Question about IOGear Computers & Internet
Mac on ethernet cable to router doesn't print, but wireless XP does
Printer T20E saya ngeblink apa yang harus aya lakukan...
Posted on Sep 12, 2009
Tip
I think there are 6 ways (at least?) to connect this printer: (1) Direct to Mac...
(1) Direct to Mac (or PC) via USB Cable (2) Direct to Mac (or PC) via Ethernet Crossover Cable(3) Ethernet to router/switch, with Mac/PC also via Ethernet to router/switch(4) Ethernet to router/switch, with Mac/PC via WiFi (802.11 wireless)(5) WiFi to router, with Mac/PC via Ethernet to router/switch(6) WiFi to router, with Mac/PC also via WiFi.
As (1) should be simplest, tried this first. First document would print instantly and completely, next doc would hang in queue with unexpected msg, "Printer is offline." Only way to print 2nd doc was to power cycle (off-on) the printer. This problem occurred whether 2nd doc was sent to printer before or after 1st doc had printed. Tried 2nd USB cable, tried new driver, tried reinstalling printer; same problem. Spoke to both Samsung and Apple support, including both on a conference call; never got this to work and never clarified if problem was in printer hardware/software, driver, or something else. Both companies now showing this issue as unresolved.
Nothwithstanding USB problem, did succeed in modes (4) and (6), although custom wireless config needed since my network does not broadcast SSID and requires an encryption password. Procedure required connecting first via Ethernet, obtaining Configuration Report by holding down orange button for 5 seconds, then using browser to connect to the printer's IP address. Also required different driver for wireless config (as opposed to USB).
Bottom line: What seemed simple - USB direct connect - proved unworkable, but wired and wireless network config works fine.
on Apr 25, 2010 | Office Equipment & Supplies
Tip
Samsung ML-2525W printer & Mac OS X 10.6
(1) Direct to Mac (or PC) via USB Cable (2) Direct to Mac (or PC) via Ethernet Crossover Cable (3) Ethernet to router/switch, with Mac/PC also via Ethernet to router/switch (4) Ethernet to router/switch, with Mac/PC via WiFi (802.11 wireless) (5) WiFi to router, with Mac/PC via Ethernet to router/switch (6) WiFi to router, with Mac/PC also via WiFi
Nothwithstanding USB problem, did succeed in modes (4) and (6), although custom wireless config needed since my network does not broadcast SSID and requires an encryption password. Also required different driver for wireless config (as opposed to USB).
I have the Zyxel ngg-416n wireless router. when i connect it to my cable system and the the router to my mac, the computer doesn't 'see' the network connection. so i can't load the...
Not really familiar with MAC but make sure you're plugging the ethernet cable into a lan port on the router and not the WAN/uplink port.
Also check to see if your lan connection isn't disabled on the computer.
For starters
Aug 27, 2011 | Zyxel Communications NBG416N 11N 150N Wlan...
Just replaced Netgear WebSafe router with Linksys WRT400N. Now, can't "see" printer in network nor can access it to change settings (or print). Have tried with ethernet cable straight to router and through...
Reset printer to factory settings according to manual. Plugged in ethernet cable directly to router. Ran BRAdmin which recognized printer and saw that IP address had been automatically set within new router range. Changed setting to STATIC. Deleted old printer definition from printer list and added updated definition using Printer Setup Utility. Printed test page from BRAdmin. Also printed file from Documents folder wirelessly. Changed printer settings in another laptop & was able to print wirelessly from there as well.
Jan 07, 2010 | Brother HL-2070N Laser Printer
I am trying to connect my macbook pro 4.1 to a wireless printer. That printer works fine - when on wireless with my wifes windows machine and it works fine if i connect my mac to the printer- just not n a...
IN the case of the Mac what I have had to do in the past was shut down the other laptops and computers, delete the printer program from the Mac and start over. During the setup of the printer make sure nothing is connected to the printer. Only connect what you are instructed to at the appropriate time. It will eventually ask you how you are going to connect to the printer from that particular printer, answer ethernet cable and attach the ethernat cable to the printer from your router, make sure your laptop is connected to the router with an ethernet cable. Always set your computer up to the printer vis a hard line, then onve it is done you can swap over to a wireless setup. Once the setup is complete and a test print is accomplished bia ethernet cable, then disconnect the cable from the laptop to the router. Once you are connected to the network wirelessly, attempt another test page, you have already set the printer up at this point to be your default printing device so the laptop will find the printer on the network and initiate it. You may have to watch close for a pop up window asking to allow the connection or access to the program. Maybe think about dropping the firewall temporarily until the connection is secure.
Nov 29, 2009 | Computers & Internet
My XP computer is a wired connection to the modem. The XP computer is supposed to be a wireless connection to the modem. That said, why is it that when setting up the router, I am instructed to plug in...
It's not really required to plug in your PC via ethernet cable to the wireless router in order for you to configure it. It is however, recommended to connect it via ethernet cable initially so that when you changethe wireless settings on the router you wont get disconnected. Please note, that when you connect your PC wirelessly all wireless settings should match (Wireless Name/SSID, Wireless Security (WEP/WPA keys or passphrase), Wireless MAC Filtering).
Jul 14, 2009 | Linksys WRT54G2 Wireless Router
Can not connect to Internet wireless or through router to Ethern.
call service provider (isp) to insure they have routers mac address. I cannot stress this enough
Mar 01, 2009 | D-Link DIR-625 (790069292637) Wireless...
Wrong Kind of Ethernet Cable?
If you can still access the web based configuration on your linksys router (by going to 192.168.1.1 in your web browser) that means nothing is wrong with the cable/connections. However the ISP is not letting your router get access to the router since it doesn't have the same MAC address as your computer's ethernet card/port.
To change your routers MAC address to the sameone on your computer (So you ISP thinks its still the computer connected), you have to first go to start>run>type in cmd and when command prompt opens, type in "ipconfig -all", which lists your IP addresses, etc. Make sure you add the -all (With a space after ipconfig) or else you can get your computers MAC address. The Physical Address is your MAC address. Now once you obtained the MAC, go to your router configuration, and login. Then look for where you can set or clone the MAC address of the router. The default mac address could be on the bottom of the router, if so check for it and just look for that address in your web configuration, then change it to your computers MAC address.
Hope this will fix it!
Feb 28, 2009 | Linksys Wireless-G WRT54G Router
Can't get internet access!!
The proper procedure in any router based network is to get the router on the network first. Plug it into the online cable modem and boot it up. Let it sit for a minute and then boot up wired computers one at a time. Use one of the wired PC's to get into the routers GUI (eg. 192.168.1.1) and see if WiFi is turned on and the permissions or wireless access is not being blocked by any security settings like MAC address or IP filters. It should be wide open. You dont need ANY drivers for a router on a PC unless they are USB drivers for a USB connection straight to the router, never seen one but I have seen a cable modem/router that had a USB connection. If your laptop has a USB wireless device, you need to load the drivers for that onto your laptop, but if it is using the built in ethernet port on the rear or a PC card ethernet card, you just need to plug the ethernet cable to the rear of the router and boot up. Make sure your ethernet device is enabled in windows and you should be good to go. After you gain access to the internet on the wireless device, get back into your router, prefferably on the wired computer and lock your network down with security measures like MAC address filtering, WEP, or other means.
May 16, 2008 | Compaq Computers & Internet
Open Questions:
Computers & Internet Logo
65 people viewed this question
Top IOGear Computers & Internet Experts
John Anderson
John Anderson
Greg Cann
Greg Cann
Dave Harris
Dave Harris
Are you an IOGear Computer and Internet Expert? Answer questions, earn points and help others
