Question about KitchenAid (KSRD22FKST) Side by Side Refrigerator
Front wheel is broken - KitchenAid (KSRD22FKST) Side by Side Refrigerator
  • 4,066 Answers
The steering wheel no longer moves the front wheels to move the car
Year/make/model??? If the steering wheel turns but both front wheels don't, suspect internal rack and pinion/steering box failure or broken steering shaft u-joint or possible broken steering linkage. ( Pitman arm/ center link etc)
Feb 20, 2016 | Cars & Trucks
Loud noise when turning the Wheel on front passenger side of 2004 Pontiac grand am
check for failed wheel bearings
check for worn pads and faulty disc rotor
if front wheel drive -check for failed cv joints
Jul 14, 2015 | Pontiac Cars & Trucks
What causes rear wheels not to engage whether in 2 or 4 whhel drive? Front ones only turn when in 4x4.
If the shaft is powering out to rear end then internal on rear possibly broken differential. If no power from case to rear then broken in case.
May 31, 2015 | Cars & Trucks
Front wheel broken
I have seen seeral replacement type wheels on eBay.
Nov 14, 2013 | RC Thunder Tumbler Rc Car
My tracker pro's front wheels wont turn
It is likely that the steering linkage has broken or fallen off. Examine the steering linkage and see if it is moving when the wheel is turned. You may have a broken steering column as well.
Apr 22, 2012 | Craftsman Garden
Abs lit up on dash/ track control off/ resently repaired all brakes front and rear/ rear with new pads and rotors
most likely you have a bad wheel speed sensor or a broken wire to the wheel speed sensor. you will need it scanned to find out which sensor is acting up. if it is a broken wire it usually will be for a front wheel speed sensor from all the turning and it should be with in the first 6 inches or so from the sensor. to replace sensor you must replace front wheel bearing sensor assembly.
Sep 09, 2010 | 2004 Pontiac Grand Am
Broken wheel stud on the left front wheel-
Try spinning the hub around to different spots to see if you can wiggle it out.
Apr 08, 2010 | 1998 Honda Civic
My steering wheel is vibrating really bad and I can't turn the wheel
If you cannot turn the front wheels and the steering wheel was vibrating before then (since I assume that the car is undrivable now), then your car most likely has broken/damaged tie rod: check if the front wheels wobbles.
A less common problem is the actual steering/wheel rack-pinion gearing mechansim is broken and it is indicated by not being able to move both the front wheels together.
In both case, you need specialist repair.
Hope it helps.
Jan 28, 2010 | 2007 Lexus IS 350
GRACO STROLLER FRONT WHEEL BROKEN
I have the same problem, the airline broke ours the last time we flew. I just found on Graco's website that you can order replacement parts. Here is the link, http://www.gracobaby.com/store/order/default.asp?N=10418+10413+10421&Ne=11
You'll need the model number and serial number. I found ours on a sticker under the footrest. For our stroller it's $19 plus shipping for the front wheel assembly.
Hope this helps.
Jan 13, 2008 | Baby Gear
KitchenAid (KSRD22FKST) Side by Side Refrigerator Logo
75 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Todd Arndt
Todd Arndt
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
