Question about Refrigerators
GSS25JEMC won't get cold
I saw the post about the control board. I thought I saw a small darkspot on a component on the board. I touched a hewat sink next to itand felt an electric current. Do you think that's it? How do youcheck the compressor relay? Need a solution fast!!! thanks
  • Refrigerators Master
  • 1,606 Answers
If the compressor doesn't run , but the fan next to it does , then the board is the problem . If you can remove the board , and turn it over , look under the small black boxes , but on the soldered side , and you should see a spot where the solder has heated and moved away from the small terminal . "Resolder" this spot , and reinstall the board and the compressor should come on .
Posted on Sep 10, 2009
Testimonial: "I wiggled the board and the compressor started. I'll try the solder fix in the morning. Thanks!!!"
  • Mike Smith
    Mike Smith Sep 10, 2009
    If you saw a black spot on one of the resistors (one right above another ) then one of the fan motors probably isn't working , therefore , replacing the board , is the only "fix" .
  • 4,070 Answers
Check your compressor relay- http://www.acmehowto.com/howto/appliance/refrigerator/check/compressorrelay.php
Uaually if the relay will rattle it is bad.
How do u know when a circuit board gets hot
Usually, it's one or two components that get hot - not the entire board. You should never touch a circuit board while powered to "feel for heat". Disconnect from power (unplug, shut off circuit, etc.) and wait a moment for capacitors to safely discharge. Check all components with a volt meter BEFORE touching them with your hands. You may also look for discoloration on the board near a component. If the component is raised off the board - it may not cause the board to discolor - as the further away from the board it is the less likely it will be to cause discoloration. High heat components have "heat sinks" that are larger pieces of heat conducting materials that are in physical contact with this components designed to wick heat and transfer it to the chassis, frame or air. These components will be warm or even hot to the touch - but it will be difficult to know if "too" hot as a result.
Oct 27, 2015 | Pool & Spa
Tip
Grounding yourself and saving your components from shock
Grounding yourself is one of the most basic things to do when working with electronic components. While most people know that a pipe for say a sink (or a water pipe if you happen to be working in an unfinished basement), is grounded by being in the the actual ground.
Most people have felt the shock of a finger touching someone while after walking around in socks. Walking in socks will help keep your American floor more clean, rather than bringing in the filth that our shoes go through. Shoes have been in parking lots public bathrooms, and everywhere you can think, so keeping the shoes at bay next to the open doors is healther.
But no shoes means more static. so touch one of those water pipes and you will be grounded. and the chips, say a ram chip will not be fried. If you dont have pipes exposed, there are still several ways to ground yourself. The easiest is to touch a bare metal surface that is grounded. For some this might be the back of a desk top where the power plug in is located. For others try touching your sink faucet, might as well wash your hands while your there.
static although its around our daily lifes, can cause big trouble for chips. for them its like lightining. thousands of volts can be transmitted and fry chips. so be sure to ground yourself before working on any computer electronic component.
on Apr 19, 2010 | Computers & Internet
Tip
PS3 (Playstation 3) Yellow Light Of Death REPAIR GUIDE
Disclaimer: if your PS3 is still under
warranty then please send it back to them for repair.
DO NOT Try this repair IF IT IS STILL UNDER WARRANTY.
This Guide is for the repair of *********** boards only and
will not repair your power supply or read errors.
In this guide there is no guarantee you will fix
your ps3 and by following this Guide YOU take on full
responsibility for any damages caused by following this guide.
Tools needed
Heat gun .
Isopropyl alcohol.
Vacuum cleaner or compressed air can.
Phillips screw driver.
Flat Head screw driver or slotted torx bit.
Artic Sliver 5 (Radioshack)
1. Remove warranty sticker and rubber foot that’s
positioned above hard drive bay.
This will invalidate any warranty.
2. Using a small flat blade screw driver or slotted torx bit,
unscrew cover plate screw.
3. Slide cover plate towards the left until it stops and lift
off.
4. Remove all Phillips screws marked noting size and
position.
5. Hinge case towards you until disengaged and then tilt
towards the left. See below.
6. Remove ribbon cable by carefully lifting black part of
connector (locking tab).
7. Lift/tilt blue ray drive towards the right whilst
disconnecting power cable and the large ribbon (lift tab)
underneath.
8. Remove 5 screws and the earth wire screw on psu, and
unplug connector plug.
Before removal of psu unplug small bnc connector (black
wire) and remove tape on side of psu, now lift off psu.
9. Now remove the wide ribbon from connector (lift tab)
unscrew the four screws on the Bluetooth board and
remove.
10. Remove hard drive cover,
11. Unscrew blue hard drive screw and disengage hard
drive by sliding towards gap in the bay. .
12. Remove hard drive,
13. Unscrew 4 screws holding the bracket, on/off and
eject control panel.
Remove small ribbon (lift tab) and remove control panel.
14. Unscrew 8 screws,
15. Lift enclosure out of plastic base,
16. Now unclip black rear panel and remove.
17. Unscrew 4 screws and remove sprung brackets,
18. Lift of metal cover plate whilst allowing ribbons to
pass through gaps in plate without damage, see below.
(Taking note where heat sink rubbers are positioned).
19. Supporting fan assembly turn board over, remove
fan power connector and fan,
20. Remove 2 screws holding plate to hard drive
connector and unplug battery connector. See above.
Now remove plate.
21. Clean off old heat sink compound from the 2 main
processors using Isopropyl alcohol Or Artic Silver remover Faster Than alcohol)
making sure all traces of the old heat sink compound has gone.
22. Clean both touch plates on bottom of fan/heat sink
assembly with Isopropyl alcohol until all traces of the old
23. Now using a vacuum cleaner or compressed air
blower get rid of all dust build up in the case and on all
component parts of the ps3 (pay special attention to the
fan assembly and heat sink fins(MUST BE CLEAR OF
DUST).
24. Place the ps3 mother board on a flat heat resistive
surface (kitchen work top or melamine shelf will be fine).
25. Turn heat gun on and set temperature to 350 deg
and the fan speed to low (to high and it will move the
surface mount bits).
Allow gun to get up to temperature before
continuing!!!!
Note (There is two Large Square Chips in the Middle of the board these are your CPU and GPU they both have two Black Rectangles Right Next to them. These are the Memory Chips. These are the only things you will be Heating Up on top and Bottom)
26. Using a circular motion hold heat gun over areas
outlined below (keep heat gun an inch above
board/components at all times).
27. CPU side first.
. After 15 to 20 seconds move onto the next area.
28. Once all marked areas have been heated/reflowed
on the mother board LEAVE for at least 10 to 15
minutes to cool.
(DO NOT MOVE MOTHER BOARD WHILE COOLING).
29. A popping noise may be heard during cooling, don’t
worry this is normal.
30. NON CPU side.
31. After 10 to 15 seconds move onto the next area.
32. Once all marked areas have been heated/reflowed
minutes to cool.
33. A popping noise may be heard during cooling don’t
Heat sink compound still on in this picture, remove
before reflowing.
Heat sink rubber pads still on in this picture remove
before reflowing also hold ribbons out of way while reflowing;
You have just repaired you’re yloded ps3
mother board.
34. Now its time to apply new heat sink compound to
the 2 processors, when doing this its always best to
follow the manufacturers instructions but I believe the
process is the same with all types (please check
instructions that come with paste), before continuing
35. Now Get your Artic Silver 5
36. Place a Small amount of compound from top to bottom on the left hand side of
processor chip, now using a finger with some Plastic over the tip spread the
compound evenly and thinly over processor face (to much
is bad and not enough is also bad) the ideal amount is
when you can almost see through the paste.
37. Now repeat on the other processor.
38. NOW IT IS TIME TO REASEMBLE THE PS3.
RETRACE YOUR STEP IN REVERSE TO REBUILD
MAKING SURE ALL RIBBON CABLES HAVE BEEN
FULLY INSTERTED INTO CONNECTORS AND LOCKED
DOWN IN. (TABS).
on Dec 15, 2009 | Video Game Consoles & Games
Clean heat sink on toshiba satellite
Turn off the Satellite laptop and flip it over so you can see the bottom. Push the battery latch towards the outside of the laptop and remove the battery.
Locate the heat sink panel, which will be next to, or including, the two fans that you can see. Unscrew the two to three screws that are holding that panel down, and remove them.
A few models of Satellite laptops use Torx sized-8 screws instead of Phillips.
Unplug the cables running from the two fans to the control board.
You can see the cables coming up from under the fans.
Then unscrew the two to three screws on the fans, and pull up to remove the fan unit from the laptop.
If your Satellite heat sink panel does not uncover the fans as well as the heat sink, ignore this step.
Remove the four screws that surround the heat sink.
Then move the heat sink back and forth to disconnect it from the CPU.
If your laptop shuts down by itself without any reason, check the heat sink first.
Overheating is a very common problem among Toshiba laptops.
Lift up on the heat sink to remove it from the unit.
If the CPU got caught on the heat sink and comes off as well, grasp it by the edges and peel it off the heat sink.
Turn the screw on the side of the CPU socket to unlock it, then place the CPU back in its socket and lock it again.
Blow compressed air into the heat sink and the fans until the dust is removed.
Then blow the air onto the control board to remove loose dust from there as well.
Place some Isopropyl alcohol onto your cloth, or a small brush, and clean the processor and the control board area around the processor.
You will also want to wipe up the thermal grease that is on these components. Make a note of the area where you removed the thermal paste.
Reapply a layer of thermal grease in the areas where you removed it.
The lid of the thermal grease container will have an applicator.
Just spread the grease over the components.
http://www.hardwaresecrets.com/article/Thermal-Compound-Roundup-February-2012/1490
Replace the heat sink, then the fans and finally the heat sink panel cover.
hope this helps
Oct 09, 2012 | Toshiba Satellite L505DGS6000 Notebook
Bosch 4000 table saw will not start. I changed the switch and still won't start, not even a sound. The saw is relatively new, and the outlet works. What should I try next?
A real Weakness of this saw is sawdust and debri entering the cooling ports of the motor causing intermittent contact of brushes which damages the motor speed control board ($40.00). Don't ever operate this saw with out a vacuum saw dust extraction system. Also when you replace the Speed control board also replace the Brushes ($6.00). It helps extend the operational life of the motor components to blow out the contaminants regularly with compressed air through the motor cooling ports (turn off saw first).
You can bypass the speed control board (if you want to disable this wonderful engineering feature by attaching black and white power wires directly to the black and white wires to motor.
Feb 22, 2010 | Bosch 4000 - 07 Electric Table Saws
GSSs5JEMC won't get cold
Cool, Sounds like a loose connection or a weak solder point on the board. Did you wiggle that heat sink or a connector. Just make sure all the connectors are firmly in place and not loose, especially the ones that provide power to the compressor. Board may have to be replace if a component is loose...or you can try to resolder if your comfortable doing that kind of stuff.
Sep 10, 2009 | GE Refrigerators
F11 flashing kenmore he washer
The F11 error code indicates a serial communication failure. This happens when the 2 main control boards are unable to communicate with each other. This is either caused by a loose wiring harness connection or one of the control boards is defective. Good luck and please rate FixYa!
Dec 28, 2008 | Kenmore Elite 45986 Front Load Washer
Mainboard shutdown
Never do that to fuses, search the web (especially the site of your laptop's maker) for common cures to your situation, and failing diagnosis recommending a particular cure, don't do stuff at random.  That sort of thing sort of sounds like a battery issue; won't the thing come on with no battery, but the power power connected?
Sep 10, 2008 | Intel Motherboard
Retrace lines and poor convergence
you have bad solder connections on the convergance board solder then and get back to me k
Oct 30, 2007 | JVC AV-48WP74 48" Rear Projection...
Blown capacitor
most of this TV's are not a component level repair anymore,
unfortunately you have to replace the entire board
Oct 16, 2007 | Samsung HPN4239 42 in. Plasma HDTV
Refrigerators Logo
88 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
