Question about Sony RCD-W500C 5-Disc CD Recorder
I get a data disc message when press record
Wont record cd-rw
  • 77 Answers
Try to record on cd-r only. maybe it only works on recordable format not on rewritable format
Posted on Sep 10, 2009
Placing good cd-r disc for recording shows "insert
u mabe inserting the wrong disc all phillips cd recorders uses cd-r or cd-rw that says digital audio.
Jul 28, 2011 | Philips CDR785 3-Disc CD Recorder
How to copy anything else on finalised DVD or - to HDD on samsung HR 755
If the disk is finalized you can't normally write anything else.
The words "Finalizing" and "Closing" are used interchangeably by most recording applications. To "Finalize" or "Close" a disc means that no additional data can be written to it. This is done when the last session's lead-in is written. The option to close a disc is usually selected after all of the data that will be written has been placed in the project window, and the user knows that no more data will be added to the disc in subsequent recording sessions. The next writable address on the disc is not recorded in that lead-in, so the CD recorder, in subsequent attempts to write, has no way of knowing where to begin writing.
Mar 09, 2008 | Televison & Video
Does the unit recognize 80 minute discs?
Any desk CD recorder will only recognize discs labeled "Audio Disc".
That means you cannot use CD-R or CD-RW discs, that are basically data discs. No matter duration, if your 80 minute disc is CD-R or CD-RW, your unit will not recognize it. Good Luck.
Flavio/BRAZIL
Jul 25, 2010 | Philips CDR778 2-Disc CD Recorder
Sony RCD-500C I get a data disc message when pressing record
It wants a CD-R Audio or CD-R Music blank disc to record on. It won't record on CD-R data discs.
Feb 28, 2010 | Sony RCD-W500C 5-Disc CD Recorder
Computer does not recognize it as a CD RW drive
When you try to write data to an optical disc, you may experience any of the following symptoms:
* You receive various disc write error messages.
* You experience issues with the drive and the built-in recording feature of Windows XP.
* You experience issues with third-party programs that you use to write data to the disc.
* You cannot read the disc in all versions of Windows.
* You cannot read the disc, or some files on the disk, by using an MP3 player.
* When you add files or folders to a disc that already contains data, some files are lost.
* Recording files to the disc is inconsistent.
* The disc recording operation is consistently unsuccessful.
TROUBLESHOOTING
Troubleshooting specific errors
If you experience one of the following errors, follow the appropriate steps to resolve the error.
* There is no disc in the drive. Please insert a writable CD into drive.
This error can occur if the CD-R drive or CD-RW drive is not recognized as a recordable device. This error can also occur if the device driver has been corrupted. To resolve this issue, see Method 3 in the "General troubleshooting" section and Method 1 in the "Advanced troubleshooting" section.
* Drive not accessible, incorrect function
This error message typically occurs when you try to write to a CD-R or a CD-RW, and the Windows XP built-in disc recording feature does not recognize the CD drive as a recordable drive. This error message may also occur if specific third-party programs are installed. For more information about how to troubleshoot this error,
when you access the CD-ROM drive, the DVD-ROM drive, or the CD-RW drive
* Error Deleting File or Folder.
Cannot delete file name. Files on this CD-ROM drive are read-only. You cannot copy or move files over to this CD-ROM drive.
This error message can occur because individual files cannot be deleted from the CD-RW. You cannot use the CD disc recording feature of Windows XP for random-access storage while you are writing to disc.
To set the service to Automatic, follow these steps:
1. Click Start, click Run, type services.msc /s, and then click OK.
2. Double-click IMAPI CD-Burning COM Service.
3. Under Service Status, click Start.
4. Try to write data to a CD.
Jan 28, 2010 | Samsung (SH-M522C/BEBN) CD-RW/DVD-ROM...
Sony RCD-500C I get a data disc message when pressing record.
You need to use CD-R Music or Audio blanks, not Data. It's part of the spec for home CD recorders to reject blank data disks.
Jan 25, 2010 | Sony RCD-W500C 5-Disc CD Recorder
I get a "Data Disc" message when I press record.
have you purchased the correct blank discs? sounds like you've inserted discs that can only be used on a PC. these players can only record onto blanks bearing the "compact disc digital audio" mark. these are for use on home audio recorders. hope this helps?
May 02, 2009 | Sony RCD-W500C 5-Disc CD Recorder
Won't record record to CD-RW
First make sure your cdrw disc is blank. If it is blank try another good known cdrw brand disc and burn it in 12x speed for a good burn.
If it still fail check the software side of your cd rewriter first and lastly the cd rewriter unit.
Mar 28, 2009 | Crosley 4-in-1 Entertainer CD Shelf System
Can't get it to record
I experienced this problem a long time ago, i believe that it was because i tried to use a normal data cd-rw but the unit only reads audio discs. It has to be a cd-rw for audio only (will say cd-rw audio on the disc, whereas if it is a data disc it will simply say cd-rw.) Hope this helps..
Mar 13, 2009 | Pioneer PD-R509 CD Recorder
Wont record on blank pc disks!
I had the same problem and found that I was using the wrong type of CDs. If you look on the CD you have to use the CD that says Compact disc digital audio Recordable or Compact disc digital audio Rewrittable. After I used the Digital ones I could record on it. I then tried the CD on the PC and it worked. You can look on the top of the unit and see the information if you still have it. Hope this helps you.
Feb 23, 2009 | Pioneer PD-RW839 4-Disc CD Recorder
Sony RCD-W500C 5-Disc CD Recorder Logo
175 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
