Question about Kenmore 22422 Top Load Washer
Kenmore washer odor
Kenmore clothes washer has odor of burned rubber upon use. Mod 110.24922200 Ser CP0610837 .
    President:
  • 1,937 Answers
The most likely cause of a burnt rubber smell is a worn motor coupler.
Sears parts site
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?pop=true&modelNumber=110.24922200&pop=flush
Go to the sub section with the brake/clutch/motor/gearcase and item # 13 is the motor coupler between the motor and transmission.
It has three parts. 1. A plastic piece with three prongs fits on the transmission input shaft. 2. A plastic piece with three prongs fits on the motor output shaft and 2. a RUBBER grommet with 6 holes fits between them.
Over time, the rubber piece can wear and the two plastic pieces can rub against it at speed causing a rubber burning smell.
Replacing one is easy.
Remove the cabinet, the pump (2 clips) the motor (two screws and clips) and the motor mounting bracket (two 1/2: bolts).
Remove the rubber piece and pry off the two plastic pieces. Fit the new plastic pieces on the transmission and motor shafts. Replace the mounting plate. Carefully line up the six holes as you put the motor back on.
Replace the motor mounting clips, the pump and clips and cabinet.
Posted on Sep 21, 2009
He5t tearing clothes
Are you sure that the clothes are not getting caught on exposed zips.
Why not load some things like towels sheets (without zips/buttons etc) in the washer and see if the issue repeats itself. You should also be able to see if there are any sharp edges or loose sharp items in the drum (mind your fingers)
Dec 14, 2013 | Kenmore Elite 45986 Front Load Washer
My Kenmore Elite HE3 Mod 11044832 202 started making LOUD knocking noises during final spin cycle, then started to smell like something burning. Whit placis shreds in the washer.
the plastic is the drum has dropped so its eating a way the plastic on the back of the drum so no not worth fixing the mould is an easy fix just soke a cloth with neat bleach and leave over night make sure you do a rines after woulds as you don't want bleach on your cloths ok
Oct 21, 2012 | Kenmore 44832 Front Load Washer
Hi i have a kenmore mod.110.44932 200 ser.csn0605989...no code but at time while the washer not in use i hear water then when i check the washer the inside is full of water and running out the door what...
The problem is that the water valve is not fully closing and the water valve would need to be replaced to stop it from filling when off.
The part number for that water inlet valve is 8181694 it could be purchased at your local appliance parts store or online at;
partselect.com
apdepot.com
repairclinic.com
apwagner.com
To replace that water valve,turn off water supply to washer,disconnect rubber fill hoses,remove top and the valve will be on the rear top under the top
GENE
Sep 06, 2011 | Kenmore 44932 Front Load Washer
I have a front loader kenmore and there is a stale smell on my clothes. I have run the machine with vinegar, tried bleach and now have tried tide cleaner for the washer and my clothes still smell.
try to change the rubber around the door opening this will take care on the odor also try using the afrsh washer cleaner and use a double dose 2 tablets
Sep 04, 2011 | Kenmore Elite 45986 Front Load Washer
The washer has an odor like burnt rubber.
It may be your belt burning. Try checking it. It could be the motor or pump as well.
Feb 27, 2011 | Kenmore 24032\24036 Top Load Washer
Kenmore Washer-coupling replaced-
Be sure that when you replaced the coupler, that you tapped on the rear (transmission) coupler. Take a long extension and a 9/16" socket and tap it until the shaft is flush with the inside of the coupler. Also, we have found that sometimes shaved rubber from the old coupler isnt rubbing or fell down in the area. Also, if you have it back out, be sure your new coupler doesnt show wear already. That would be an indication of a bad transmission, basket drive, or drum block.
Sep 05, 2007 | Maytag Neptune MAH5500B Front Load Washer
Kenmore 22422 Top Load Washer Logo
183 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
