Question about Dishwashers
I have a Whirlpool Quiet Wash dishwasher. I don't
I have a Whirlpool Quiet Wash dishwasher. I don't think the bottom arm is moving and there is a strange noise. I took it apart and there is a white washer that is split - should it be?
  • 530 Answers
Yes.. keep going deeper you will most likely find what is blocking the chopper from turning.
Posted on Sep 10, 2009
Whirlpool dishwasher quiet partner lol is not cleaning dishes on top rack
could be a few things clean inside filters and screens listen to it does the wash motor during wash sound strong like it tossing water around in there open the door during the wash see if kicks some water out at you. If it sounds and seems like its working ok then some units have a rubber check valve little flapper in the tube that goes up the back wall to the upper spray arm i have seem break off and clog that tub not allowing any water to the upper spray arm.
Dec 24, 2016 | Whirlpool Dishwashers
Whirlpool DU1055XTSQ2 Quiet Partner 1 Has grinding noise at start up. Can you send a diaghram so I can take off the bottom sprayer and what do you gthink it could be?
Is start up after filling with water? After it fills the wash motor starts to work. Some times the spray arm could hit the heating coil when it turns. Make sure the spray arm is not loose. But most likely its the wash motor.
Dec 12, 2011 | Whirlpool Dishwashers
Loud sounds
Many Frigidaire dishwashers come with the promise of being the "quietest dishwasher in its class," according to Frigidaire. However, a quiet dishwasher doesn't necessarily mean that the dishwasher is silent, as some noises are normal. It can take some troubleshooting at times to determine if a noise coming from the dishwasher is typical or if it indicates a larger problem Listen for the sound of water filling and draining throughout the wash cycle. These sounds are normal and do not indicate an issue.
  • 2 Pay attention to the drain motor, which operates at the beginning of each cycle. This noise should be fairly quiet and should not sound like a loud, grinding or banging sound.
  • 3 Note that the sound will change when the wash cycle moves between the lower and middle spray arms. This sound should be temporary and fairly quiet.
  • 4 Look for hard items in the dishwasher grinder or filter if a loud crunching, buzzing or grinding sound is heard. The dishwasher can typically grind up these items within one or two cycles, but the item may be lifted out and discarded to eliminate the sound.
  • 5 Remove the bottom rack and spray arms from the bottom of the dishwasher if there is a loud noise coming from the dishwasher that does not resolve itself. Look inside for the impeller, which is round and spins. Remove any debris that may be clogging up the impeller or pump.
  • Oct 07, 2011 | Frigidaire Professional Series 24 in....
    Hello ! We have a Whirlpool "Quiet Wash Plus" dishwasher that is approx 12yrs old. It has performed exceptional over this time, but notice recently it does not get the dishes as clean as before....
    Is the water level ok? Check your water temp into the tub. It needs to be a minimum 120 degrees. Check for plugged spray arms. Do they turn freely? Does dishwasher drain completely?
    Sep 25, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
    Whirlpool du1055xtsq 3 not cleaning top rack of
    In my experience, you probably have a clog in the spray arm/arms for the top rack. Take the arm(s) out and see if the holes in them are clogged. Rice, plastic wrappers, and glass from dishes that broke in there are the most common culprits I've seen.
    Nov 25, 2009 | Whirlpool Dishwashers
    My Whirlpool quiet partner dishwasher seems to run
    try a large cresent wrenck,or channel lock plier.ps.might place towel over plastic nut,to protect from wrench damage.
    Oct 10, 2009 | Dishwashers
    Dishwasher fills and heats water, but doesn't wash.
    To tell you the truth, I don't even know what model my Whirlpool is. However, I had this same issue. My dishwasher would fill, but it wouldn't spray the water. I could hear it hum, but the motor wasn't going.
    After no success finding any ideas online, I had to call out the repairman. Well, 5 minutes and $109 later it was just a simple matter of the motor being stuck. Apparently this is a common issue with GE, but not as common with Whirlpool. Just a seal that gets stuck if you don't use it for awhile (even though there hadn't been any long stretch for me). He reached in/under and turned the motor a bit over a half rotation before it broke loose. It fired up... I wrote the check ... and he left.
    He advised me to run the washer on the rinse cycle at least once a week.
    Hope that helps someone.
    Jun 11, 2009 | Whirlpool 24 in. GU2500 XTP Built-in...
    Whirlpool Quiet Wash Plus Dishwasher is not despensing the detergent properly. After a wash cycle there is still some left.
    My Whirlpool Quiet Wash plus dishwasher seems to have died. No power. None of the buttons work, it quiet mid-cycle. No breaker issue, my garbage disposal runs off same breaker and is working fine. Any ideas? I was thinking the comp. board that the buttons work off of is fried. If this is the case any idea how much to replace it? Would it be cheaper to buy a new dishwasher?
    Apr 21, 2008 | Dishwashers
    Need to remove wash module
    a screw fell into the wash moduel. How do i remove the lower spray arm, ect Thank's
    Feb 08, 2008 | Dishwashers
    Dishwashers Logo
    Top Dishwashers Experts
    Owen Barnes
