Question about Plumbing
Pump for short period - Plumbing
  • 523 Answers
I assume you mean the pump will run for a short period and then turn off only later to start again? If this is the case the motor's thermal switch is opening due to too much internal heat. If the pump is miss sized "too lagre for the head (pressure)" the pump will operate off its curve drawing too many amps heating up the motor. If this is the case you can throttle back the pump (less flow more pressure) to keep it on its curve. If however this is an existing pump and now having this issue I'd guess that the thermal switch has weakend and will require replacement.
I hope this may have helped,
Tom
Posted on Sep 25, 2009
PCM problem or what??? My 04 Jeep keeps shutting down due to fuel pump not working. New pump but no current to pump.
Could have an intermittent situation with the pump itself. Did you check that out? Check all connections for corrosion.
Oct 02, 2016 | Jeep Cars & Trucks
Water switch open , heater heats up for short period and cuts out
ensure pump is running at full prime. clean the filter out as well. disconnect both connections from pressure switch in raypack heater. check continuity. if switch opens at any point and you have no flow restrictions then replace the pressure switch
Mar 11, 2014 | Solar Rheem Gas Fired Pool & Spa Heater...
My chevy impala keeps running hot eventhough the radiator and the fluid isn't getting hot. But after running for a short period of time or trying to drive for a short period the car runs hot and c
I would start by checking the fluid to make sure it's at the proper level, Then check to see if the thermostat is opening like it should. If you have good flow and you get heat inside the car but the car still overheats I think I'd be checking for blown head gaskets and head warp.
Jan 30, 2013 | Cars & Trucks
With gas line removed fuel pump quits running after 5-10sec
That is a built in safety. If you're fuel line were to rupture, you wouldn't want the fuel pump to empty your tank. The pump runs for several seconds until pressure is built up or the time-out period is reached, whichever comes first. If you clamp the end of the fuel line, the pump should run for a very short period to indicate the pressure sensor is working. When the clamp is released, the pump should start back up and run for several seconds until the time out period is reached.
Jun 06, 2011 | 1996 Yamaha XV 535 Virago DX
No brake pressure - brakes fad after short period
your abs pump has probably gone out. get replaced immediately before driving :)
Mar 11, 2010 | 1986 Jaguar XJSC
Car wont start at times
try checking the ignition fuse in the fuse box unde the hood. if it doesn't have a good connection or if there is a short it could cause the car not to start. my grand am is doing the same thing and i tried cleaning the connection of the fuse, but i think i may have to replace the fuse box because there might be a short.
Oct 02, 2009 | 2002 Pontiac Grand Am
My dishwasher was run without water in it. did i break it?
By the way, was it still running when you put it off. Anyway, If it was for a short period of a few minutes, 2 to 3 minutes, no damage done. For a longer period, you could have damage the pump. Anyway, try it again, but with water, check pump water leak. If it does, put it off. Have the pump mechanical seal replaced, and continue the test. If there's no water pump in it, just continue the test. You may still have it in good working condition.
Sep 22, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
Plumbing Logo
53 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
