Question about Maytag PAV2300 Top Load Washer
The water valves didn't shut off. the washer over flowed. when i changed the cycle the vaslves shut off and the pump empties the washer. when i start a fill cycle, the washer over flows
  • 530 Answers
If you turn the timer off does the water stop? IF yes you have a bad pressure switch or possibly the hose that goes to the pressure switch is disconnected or has a hole in it. If the water keeps entering the washer with the timer turned off you have a bad fill valve.
Posted on Sep 10, 2009
    President:
  • 1,776 Answers
Check for a faulty water level switch. It's a diaphragm-like device with a small plastic tube attached between the switch and the bottom of the washer's outer tub. As the water level increases, so does the pressure on the air in the tube and when it reaches a certain level, it activates the switch to shut off the water and signals the timer to start the appropriate cycle. Check for any obstructions in or damage to the plastic tube. The switch can be tested using a multimeter or ohmmeter. Check for continuity. A lack of continuity means a bad switch. Sorry for your trouble and I hope this helped. Best wishes.
Whirlpool awm 8125 fault code F09 followed by FA
The drain pump runs constantly in an effort to drain the water. Unplug the washer and, if the washer is overfilled, check the water inlet valve assembly for proper shut-off of water flow. If the water inlet valve assembly is defective, replace it. If the washer is empty when this error code appears, replace the water-level pressure switch.
Dec 16, 2013 | Whirlpool AWM8143 Front Load Washer
Kenmore 800 modle washer does not fill or agitate
It is possible that the machine does not start off the cycle because there are errors due to feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting from the flow of water into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
If the water flows though the inlet then the flow pressure should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
Test a pressure switch: Click on : http://www.youtube.com/watch?v=HZZ2bDMspj8
Check this link to replace the inlet valve:
http://www.espares.co.uk/advice/washing-machines/a/7/1408/how-to-replace-the-inlet-valve-on-a-washer-dr.html
Feb 12, 2013 | Kenmore 24032\24036 Top Load Washer
Washing machine over fills with water
Jan 21, 2013 | Washing Machines
Washer stops mid cycle
Finally after the wash the drain valve will be activated, the water is allowed to come in to rinse and then finally the dry spin with the drain valve/pump activated so as to drain off all the water from the clothes during the spin.
Make sure that a fault in any of the cycle will relate to the specified action, so check the command from the program module and then the executing device be it the valve or motor or pump.
Please check the link below:
http://www.repairclinic.com/Washing-Machine-Troubleshooting?red=Washing-Machine-Repair-Help
Jan 19, 2013 | Kenmore Washing Machines
Washer won't agitate in wash cycle
Jan 19, 2013 | GE Profile WPRE6100G Top Load Washer
Washer won't drain or run thru any cycles.
Jan 14, 2013 | GE WSXH208A Front Load Washer
Samsung Model WF317AAS/XAA seems to be having problem with the board. I changed the drain pump, the pump is fine but when I put on a full cycle it do not complete. It stops at Rinse and then a nd code...
It ispossible that the machine does not start off the cycle because there are errorsdue to feedback from the inputs. For the program to start up the main programcontroller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting fromthe flow of water into the drum as also the drain valve to open to exit thewater at the point of the program cycle. If this does not happen then thevoltage at the valve/motor/pump must be checked or the fault relates to novoltage from the controller. This meansthe controller is a suspect.If thewater flows though the inlet then the flow pressure should be good, if not theinlet valve is bad or there is dirt in the filter. Also check the flow at theinlet of the water line. Once the water comes into the system the WATER LEVELSENSOR - normally a pressure switch- must activate at the preset/chosen levelto give the signal to the program controller to switch on the motor. What ismost important for the motor to start functioning is that the door switch mustbe ON when the door is shut or this will be an error for starting the motor forrinse and wash.Check thislink to replace the inlet valve:http://www.espares.co.uk/advice/washing-machines/a/7/1408/how-to-replace-the-inlet-valve-on-a-washer-dr.html
Jul 26, 2012 | Samsung WF337AA Front Load Washer
We had the problem where the washer would not empty all of the water but now that problem has been fixed THANKS TO ALL YOUR HELP cleaning the pump worked great!!!!! now I have another problem the washer...
Thedoor switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
Jul 02, 2012 | Frigidaire Affinity ATF6000F Front Load...
I have a Whrilpool washer model LHW0050PQ 2. It will work perfectly then will not spin. At the end of the cycle the done light just flashes. If I choose to just choose spin cycle you will hear it go...
This is almost certainly a simple problem with your empty pump filter being clogged. The empty cycle is timed and if it can't get all the water out in time because the filter is blocked and slowing the empty down, then it will fail safe and won't step on to the final spin cycle with excess water in the drum.
Locate and clean the filter. There is a round unscrewable filter cover on the front of the machine at the bottom right, behind a small door. Many models of this design also have a small hose to the right of the filter cap that you can pull out, remove a plug from and drain off any water in the filter before you remove the filter its self and get your floor wet, so take a look for this before you remove the filter and get soaked.
If this IS the case, you need to call the repair guy out again and when he gets there, kick him all round the house until he gives you a refund foe his last 2 visits!
Jul 11, 2011 | Whirlpool Washing Machines
Water flowing back into washer after wash
There is a back flow valve attached to the outlet port of the drain pump. It is just a small rubber flap. This sometimes comes loose or remains open due to debris and allows the water in the drain hose to flow back into the machine after the drain pump shuts off. It can be checked by removing the drain hose from the pump inside of the machine. You will lose all of the water in your machine (about 1/2 gallon)when you do this so be prepared with a bunch of towels.
Feb 14, 2007 | Whirlpool GHW9100L Front Load Washer
Maytag PAV2300 Top Load Washer Logo
83 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
