Question about Amana DLE330RAW Electric Dryer
Machine squeals when running.
I took off the front and when I turn it by hand, a squealing sound comes from behind the plastic blower wheel
  • 74 Answers
Bearings on the drum roller worn out
Posted on Sep 10, 2009
Loud thumping from under drivers side that started with a squeal.
16 costly car noises - Bankrate.com
www.bankrate.com/finance/money.../16-costly-car-noises-1.asp...
BankrateYou should not ignore certain thumping, banging, clicking and squealing sounds. These sounds often rear their heads or intensify whenever the driver takes ... Hissing or sizzling under the hood: Heard when the engine is first shut off, .... my rear right wheel makes a loud bang when switching from park to drive/reverse.
Sounds coming from drivers side front wheel - AnandTech Forums
forums.anandtech.com > Social > The Garage
AnandTech
Dec 1, 2009 - 21 posts - ‎10 authors
Sounds coming from drivers side front wheel The Garage. ... slightly left, I get a slight metalish-squealing sound coming from the drivers side front wheel area. ... but before I start the wild and expensive goose chase of bringing it to mechanics I ..... Those twoloud clunks when turning hard right give it away.
Ford Explorer Questions - Thumping from front end - CarGurus
www.cargurus.com > Questions > Ford > Explorer
CarGurusDec 22, 2009 - Thumping from front end - I have a hard thumping noise coming from ... without problem then I'll take a turn or something and it will start. ... I just recentlystarted having a rubbing and thumping and squeaking noise in the right front sidewhen driving ... Thumping sound coming from under the truck 4 answers.
Car Noises: Consumer Reports - Consumer Reports Online
www.consumerreports.org/cro/...noises/.../index.htm
Consumer Reports
Feb 03, 2016 | Cars & Trucks
My concord is squealing when moving it sounds like it comes from the front passenger wheel,
check brakes ,check if backing plate is bent , jack up car and turn wheel by hand and see if you hear anything ,you may have to take car out of gear. so be careful
Oct 13, 2014 | Cars & Trucks
1991 nissan maxima squealing clicking noise behind the dash
while clicking is happening place your hand on the heater blower motor and you will feel it coming from there. change the blower fan.
Apr 07, 2017 | 1991 Nissan Maxima
FA4B blower assembly noise
It is possible that the actual fins have separated from the hub. Hold the shaft of the motor (as to stop it from spinning) and the try to spin the fins. You then may notice the welds are broken. Could just be a bad motor, could be just the wheel. Good Luck!!
Aug 31, 2017 | Carrier Heating & Cooling
Squealing sound when air conditioning is on and turning left
same problem...not an a/c issue. When the fan is on and when you turn left.sounds like something rubbing in the blower. took the blower off, no obvious blockage.
Apr 19, 2012 | 2003 Pontiac Vibe
LG dle3777w emitting a high-pitched squeal
Hello there and thank you for choosing fixya
If your dryer is making a squealing sound or a high pitch noise please look at the following
Rollers Many dryers use rollers or wheels to support the clothes drum. When these rollers are worn, they can be noisy. You should replace the whole set of rollers at the same time. Idler pulley Dryers have a tension or idler pulley that keeps tension on the main drive belt. When it's worn, it can be noisy. When that happens, don't lubricate it. Just replace it. Glides Many dryers use nylon or plastic glides at the front of the clothes drum for support. When these are worn, they can be noisy. When that happens, replace them. Rear drum bearing Some dryers support the clothes drum in the rear with a center spindle instead of rollers. The spindle may be a ball-and-socket type support or a shaft through a sleeve. When the components are worn, they may squeak, squeal, or rub. You can't repair them. Just replace them when they're worn. Blower wheel Your dryer's blower wheel pulls air over the heat source, through the clothes drum, and past the thermostats, then pushes it out the exhaust duct. The blower wheel, which is usually plastic, may wear out over time. But if it's noisy, it may simply be clogged with lint. Clean the blower and test to see if the dryer is still noisy. If it is, you probably need to replace it.
May 17, 2011 | LG DLE3777 Electric Dryer
Loud squealing sound when the basket first spins up this is a Kenmore stacked set, washer on the bottom, and dryer on top
Your problem could be a bad bearing...The drum rides in a bearing at the rear middle of unit..Its basically a plastic insert...When the dryer is first started the bearing will squeal until the plastic warms up..Normally you will hear the squeal at the back middle of dryer...Your problem may also be the belt tensioner...Again a plastic wheel with a metal bearing inside...Normally this squeal will be from start to finish..
Apr 20, 2010 | Kenmore 98702 Stacked Washer/Dryer
Engine squealing
Only two choices a belt pulley bearing or the ps pump.
Sep 22, 2008 | 1999 Mercury Cougar
Amana DLE330RAW Electric Dryer Logo
95 people viewed this question
Top Amana Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you an Amana Dryer Expert? Answer questions, earn points and help others
