Question about Sony Handycam DCR-TRV250E Digital Camcorder
Flashing yellow arrow
When attempting to record or playback, after a few seconds to minutes, the yellow flashing arrow with C:31:23 in the top right corner. Someone please help!!
    President:
  • 4,402 Answers
Take the battery out and turn selection switch to camera and then turn it off. Put the battery back in and its working again.
if that doesn't work try
Try smacking the side of the camera relatively hard with the palm of your hand. Eject the tape and reinsert. You may need to do this a couple of times.
Posted on Jan 28, 2008
  • karloksana May 16, 2011
    Thank you for your help i had done every thing that it said in the book but then i read your answer and good god it worked THANK YOU FROM A VERY HAPPY GUY IN UKRAINE
No matter what mode I place the unit in..camera mode or playback mode...I get a yellow flashing triangle on the view screen. I can't record or do playback. Any idea what that yellow triangle represents? ...
I have the same unit and the problem your describing comes and goes from the power switch on mine. (wiggle it)
hope this helps (if it don't... get it fixed this is a cam that cant be replaced even broke they bring in 200 on ebay or did a few years ago )
Dec 14, 2010 | Sony Handycam CCD-TR517 Camcorder
My sony wount record or playback a movie, there is a blinking symbol when i hit record.
I'm Sony tech and can help you to solve problem of CCD-TR818 camcorder.
Tap bottom of camcorder few times with your palm gently, now check playback of tape.
If problem still not solved, let me know what error code flashing on top right of view finder screen.
Thanks.
Dec 04, 2010 | Sony Handycam CCD-TR818 Camcorder
How do I reset the clock on a 2008 Impala, and 2008 Accord? I can't find the manuals
For the Impala:
AM/FM Base Radio with a Single CD Player
This type of radio has a H (clock) button for setting the
time. You can set the time by following these steps:
1. Press the H button until the hour begins flashing on
display. Press this button a second time and the
minutes begin flashing on display.
2. While either the hour or the minutes are flashing,
turn the f (tune) knob, located on the upper right
side of the radio, clockwise or counterclockwise
to increase or decrease the time. Instead of using
the tune knob, you can also press the SEEK arrows,
\FWD (forward), orsREV (reverse) buttons
to adjust the time.
3. Press the H button again until the clock display
stops flashing to set the currently displayed time;
otherwise, the flashing stops after five seconds and
the current time displayed is automatically set.
To change the time default setting from 12 hour
to 24 hour, press the H button and then the
pushbutton located under the forward arrow label.
Once the times 12H and 24H are displayed, press the
pushbutton located under the desired option to
select the default. Press the H button again to apply
the selected default, or let the screen time out.
With Date Display
Single CD (MP3) Player
time and date.
To set the time and date, follow these instructions:
1. Turn the radio on.
2. Press theHbutton and the HR, MIN, MM, DD,
YYYY (hour, minute, month, day, and year) displays.
3. Press the pushbutton located under any one of the
labels that you want to change. Every time the
pushbutton is pressed again, the time or the date if
selected, increases by one.
• Another way to increase the time or date, is to
press the right SEEK arrow or\FWD button.
• To decrease, press the left SEEK arrow or
sREV button. You can also turn the f (tune)
knob, located on the upper right side of the radio,
to adjust the selected setting.
The date does not automatically display. To see the
date press the H (clock) button while the radio is
on. The date with display times out after a few seconds
and goes back to the normal radio and time display.
Mar 15, 2010 | 2008 Chevrolet Impala
I have a philips dlp 55pl9773 has one red flashing led on the front when i do a hard reset tv boots up lamps lites led goes from flashing yellow to green for about ten seconds and then back to red flashing...
MY philips tv model number 55PL9773/17 WAS TURNING OFF THE SCREEN AND LEAVING THE AUDIO ON FOR ONE MINUTE. THEN THE YELLOW LIGHT STAYED ON. THEN THE LIGHT TURNED OFF. thEN I TURNED ON WITH THE REMOTE AND THE YELLOW LIGHT TURNED ON AND A FEW SECONDS LATER CHANGED TO THE GREEN LIGHT AND THE TV TURNED ON. AFTER A FEW MINUTES, BETWEEN 10 AND 30 IT DID THE SAME THING. NOW IT IS OFF WITH A BLINKING RED LIGHT PERMANENTLY ON. TO TURN IT OFF I HAVE TO UNPLUG IT FROM THE WALL. I REPLACE THE LAMP A FEW WEEKS AGO AND IT IS FINE.
Dec 01, 2009 | Philips 55PL9773 55" Rear Projection...
Panasonic VCR 7350 displays error messages and cant insert tape
There is either some damage to the mechanism or the mode switch is faulty. If you know what to look for taking the top cover off might show what part of the mechanism is damaged.
If it is the mode switch then it will need to be replaced. This can't be done without the service manual as the vcr needs to be set up. And they are never set up in the eject position.
Sep 27, 2017 | Panasonic AG-7350 VHS/S-VHS playback VCR
No record or playback
had the same problem, it seems to do fine without a tape in it :so I took the tape in and out a few times and I guess the alighnment was better so it works for Now..So Give it a try
Dec 12, 2008 | Panasonic Palmcorder PV-DV203 Mini DV...
C:31:22 FLASHING WITH THE YELLOW EJEXT ARROW FLASHING
I can play or record and it gives me the eject sign. At times it gives me the message 'cleaning casette'
Jun 13, 2008 | Sony Handycam DCR-TRV250E Digital...
Cannot playback recorded video
reel sensor is the problem of your camera... sometimes it is a poor connection of the sensor to the socket at the main board..clean the contact of the wiring using a pencil eraser and also check the pitch roller of the mechanical if it is install cause it might be loose at it post cause of the lock has been broken already...
Dec 06, 2007 | Sony Handycam CCD-TRV318 Camcorder
Cannot record
it is a reel sensor problem...try to adjust the contact of the sensor at the main board sometimes it is a poor connection or poor solder...
Aug 26, 2007 | Sony Handycam DCR-PC105 Mini DV Digital...
Sony handycam CCD-TRV43 troubleshooting
Some part in the cam is broken and i want to repair it. where should i go in Navi mumbai India?
Aug 08, 2006 | Sony Handycam CCD-TRV37 Camcorder
Sony Handycam DCR-TRV250E Digital Camcorder Logo
467 people viewed this question
Top Sony Video Cameras Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
