Question about Summer Infant Video Monitor W/crib Soother
I just accidentally deleted the camera from the handheld and cannot get it back... now it says no camera is available. This is actually for the Best View monitor (Summer)....so far a piece-o-****.
  • chris king Oct 01, 2012
    Thank you so much this worked for me and my monitor is 5 years old .We got it when our first chid was born and now were using it on our 3Ed.Add a Comment
I know this is an old post but I was having the same problem w/ my monitor. It's an older version but I believe the only difference is it doesn't have the soother. I have the best view day/night handheld. Anyway, I couldn't find help so I did this. From the main menu on the monitor, go 2 add/delete camera & select it by pressing in the middle button that moves the camera around. There is a button on the camera itself. I faced the camera & monitor 2ward eachother & pressed the button on it, along w/ the center (toggle/select) button in the front of the handheld monitor. Careful though, cuz it'll add it more than once & u will have 2 go back & delete.
Posted on Jul 19, 2010
  • jay gilby Jan 30, 2012
    this worked a treat. thank you very much!!!!
How do I synce the camera back to same monitor
I just barely had this problem and was able to figure it out.
You need to hit the "ok" button on the side of the handheld monitor. It will only let you select "add camera".
Hit ok again and it will give you a list of 4 camera's.
Now at this point you will need the actual camera and handheld monitor. You need to hold down the "code" button on the back of the camera and select "camera 1" in the list of 4 cameras. This should sync it back and you should have picture again!
I hope that helps :)
Apr 29, 2014 | Summer Infant Babies R Us Baby Sight Color...
How to recover deleted photos?
Simply put, chances of recovery can be high as long as you act as soon as possible and stop using the Samsung digital camera to take more photos or videos, also keep the camera memory card in good shape (no physical damage).
Then you can rely on a digital camera data recovery software to get the job done and retrieve your photos. Here shows a list of good ones (for PC/Mac) http://www.digital-camera-recovery.com/
You'll need to connect the camera (mass memory card) to your computer. Then install the program to start scan & recover your files. Should be easy to get back your lost memories!
Regards
Aug 05, 2012 | Samsung PL200 Digital Camera
Can I restore photos that were deleted from camera in error
Hello friend,
Yes, you can easily restore accidentally deleted photos from camera memory card with the help of photo recovery tool. Some days back, when I was stuck under similar situation where in I had accidentally deleted all my pictures from camera memory card. Then I tried this tool which really helped me to restore all of my deleted photos from memory card. Just click here if you want to try this software.
Best of luck,
Entyn Fernandis
Apr 27, 2012 | Canon PowerShot A1100 IS Digital Camera
Said yes to format and lost pictures can i recover them
There are many programs that will be able to recover your files, the best one is Migo Digital Rescue but I have also used Recover My Files with good results. The best FREE software I have used is called Recuva but I have also heard people recommend Panda Recovery. Hope this helps!
May 26, 2009 | Praktica Luxmedia 8003 Digital Camera
Restoring deleted pictures
if you haven't continued to use the memory card you can download a freeware called glary undelete.
it will let you undelete most of the photos.there are several available.
The one I used was Glary undelete.
here is the text from the about section.
Glary Undelete is a free and easy-to-use yet powerful file undelete solution for FAT and NTFS file systems. It will bring back files emptied from the Recycle Bin, in a DOS window, from Windows Explorer with the SHIFT key held down. It will even recover files that have been deleted by bugs, crashes and viruses!
Glary Undelete works under Win 95/98/Me/NT/2000/XP/2003/Vista operating systems. The program supports all Windows file systems for hard and floppy drives including FAT12/16/32,NTFS/NTFS5 and image recovery from CompactFlash, SmartMedia, MultiMedia and Secure Digital cards.
good luck
Mar 25, 2009 | Kodak EasyShare M1033 Digital Camera
Accidentally deleted camera icon
I don't think you can actually "delete" the icon for the camera, at least not using the handset. You probably only "hid" it. Try hitting the option button and then select "show all" you should then see the camera icon but slightly grayed out/transparent. go to it and then uncheck the hide option. You can then de-select show all and you should be good to go. If this does not fix it and you did actually delete the camera function, let me know so I can walk you through that detailed process.
Jan 21, 2009 | RIM BlackBerry? Curve 8330 Cellular Phone
Accidentally Deleted Pictures
You can recover deleted pictures from digital camera by follow a good digital camera photo recovery tutorial, take a look at this one that helped me before:
digital camera picture recovery guide
hope this helps.
Aug 25, 2006 | Kodak EasyShare Z730 Digital Camera
Summer Infant Video Monitor W/crib Soother Logo
2,491 people viewed this question
Top Summer Infant Baby Gear Experts
Colin Stickland
Colin Stickland
Paul Bade
Falling star
Are you a Summer Infant Baby Gear Expert? Answer questions, earn points and help others
