My pump is blocked on my simpson eziset 450 washing machine
  • 15,935 Answers
Remove the hoses and check it out. Many times the obstruction can be cleared.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 18, 2010
2 Suggested Answers
  • 6277 Answers
SOURCE: Hi guys... I've a Simpson eziset 450 top load
As far as I am aware most washers have a filter, top loaders tend to be at the back, bad design in my opinion!
Following are my complete and hopefully 'coverall' pre-typed guidance notes for checking both the drain motor filter and the drain motor ;-0)
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as sensibly suggested by VinnyB1234!)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on Sep 04, 2011
Testimonial: "I try this solution - thanks heaps"
Simpson washing machine
you need a 10mm socket and some extensions and a ratchet take the fabric softer filter out and undo the ,bolt at the bottom of the agitator and lift out
May 28, 2017 | Simpson Washing Machines
Simpson eziset still eont dtain aftet nee pump installed
You need to confirm that power is getting to the pump, these machines can get broken wires between the control panel and the pump, usually half way up the inside of the cabinet.
Jun 13, 2016 | Simpson Washing Machines
My Simpson eziset 950 keeps coming up with error HC.
No water flowing in to machine. Check taps are fully open & filters on end of hoses are clean & not blocked. If all good then you probably have a faulty inlet valve.
Dec 14, 2015 | Simpson Washing Machines
Simpson EziSet 750 washing machine won't drain the water. please help me.
Lid switch faulty, pump blocked, outlet filter blocked (If fitted), pump needs replacing.
Dec 19, 2013 | Washing Machines
My simpson eziset 7.5 washing maching does not hold water
Be sure that the drain line is above tub level.
Dec 04, 2012 | Simpson Washing Machines
I have a Simpson Eziset 550 washing machine and it does not fill with water at the start of a wash - instead it will start to fill then stop and all three lights on the water temp gauge light up and start...
When mine had all 3 water temp lights blinking, it was a blocked pump, I emptied the washer, tilted it back, disconnected the hose from the pump (you will need towels) and clear out the pump, then put the hose back on.
Nov 01, 2010 | Washing Machines
Simpson eziset 750 manual
Hi our eziset 750 simpson washing machine has stopped working. It randomly just turns off and then will start again few days later. Cheers
Aug 28, 2010 | Washing Machines
Simpson eziset 450
It sounds like the drum is so away from level that water is not flowing to the drain line, hence the pump running out of water. I would make sure the machine is level and the drum is resting level if it's the type that pivots around inside the machine. Failing that I would open up the machine and check the hoses to make sure they're not blocked. I would also check the drain hose to make sure it's not placed too high or in a way that will obstruct water flow.
Oct 19, 2009 | Washing Machines
Washing Machines Logo
267 people viewed this question
Top Washing Machines Experts
