Question about GE Refrigerators
Refridgerator does not keep cool.Replaced the defrost thermostat and keeps doing the same thing. I have to unplug and thaw for 24 hrs and fridge works again for 2- 3 weeks and i have to repeat the thawing.
  • Otech May 11, 2010
    Did you replace the defrost timer or the defrost termination disc? any other info like model# will help
  • GE Master
  • 1,606 Answers
More often than not , when a defrost problem occurs , the defrost heater is the problem . With your G E , the heater is in a glass tube , below the coils . If you replace this , then the defrost timer would be the only part of the defrost system left .
Posted on Sep 10, 2009
How do you add a switch to disable the thaw cycle from an Amana top freezer fridge.I need to do so i can use solar power on my fridge.the thaw unit uses to much energy so when i am boondocking i can switch...
while i do not reccomend doing this since more energy is used in running the components to make is cool (compressor,compressor fan & freezer fan) all 3 must run to keep it cool while the defrost comes on for 25 minutes about once every 4 days as compered to the cooling components running a average of 24 hrs during the same time span as compared to 25 minutes is to disconnect teh wires from the defrost heater behind the freezer back wall
ps if you read this and give me a bad rating i do not care
Aug 11, 2011 | Amana ATB1832AR Top Freezer Refrigerator
Freezer was working but there was no cooling in the rest of the Fridge.Technicians refilled Gas and also replaced Thermostat.While compressor on,there was a thick ice deposition on the return pipe of the...
You got suckered by the sounds of it.... if your freezer is working your fridge is fine as far as gas charge goes.... thermostat MAY have been faulty but I doubt it.... Your problem probably started a couple weeks ago when the drain that allows defrosted ice (water) to drain into the drain pan at the base of your fridge became plugged for some reason. Then everytime the fridge went on defrost more water melted but did not drain which in turn froze. Now ice has built up and caused the air that flows into the fridge to be blocked, causing a warm fridge.... my advice is to leave fridge unplugged for 48 hrs to thaw it and find the cause of the water not to drain... could be a corn niblet or pea from the freezer... the tube should be visible from the inside or the back
Jul 21, 2011 | Electrolux Refrigerators
Refridgerator part of Miele fridge / freezer is not getting cold at all. Freezer part is workng fine with no issues. Have tried to reset but with no luck. Would like to know what the problem may be if...
It can be defrost issue.
Try manual defrost reset procedure: ----
First unplug the unit from main power outlet. Then empty whole unit completely. Then keep both the doors open. Wait for 24 hours. All the ice collected on the coils and in the freezer section will get melted. Clean the water from the sections. Then Connect the power cord of the unit to main power outlet after 24 hours/.Then set the temperature to normal in both fridge and freezer section. It will take near to 4 hours to get run in its proper cooling cycle. Then check, if the problem returns again. If the same problem occurs then it's defrost problem. The defrost board and the defrost thermostat/heater is not functioning properly and it has to be checked and replaced. The defrost assembly consists of three main parts. The defrost thermostat, the defrost heater and defrost board. Any of the one is not functioning. When thermostat sense the maximum cooling, it triggers the defrost heater to start heating and this defrosts the ice collected on the coils and the system works. Both thermostat and heater are controlled by defrost board. First the thermostat and defrost heater to be checked, if both check ok by meter and visually, then its defrost board causing the problem. You can get required parts from online sites like: --- www.repairclinic.com or from searspartsdirect online site.This should help.Thanks.Helpmech.
Apr 27, 2011 | Miele Refrigerators
Maytag msd2454gr side by side. The evaporator coils freeze up and the fridge gets warm. This happened about a year ago and I thawed it out and everything was fine. It happened again about a week ago so...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Aug 30, 2010 | Maytag MSD2454G Side by Side Refrigerator
Refrigerator is not cold (50);freezer is working; vents not blocked. What can I do? Fan is working, & compressor does kick on.
Nine out of ten times it turns out to be a defrost issue. What most people dont understand is the refrigerator gets its cool air from the freezer. If the evaporator coil in the freezer becomes a block of ice then the airflow from freezer to fridge section is blocked. The block of ice along with already frozen foods in the freezer compartment help to keep those foods frozen. Therefore you assume the freezer section is fine. However, the lack of cool airflow to the fridge side quickly turns that 38 degree air into 50 degree air. You could try unplugging the fridge and leaving doors open for 24 hours, this will thatw the evap coil. Plug it back in after the 24 hours, and within 12-24 hrs everything should be cool. If the fridge continutes to cool for about 3-6 days and then fails again, you certainly have a defrost problem. This is long winded, but hope it helps
Mar 01, 2010 | Refrigerators
Refridgerator and freezer stop cooling
inspect first the condenser at the rear or at the bottom back of the freezer. see if it is full of dirt and trash.
if it is, clean it and it could just be the problem.
if not, then observe the unit further, adjust the thermostat first to the coolest setting just to eliminate the problem with the thermostat.
keep me posted.
tnx 4 using fixya,
drcool
Nov 08, 2008 | Kenmore Refrigerators
Kenmore refridgerator c1065094881
It sounds like your defrost cycle has stopped working. unplug your fridge for 24 hours and let it defrost. plug it back after 24 hour and if it starts to cool in the fridge part at about 40 degrees F. you will have to replace one of three parts the Defrost Timer, Defrost Themo or Defrost Element. I hope this helps you.
Dec 22, 2007 | Refrigerators
Refrigerators Logo
77 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
