Question about Microwave Ovens
No power Have a Whirlpool Gold microwave. I used to to bake potatoes and overcooked them. The microwave burned the potatoes and the whole unit shut down. We let it cool down and try to plug it back on but still does not work. What should I do? It is out of warranty. Purchased in 2005. Never had a problem before till today.
  • 3,051 Answers
Hello there:
what you are going to have to do is:
(1) remove the screws in the back that hold on the cover than look under the microwave and see if there is any screws there and remove them also
(2) now remove the cover and look up towards the front right side top area and you should see a fuse remove the fuse and replacce it than plug in the unit and see if it works if so replace the cover and all screws and you are good to go ok?
If none of the above have seemed to help than i would contact a local authorized repair shop and have the unit serviced ok?
i hope that this is very helpfull for you
best regards michael
Posted on Sep 10, 2009
SET TIMER FOR 20 MINUTES FOR BAKED POTATOE.. CAME BACK AND FOUND POTATOES CHARCOALED. SMOKE AND SINGED INSIDE. MICROWAVE WILL NOT COME ON. CHECKED CIRCUIT BREAKER. POWER TO UNIT.
That was a very long duration to have set for potatoes. It would have made the magnetron burnt by exeeding the limit and findinf there was no conductive medium by moisture , it has ended up burning the magnetron.
First of all clean up the inside and clean up the point of the magnetron beam.Now confirm on the inside to be totally dry.
Disconnect power and check inside for break of fuse to the magnetron.If the microwave does not heat on testing with a cup of water , then it is possible that the magnetron is cooked.
Confirm the cost for the unit to decide on replacement.
Hope this helps.
Aug 21, 2010 | LG LMV1630 Convection/Microwave Oven
Baked potatoes went up in flames now microwave has no power no lights. power outlet has 110v ac
Were the potatoes wrapped in foil? If so, the megatron tube was burned out. Replace unit.
Nov 06, 2009 | Kenmore 62622 Microwave Oven
My Frigidaire Microwave caught on fire
The owner's manual warns of the dangers of overcooking potatoes and similar foods and not to ever leave the oven unattended while it's running.
If for some reason you don't have your owner's manual, you can download Frigidaire owner's manuals and installation instructions here.
Are you looking for help to get your microwave working again?
Chances are it's just an opened flame sensor (cavity thermostat / thermal cutout / T.C.O.). Its job is to cut power if there's a fire.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
Accessing some components for testing and possible replacement (like the oven cavity thermostat) will require you to remove the oven from the wall.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
Jun 07, 2009 | Frigidaire FMT116E1B Microwave Oven
Did I blow it up????
After washing you need to poke holes in potatoe skins or the steam can cause them to explode. Cook potatoes no longer than 6 to 8 minutes depending on your units power.
Microwave ovens can be very dangerous if damaged, so you will be safer to replace the unit. Better safe than sorry. Service on microwave ovens is not cost effective, and the newer ovens are very reasonable.
Ray
Oct 28, 2008 | GE XL1800 1100 Watts Microwave Oven
Overcooked potato overcooked the microwave
The magnetron probably overheated, blowing the thermal cutout / thermal fuse / thermostat mounted on it.
If you or a friend decide to look into it, we have critical safety and
disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
Nov 16, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
64 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
