Question about Dishwashers
Does not work on 50Hz kenmore elite dish washer
Dishwasher does not work on 50 Hz AC power
  • 115 Answers
You should have 60hz most things in u.s. run on 60hz.
Posted on Sep 10, 2009
    President:
  • 2,976 Answers
If it was built for 60Hz AC power (American), it will not work on 50Hz power. The Hz, is the number of cycles per second, the electricity makes. If your motor & controls are wired for 60cycles, they will not get the proper electrical supple to work on 50 cycles. AC voltage goes from neutral to positive to neutral to negative to neutral, (one cycle) according to the country you are in. Some countries also use 230 or 240 volts, instead of 120 volts.
What is the frequency of Briggs and Stratton portable generator 30552-00 and if it is 60 hz and I wanna change it into 50 hz, Is it possible and how?
It be better to obtain an unit that already design for your area as it will the appropriate electrical outlets.
As for the 30552-00 would be 60 Hz with running at a governed speed of 3600 (3750 unloaded).
Being a two pole generator frequency is determined by dividing engine as follows. 3600 / 60=60. Engine is RPM is in minutes and must converted to seconds. For 50Hz operation the engine speed must be reduce to 3000 rpm (50hz * 60seconds = 3000 rpm)
Feb 08, 2015 | Briggs Electrical Supplies
What is the wattage of Kenmore 385.15202 sewing
The wattge used should be listed on the machine or it's wiring. If not, you should go to ( sears.com ) and find support. I do not see a problem using an outlet there from a public power as long as you have set the unit to use the correct cycles which is normally 50Hz or 60Hz. Some electronic devices such as yours will operate on either, but you will normally have a switch to manually set which Hz setting you need. The power you recieve from the utility will be either 50Hz or 60 Hz and you will have to set the unit to match the utilities rating. Best Wishes.
Sep 01, 2014 | Sewing Machines
Losses Time
what frequency does Jordon use on their power is it 50 hz are the clocks 60 Hz designed power usage.
may need a device to convert 50hz to 60hz
search google for
50 hz to 60hz frequency converter
Apr 15, 2014 | Sanyo R-6800 2-IN-1 ALARM CLOCK AND RADIO...
I have a Kenmore dishwasher am not sure of the model number it is a Kenmore Elite with stainless steel interior. i am using Cascade advanced power liquid detergent and am getting over a time a black...
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
Oct 25, 2010 | Kenmore 15899 Built-in Dishwasher
Is it possible to convert a 60 Hz dish washer to work on 50 Hz, and how.
hello, so long as you have it wired to a 110v outlet 50-60 hertz is not going to be a problem and you don't need convert it. If however you are hooking it up to a higher voltage, you will need a step down transformer. If you have any questions please feel free to comment again. Mike
Sep 12, 2009 | Kenmore 24 in. 16032 Built-in Dishwasher
Kenmore washer won't go to final spin
The motor won't like the 50 Hz power because it was designed for 60 Hz. The same goes for any transformer that powers the electronics. Changing the motor and transformer for local parts might solve the problem, but likely to be quite costly. It might be better to pick up a machine made for this market. If you can find and use a 60Hz generator, you could see if that fixes your problem. Good luck!
Aug 21, 2009 | Washing Machines
Kenmore elite dishwasher leaves food particles on dishes
If someone is putting dishes in the washer and obstructing the spray ams that would cause food to stay on dishes. After loading dishwasher and pushing in baskets make sure the spray arm doesnt hit any of the dishes causing them to not clean properly. If that doesnt work or is definately not your problem try removing the spray arm and seeing if it has food inside of it. Some times they get food build up in them and need to be flushed out.
May 12, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
Kenmore elite dishwasher does not dry
one of the buttons on the door will give u heat, just push that button
Apr 19, 2009 | Kenmore 18 in. 14432 / 14439 Built-in...
Banding adjustment option in digital camera
50Hz and 60Hz is frequency of AC power supply. If you are in usa, select 60Hz and if in uk, select 50Hz to avoid flickers of florescent tube lights in picture.
Sep 08, 2008 | Canon PowerShot A75 Digital Camera
Dishwashers Logo
122 people viewed this question
Top Dishwashers Experts
