts diagram for your washer itself is here: http://www.searspartsdirect.com/partsdirect/part-model/GE-Parts/Washer-Parts/Model-GLWN5050M0WS/0432/0153200?searchedModel=glwn5050&blt= .
I hope this helps.
Feb 28, 2011 | Washing Machines
The wash keeps running water, never fills up
Your drain hose is to far down in the stand pipe or your stand pipe is to low, your stand pipe should be roughly the same height as the top of your washer if it is pull your hose out of the drain pipe it has probably just went down to far, it only need to be about 8 inches in the pipe, it is siphoning the water out, that is what your problem is.
Jan 08, 2011 | Whirlpool LSR5132PQ Top Load Washer
I have a kenmore model 110 top loading washing machine that keeps draining and wont fill up but sometimes it does and sometimes it does not. Help!
Your drain hose is too far down into the pipe behind the washer. What's happening is your drain hose is actually siphoning water from th washer the same time its trying to fill up. Pull the drain hose up from the drain pipe and secure it so its doesnt fly out when the washer is draining. Check too see if the problem goes away. If not pull the drain hose out more repeat steps.
Feb 17, 2010 | Washing Machines
LSR8233JQ0Washer won't fill
The water is syphoning out the drain hose.
Many times when the stand pipe is backing up someone will seal the washer drain hose to the pipe to avoid overflow of the stand pipe.
This causes the water to syphon from the washer.
Or the opening for the stand pipe is just big enough to put the drain hose in and is to tight causing the syphon.
Putting the drain hose to far down the pipe can cause a syphon also.
Jan 20, 2010 | Washing Machines
Electrolux dishwasher won't drain. Not a clog in the outlet hose or drain pipe.
The drain hose on a washing machinemag-glass_10x10.gif connects the drain pump to a stand pipe, a U-pipe under the sink, or another place for draining dirty water into the sewer. If your washer won't drain properly, the problem is sometimes an object blocking the drain hose, like a pair of underpants, a child's sock, or pieces of something that broke up in the washer.
  1. Unplug the washer and put the plug on top of the machine to keep it out of any spilled water.
  2. Step 2 Take any wet clothes out of the washer and bail the water out of the drum with the bucket. The washer may be too heavy to move if it's full of water and wet clothing.
  3. Step 3 Pull the washer out from the wall enough for you to get behind it.
  4. Step 4 Remove the plate from the back of the washer by taking out all the screws. Different brands and models of washers vary in how many screws hold on the back plate, and not all models require removing the plate to get to the pump where the hose is attached.
  5. Step 5 Locate the drain hose. Of the three hoses coming out of the back of the washer, the drain hose is the largest in diameter and is attached to a drain pipe instead of a faucet.
  6. Step 6 Check the drain hose for kinks and bends. These are often the cause of a blocked or slow-running drain hose.
  7. Step 7 Remove the drain hose from the washer by detaching it from the drain pump. You will need a screwdriver or a slide-lock wrench to open the clasp that holds the hose to the pump, depending on what type of clasp it is.
  8. Step 8 Keep the bucket nearby to catch any water that comes out of the drain pump when you remove the hose.
  9. Step 9 Remove the other end of the house from the pipe it drains into.
  10. Step 10 Bend the clothes hanger open so you can use it to poke inside the hose. Push or pull out the material that's causing the blockage.
  11. Step 11 Replace the hose and run the washer to check if it's clear.
Nov 13, 2009 | Electrolux 24 in. EDW5505EPS Stainless...
Washer is not spinning fast enough clothes are wet at one point i think i put in too much soap and it said draining problem
If this is a HE front load washer. MAke sure your drain hose is not shuved too far down the drain pipe. Water will syphen back into the washer and clothes will be wet. Drain hose should be in drain pipe 8 inches. See you ownwers manual for drain hose recomemdations. Reason why it says drasining problem is because maybe water is sysphening back into washer and pump is taking long to drain and operating too long and washer senses it. So check your drain hose and make sure its not to far down the drain pipe..re adjust if it is and wash your clothes and see if problem persists...hope this helps
Jul 29, 2009 | Dryers
I have LG WM1832CW washing machine. It is having problem now. The water comes out from the drain bump filter right away during the water filling cycle. I also tried just put the water into int drum without...
your drain hose is in the drain tube to far, pull out the hose and only put it in about four inches into the pipe. when you drain line is in to far the hose get a syhpon effect from your sewer.
Jan 15, 2009 | LG WM-1832C Front Load Washer
Whirlpool Washer - Imperial Series Quiet Wash 2
your washers drain hose is too far down the drain pipe which is causing a siphoning action pull the washers drain hose out pipe some you should be able to hear water dropping into the pipe the reason it only happens in the rinse cycle is because the water from wash is being drained and before the water vacuum is broken the rinse water comes in causing it to keep draining
Dec 30, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Duet GHW9150P Front Load Washer Logo
293 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
