Question about Poulan Wild Thing 2375 18" Gas Chain Saw 2.5 Cuin
Poulan Wild thing 2375 will not stay running
The thing seams like it is running rich and bogs out I cannot keep it running for more than five seconds at a time. I have tried the H/L 1-1/4 and 1-1/2 turns from limit, but what is the "T" screw and where should it be?
  • Poulan Master
  • 3,519 Answers
Try checking the muffler. Some models have a screen that will get clogged with carbon and the saw won't keep running. Clean the screen with a wire brush.
Posted on Sep 10, 2009
How do I adjust the carburator on a poulan wild thing 2375 chain saw that bogs down when cutting and is hard to start?
there are two screws on the carb start by turning them all the way in then 3 full turns out and then make half turn adjustments until you get it right..
Aug 06, 2014 | Poulan Garden
What causes the chainsaw to bog down and chain to stop when under light load
check chain is sharp oiled and tension is not too tight.if sawis old check engine compression is not low.
May 21, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
My poulan wild thing 2375 bogs out when throttle
Make sure that the air cleaner and muffler are not plugged. Check the carburetor screws and nuts for tightness. After turning both needles CW to stops (lightly), back them out CCW 1-1/2 turns each. Start the engine and allow to warm up. Open the throttle and adjust the H needle CW somewhat until the engine speeds up, but is 4-stroking. Correct adjustment is when the engine 4-strokes, but immediately 2-strokes when cutting. Release the throttle and adjust L CW till the engine runs fairly smoothly, but allows the engine to 'follow the throttle'. Set the idle speed screw so that the chain doesn't turn, but the engine keeps running. Hope this helps!
Apr 15, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
I have a new wild thing poulan chainsaw that idles ok but bogs down when giving it gas ..it has good fuel
make sure your using high octane (no ethunal) and fresh oil mix no older than 6 mouth (oil mix) if it st-ell happens try to adjust the high side with it at full throttle un tell it smooths out. good luck
Oct 13, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
My pulan wil thing is dieing after I cut through a
MIne was doing the same thing. I cleaned the sponge air filter. That helped but then I poured some combustion chamber cleaner into the carb and that solved it. Now it would idle all day if I let it.
Always measure oil mixture carefully. These saws are fussy and don't like too rich an oil mixture!
Hope this helps!
Rob
Sep 22, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Poulan woodshark 1950 gas to oil ratio
Thats and old saw, you have to run those very rich usually 20:1
Aug 12, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
My chain keeps binding up, i get it back on, start running my wild thing and with in 10 seconds it binds up
Try putting a new bar on it. Sometimes during use the grove in the bar gets a kink in it. This will cause the chain not to move like it should. Also, the sprocket at the end of the bar can go bad also causing a malfunction.
Best bet!!!!!! Buy a new bar...
Aug 04, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
McCulloch chain saw wont stay running after it warms up. I go to cut wood it start to bog down if i let go of the button it idles fine
Is the chain brake engaged? The brake lever should be in the back position. Toward the handle.
was this helpful?
yes
no
Mar 23, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Gas Oil Mixture
USE 50 TO 1 RATIO BETTER MORE OIL THAN LESS WORST OUT COME A BIT MORE SMOKE RATHER THAN SEIZURE
Nov 15, 2008 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Poulan Wild Thing 2375 18" Gas Chain Saw 2.5 Cuin Logo
510 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
