Question about Iomega HDD External Desktop (32660) 80 GB Hard Drive
Could I buy an usb to esata adapter, then an esata cable? That way I could plug my usb cable (that came with my hard drive),into the adapter and then the esata cable into the other end of the adapter, then plug the esata cable into the DVR??? I'm trying to connect my hard drive to my DVR to record movies to. See less
3 Suggested Answers
  • 76 Answers
SOURCE: connecting a esata port to a sate external hard drive
I don't think there is a converter from USB to ESATA, but you could buy a new Hard Drive enclosure that has those options, but I am not sure if you are willing to take out the HD from the existing one.
Posted on Sep 09, 2009
Testimonial: "I received an answer but I'm not sure I can replace the hd cover with the adapter cover."
martin-r
  • 151 Answers
SOURCE: My Iomega eGo Portable Hard
Have you tried connecting it with the Firewire cable that came with it? (your pc may not have the correct port) or connecting it with a different usb cable?
Has the drive been dropped? it has a protection system which shuts the drive down when it is dropped. you may need to put the HDD into a different caddy or plug it directly into a desktop pc's motherboard to retrieve you data.
I hope this helps.
Posted on Jan 21, 2011
USB broken
Pop in to your local PC shop. You should be able to buy a new cable relatively cheaply.
Dec 10, 2013 | Computers & Internet
Macally G-S350SUA power supply
  • I have the same Macally hard drive enclosure and I misplaced my power supply also. I used an old IBM Thinkpad power supply. These are common and cheap. The Macally enclosure states 12V DC input, and the Thinkpad PS is rated at 16V but it works fine. The plug and polarity are correct.
Oct 11, 2012 | Macally G-S350SUA 3.5" Hard Drive...
Hi , i have a 500gb hardrive i bought a few months ago, full of family memorys and although it powers up the computer has stopped or failed to regonise the hard drive , pleaser can you help .im desperate
Replace the cable you are currently using with your printer cable and see if it is the cable if that is not the case I would open the case, and check your connections on the hard drive, there is a chance it might have come loose.
Jun 23, 2011 | Genica 2.5 USB 2.0/eSATA Aluminum External...
I have windows server 2003 professional edition installated.Cannot access seagate external hadrdrive
If you were able to access it before and the drive powers up when you turn it on, the most likely cause is that the USB connector is broken. If your drive came with a Firewire adapter and you have a firewire connector for your computer. Then swap the usb with firewire interface and confirm that the drive is still working. If it works then the USB adapter is broken. The second alternative is to try the eSATA connector if you have an eSata interface on your computer get a cable and check that the drive works. Third way to check is to puchase an eSata adapter the allows you to plug the eSata to the usb port on the computer. Forth is to try and open the usb module and solder the usb connector back on. Fifth is to try tearing open the drive case (difficult but not impossible) and put the drive into a different case (purchase at Best Buy, Staples, online, etc)
Sep 15, 2010 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
1 TB Esata/FireWire400/USB 2.0 disk problem, one flashing light
have you checked the output on the power adapter when you plugged in? if not, there is no hard reset for the drive. you just have to isolate the board on you external hdd.
Mar 02, 2010 | LaCie d2 Extreme 250GB External with...
I plug the external hard drive the blue light shows put on the computer it doesnt show at all not on device manager or disk management please help
In the past I have had problems with external esata drives. Unplug the drive and turn the computer off. Plug the drive back in (with the computer off) and restart the computer. Look if the drive is there.
Don't forget that external esata drives also need an external power supply.
Nov 03, 2009 | Acomdata 1TB Puredrive USB Esata 1 TB Hard...
I'm trying to plug my sata hd into my esata DVR
What you can do is go to a good computer hardware store like, new egg. or somewhere that sells core hardware for computers. you should be able to buy a PCI-E or a PCI ESata card so you can plug it in. hope this helps!
Sep 10, 2009 | Mag Innovision InnoVision XJ 717 Monitor
Connecting a esata port to a sate external hard drive
Sep 09, 2009 | Iomega HDD External Desktop (32660) 80 GB...
ESATA Connection problem with My Book & my laptop w/ Vista
Had the same problem with a WD esata 1TB drive and an HP DV6 laptop. Using Vista home premium. Lots of experimentation BIOS settings and driver update, and finally fixed it by trimming back a couple of mm of the plastic shoulders on each connector of the esata cable. A few depth measurements and it became clear that the connectors weren't going in deep enough otherwise. The cable was a Belkin of reasonable quality.
No problems now, but the drive is only recognized if it's connected at boot-up.
The core of the problem is the external casing of both the laptop and the WD drive enclosure. They're thick and keep the cable connector from going in far enough. Perhaps manufacturers of the cables or the esata devices are sloppy, or the standard isn't specified well enough. I've seen pictures of esata cables that have significantly different dept.
May 14, 2009 | Western Digital My Book Essential Edition...
New Seagate FreeAgentPro USB eSATA 500GB power on light not glows
Thank you for your reply.
I have solved the problem with local help.
Printed installation manual of Seagate 500 GB eSATA external hard drive has not properly mentioned how to use power on/off switch once connected to mains. I could get local help, who has already used the device. On/Off switch to be pressed for few seconds after mains connected, sometimes it comes automatically once power is on and USB cable pluged to the USB port of PC if power supply is ok. There is no indicator for the power supply (before device glows) after connected to the mains. I was in confusion whether power supply is ok or not.
Finally, It was found that the problem was with mains power supply and I have changed the power socket and adapter.
SP Jena
Nov 18, 2008 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Iomega HDD External Desktop (32660) 80 GB Hard Drive Logo
32 people viewed this question
Top Iomega Computers & Internet Experts
Owen Barnes
Martin Murray
Are you an Iomega Computer and Internet Expert? Answer questions, earn points and help others
