We just replaced the ink cartridges on our HP 7280 all-in-one and it will not print anything.
4 Suggested Answers
  • 235 Answers
SOURCE: HP C 7280 printer states ink jet failure
have your printer head check it is most likely the one causing these problems, if you have already replace it with a new cartridge and have reset the machine then it is likely the problem have it check by a qaulified tech to avoid any more damage to the machine
Posted on Nov 21, 2009
bob_computer
  • 3153 Answers
SOURCE: Just replaced the black ink cartridge on the HP
Take a look at my tip on cartridges it may save you a lot of time and money
http://www.fixya.com/support/r3845491-ink_cartridge
OR
Read on and see if any applies to you.
Check that you removed the protective tape. some cartridges have two of these pieces of tape one over the head and possibly on on the contacts to the printer.
If you recently re-filled or had the cartridge refilled or even bought one of the many cheaper replacement cartridges you should read on
Most modern cartridges have an ink level chip built on to them.
Should the level drop below 25% then most of these chips lock up and will not reset.
Re-filling them will have no effect
If you are lucky you should be able to find either a
chip resetter around on the INTERNET or maybe even local
OR
Even better empty cartridges that
never need to be reset.
The second option is my preference
I realise these are not for your specific printer but there are others listed on both those sites as well.
cheaper cartridge problems have been on the rise recently and that is for ALL makes of printer.
If you try to clean the contacts be VERY careful cleaning contacts and ONLY use isopropynol on a lint free bud or cloth.
Also be very gentle.
I have seen the contacts cleaned and cartridges ruined with other methods of cleaning.
Rubbing too hard can also cause a badly set chip to move making it inoprable.
I dont like full prices replacements either which is why I always provide the links
I usually reccomend that people take back any cartridge that does not work right from the get-go.
I dont know of anyone who has had a problem doing that be it a shop refill or otherwise.
No matter if I paid $1 or $100 for a cartrdige I would still expect it to work
Hope this gives you the information you need
Bob
EXMod
It would be very decent of you to consider the quality of our experts answers and judge them accordingly as you pass through FixYa.
Thank you
Posted on Jan 14, 2010
  • 1218 Answers
SOURCE: Hp 7280 all in one.
Mostly, printer cartridge error occurs when the printer head is unable to identify the cartridge properly. And the basic reason behind this is that the cartridge is improperly attached. To reattach the cartridge, turn on the lid of the printer and then remove the cartridge from the printer head. Check the cartridge to make sure that there are no scratches or other damaged parts that can contribute to a printer cartridge error report. Take note that the cartridge should not be left open for more than 30 minutes; otherwise the ink will start to dry up and the cartridge will get clogged.
Posted on Jan 18, 2011
Hp 2540 deskjet. Just replaced BOTH cartridges with genuine HP ink 60. Printer still flashes on the cartridges being empty. Error message. I cannot print anything. I can scan but that is all.
Per HP: After installing a new print cartridge, a message appears on the front panel that the print cartridge is low on ink. This may be caused by installing the cartridges with the power turned off. Cartridges should always be installed with the power turned on.
Found the following directions online:
How to Replace an Empty Ink Cartridge in the HP Deskjet 2540 All in One...
May 20, 2016 | HP Office Equipment & Supplies
What does ink threshold exceeded mean?
Sad to say I know how to fix this.
1. Power up the printer
2. set printer's date to the current day.
3. On the keypad press the * and # keys together
Now press one at a time 1,2,3 for the code
"screen stould display a white backround with 2 lines of info"
4. remove all the print cartridges
5. Press the >> arrow button twice until "reset menu" is found
6. Press OK
7. Select Partially full reset Press ok
( the printer will take almost to minutes before it powers down)
8. Power up the printer and follow the steps.
reinstall ink ect......
I don't know why this happens but I sure a lot of printers are in the trash because of this. If you print out a SELF TEST REPORT the
dates on the age of the ink Cartridges are likely out of life range.
Planned obsolescence by HP can be found all over the web. This could be one of those.
HP Photosmart 3000 C6100 C7200 PSC 7280 Printers HP 02 Cartridge...
Press the helpfull Thanks!!!!
May 01, 2014 | HP PhotoSmart Office Equipment & Supplies
Ink threshold exceeded
6. Press OK
Feb 04, 2014 | PrintCountry HP Photosmart C6280 Inkjet...
6. Press OK
Aug 21, 2013 | HP Photosmart 3310 Printer
Error: Ink Threshold Exceeded
6. Press OK
Sep 25, 2012 | HP Photosmart C7280 All-in-One Printer
6. Press OK
Sep 25, 2012 | HP Photosmart C7280 Printer
Hp 7280 all in one. Magenta ink (all new) does not work. Test print shows good cartridges and plenty of ink.
Jan 18, 2011 | HP Photosmart C7280 Printer
HP C 7280 printer states ink jet failure. I have tried resetting machine, resetting the ink cartridges, and holding # 6 down on start up. I have replaced all low ink cartridges.
Nov 21, 2009 | HP Photosmart C7280 Printer
Ink failure
put ink cartridges in the printer
Jul 20, 2017 | HP Photosmart C7280 Laser Printer
My printer is printing photos in red.
Change the INK reset the printer get the right driver's and recalibrate the printer. that will do the tricki i had these problem before     http://welcome.hp.com/country/us/en/support.html
Jan 16, 2009 | HP Photosmart C6180 All-In-One InkJet...
73 people viewed this question
jasbo
jasbo
