Question about Goldstar Heating & Cooling
Water spewing from unit - Goldstar Heating & Cooling
    President:
  • 2,976 Answers
If water is coming out the back, that's good. If it's going into the room, the unit needs tilted downward more on the outside. Minimum 3/4" from the window to the back end. Check to make sure the drain hole isn't plugged.
Posted on Sep 10, 2009
Water spewing from therma pressure unit
If you're referring to the thermal relief valve, it is probably bad from freezing or popping open to many times (from running with gun closed too long)
Sep 16, 2014 | Garden
Our super old insinkerator is spewing out water and gross dirt junk! What do I do?
It has to be clogged, try putting some Very hot water down the insinkerator. Remember if you have a dishwasher, it also usually uses the insikerator to drain. The Ice wont hurt the unit... so try both.
Jun 19, 2014 | In-Sink-Erator 1019E InSinkerator Batch...
Water spewing from piping near the water pump
The water pump is most likely bad.They leak when they wear out.You need to replace it and check all your hoses make sure none of them are leaking.
Apr 02, 2014 | 2000 Mazda Familia
It's two years old, and is now spitting out lots of water.
Should have a drain on the unit. Check for ports that have debris in them on the outside of the unit. Clean the debris out and the unit should drain normally.
May 30, 2010 | Haier ESA306 Air Conditioner
My takagi Jr is spewing black smoke?
If you are the technical type you can take it apart and clean the burner, the thermocouple and the chamber....This may fix it. If it is the orface that needs to be cleaned, call the gas company, they will clean it for you for a small fee.
good luck,
James.
----PLEASE CLICK ON 4 THUMBS UP 4 ME----
Apr 25, 2010 | Heating & Cooling
Water build up and spew into the room out ofvent
No. It should not spew water into the room. The drain pan is choked up. clean the drain pan and the problem will be solved.
Aug 15, 2009 | Haier Heating & Cooling
Water spews out drain when washer is draining
Call one of those sewer boys, partially clogged I would say.
Anymore drainage problems in the house.
To avoid costs could try to clean the water lock.
Ask price on before hand, avoid night weekend calls.
Apr 16, 2009 | Kenmore Washing Machines
Water spewing into the reservoir and ovrflowing
Sounds like you do not have an orifice in the water line to regulate the water pressure.
Feb 25, 2009 | Aprilaire 550 Humidifier
Heating & Cooling Logo
43 people viewed this question
Top Goldstar Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Are you a Goldstar Heating and Cooling Expert? Answer questions, earn points and help others
