Question about Garden
Won't start My Echo weedeater won't start and plug is wet when removed
  • 33 Answers
The plug may be fouled. Replace the plug. Also make sure it is wet with gas & not a watery gas mixture like I had in mine two weeks ago. Apparently the atmospheric pressure drop when it started raining caused it to **** in moisture.
Posted on Sep 10, 2009
    President:
  • 1,776 Answers
If the plug is wet, have you checked to see if you are getting spark? I will assume (something I hate to do) for the sake of argument, that you do have spark. If you have gas and spark then the next place I would check would be the spark arrestor/exhaust port. Make sure it is clear of carbon build-up. It has to be some sort of compression problem, I would think, and that would be a place to start. Hope this helped and let me know how it goes! Best wishes.
How do I fix a echo srm 210 weedeater that starts but will only run a few seconds?
Try calling echo and ask for tech support or go online to get the phone # or check you tube to see if they have a video on it
Apr 05, 2016 | Echo Garden
Hello I have an echo pb-500T, my cord won't pull.
Remove the impeller and check for loose motor mount screws. With the impeller off and the spark plug removed and the pull start functioning properly; if it still wont pull then its likely internal and due to be replaced.
Oct 24, 2012 | Garden
Weedeater will not start
try cleaning the spark arrestor screen
Mar 17, 2012 | Garden
Motorcycle won't fire
is the plug wet with /dry when you remove after attempting to start,what bike is it
Feb 15, 2018 | Motorcycles
My weedeater has no spark at all
If there is no spark then I would suggest checking out the plug wire for cracks or breaks If there is none present then the ignition coil could be finished Take it off take it into your small engines dealer and get him to test it.
Dec 27, 2011 | Ryobi 30cc 17" String Trimmer Zrry30530...
I have a PB251 Echo blower that won't start. I have a good spark Good compression and clean new gas is getting to cylinder because i have a wet spark plug when i removed it ,yet it won't even...
I suggest cleaning the carburetor and replacing the diaphrams. The diaphrams come with a rebuild kit that has a lot of unused parts.
Aug 31, 2011 | Echo Garden
Ryobi 705R weedeater won't run. I can get it to
Yes, it is possible. Here are a couple of Tips to remedy your problem:
www.fixya.com/support/r6078121-fuel_line_relacement_trimmer_weedeater
This should get it running for ya.
Good Luck!
Jim
Jul 24, 2011 | Tools & Hardware - Others
I have a echo HC-150 it won't stay on boggs down
Hi, either the carby is flooding and requires a carby kit or the spark arrestor or outlet in the muffler is blocked. Hope this helps, regards Phil.
Jul 18, 2011 | Echo Garden
The PB-250 will not start. It was purchased last year and used little. I have fresh gas and a new properly gaped OEM plug. I do have spark. The spark plug is wet with fuel. Can one flood the engine by...
It is very easy to flood this item mind you its easy to flood all petrol trimmers. If plug is wet simply turn the switch to off and pull cord at least 15 times you should get the engine to start coughing keep pull cord but do not turn the petrol on do not prime it either. It should catch. If it does not push the primer once and pull cord
May 31, 2017 | Echo Gas Blower 135 MPH390 CFM Blower...
Garden Logo
316 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
