Radio Communications Logo
Wil Guthrie Posted on Jul 25, 2019
How to put my dg-478 vibe in pairing mode I forgot how to after having it for a year
Bill K
Level 1:
Welcome Back:
Visited the website for 2 consecutive days.
  • Contributor 7 Answers
  • Posted on Oct 16, 2019
 Bill K
Contributor
Level 1:
Welcome Back:
Answers
7
Questions
Helped
4405
Points
17
2 Related Answers
I808
  • 10 Answers
  • Posted on Jun 15, 2009
SOURCE: Forgot how to put my Blueant in pairing mode. the
Turn it off, then when you turn it back on keep the power button (the green one) down until the blue light starts flashing red and blue.
Mister Danger
  • 5631 Answers
  • Posted on Nov 13, 2014
SOURCE: VE-10EL-DG
WHAT IS YOUR QUESTON?
tip
How to put most Bluetooth headsets into Pairing Mode?
There are two main ways to put your Bluetooth Headset into Pairing/Discovery mode:
1. For devices that have a Power Button
Start with the headset in the OFF state, then hold the power/action button until it goes into pairing mode (about 3-5 seconds). When in pairing mode, the light should be flashing red and blue or have a steady blue light, in most cases.
Then you can discover it with your phone or PC.
2. For device that have an On/Off SWITCH
Start with the headset in the OFF state, then hold the call/action button while you turn the headset ON. The headset should now flashing red and blue or have a steady blue light, in most cases.
If you forgot the pairing code, refer here:
http://www.fixya.com/support/r5008953-pin_codes_most_bluetooth_headsets
If you need a copy of your manual, refer here:
http://www.fixya.com/support/r4964670-get_manual_most_any_electronic_device
on Jun 02, 2010 • Radio Communications
tip
Show Routing Table button will open a chart displaying how data is routed...
Show Routing Table button will open a chart displaying how data is routed through your LAN. Use the example below on how to configure a static routing:
STATIC ROUTING:
192.168.2.2 192.168.1.2
ROUTER C ----------------- ROUTER B ----------------- ROUTER A--------------PUBLIC IP ADDRESS
192.168.3.1 192.168.2.1 192.168.1.1
ROUTER A: Gateway Mode ROUTER C: Router Mode
1STENTRY 1ST ENTRY
DESIP: 192.168.2.0 DES IP: 192.168.2.0
SM: 24 SM: 24
DG: 192.168.1.2 DG: 192.168.2.2
HOP COUNT: 2 HOP COUNT: 3
INTERFACE: LAN INTERFACE: WAN
2NDENTRY 2ND ENTRY
DESIP: 192.168.3.0 DES IP: 192.168.1.0
SM: 24 SM: 24
HOP COUNT: 3 HOP COUNT: 2
ROUTER B: Router Mode
1STENTRY
DESIP: 192.168.1.0 WAN IP: 192.168.1.2
SM: 24 SM: 24
DG: 192.168.1.2 DG: 192.168.1.1
HOP COUNT: 2 DNS: DNS of 1st router
INTERFACE: WAN
2NDENTRY
DESIP: 192.168.3.0
SM: 24
DG: 192.168.2.2
HOP COUNT: 2
INTERFACE: LAN
1stRouter must be set on Gateway Mode
2ndRouter must be on Router Mode
Use Static Routing
Select Entry
Destination IP = IP Subnet of the 1st Router
Subnet Mask = Subnet Mask of the 1st Router
Default Gateway = Interface IP
Hop Count = 1 + n
Interface= Connection to the 1st Router
Hope this help everyone.
on Apr 22, 2010 • Computers & Internet
I forgot how to connect my DG Bluetooth Keyboard Case to my iPad. Can you help please?
It should be just like pairing an audio Bluetooth device. Turn the iPad's Bluetooth on and the keyboard as well, the iPad will look for an available device, it should pop up in the iPad, tap it to pair, if its ask for a pairing number, it should be noted in the box that came with the keyboard or in the instructions, that should be it.
VE-10EL-DG
2helpful
Asus Xonar DG PCI 5.1 Playback is choppy with a "Matrix" like sound light "popping" sound occasionally using Windows Media Player 11 CD/DVD and Online My 8 year old's...
you need to download the audio drivers for you mother board, upon downloading make sure you type the correct model of the mother board to make sure it is compatible. that's all thank you.
I forgot the cod
Once you make your phone discoverable, then put the Plantronics 230 headset into pairing mode by pressing the call control button until it flashes red and blue. The passkey code is " 0000 " (four zeros). Here is a link for the pairing instructions:
Plantronics Explorer 230 Pairing Instructions
Good luck from Headsets Direct!
Forgot passcode and cant find manual so i cannot pair it with my new phone
iIf you know how to put ur device into pairing mode then most pass codes or pins\pairing codes are as follows 0000,9999,1111,or 1234 most blue toth manufactures from north america use 0000 i hope this helps but you need to know how to put ur blue tooth device into pairing mode ,usually you hold the power button on for 6 to 10 second untik u have a solid light or tone depending on the device u have..once again i hope this helps
53helpful
2answers
Top Radio Communications Experts
eradiostore
eradiostore
 Grubhead
Grubhead
Are you a Radio Communication Expert? Answer questions, earn points and help others
