Question about Sharp Aquos LC-42D62U 42 in. LCD HDTV
Trying to hook my roku box to my sharp aquos 46 in using my hdmi
The tv will not reconize it in input
  • Anonymous Mar 23, 2014
    Want to use my Roku 3 without using a major credit card. Do not want to set up account rite now. Just want the free channels.
According to roku support hdmi won't work with the aquos as of today (1/6/2010). i have no idea if it's an hdcp issue or not
Posted on Jan 07, 2010
My sharp aquos TV Guide 46" model won't pick up hdmi connection from the cable box. I already tried changing the cables with no change. Any suggestions
Have you tried a different HDMI input on the TV? Are you sure you've selected the correct HDMI input? Make sure there are no component cables connected to the cable box. Occasionally that will disable the HDMI output.
Nov 19, 2014 | Sharp Aquos Televison & Video
I have a Sharp LC-42D62U and have our DVR from cable connected to HDMI #4. I want to hook up a Roku via HDMI to HDMI #5 but the input source shows unavailable sign. Is there a way to get both HDMI...
If your Tv has this many HDMI ports it will have a menu to access each one separate. Go to your Tv's settings menu and look for your HDMI ports to use.
Jul 30, 2011 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Television is not recognizing HDMI inputs
there is a possibility that there might have been a power surge sent over hdmi into the hdmi board on the tv. if on your model the hdmi board is seperate from the sine board then youll have a cheap replacement if not its gonna cost you roughly 300-400 is my guess.
call your repair guy
Aug 02, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Sharp Aquos 46" HDMI problem
I have a similar problem. The Sharp TV aquos appears to be shutting down my blue ray player and dvd recorder when connected via HDMI. They work fine and never close down when I connect them via the rca cables either single video connection or a composite 3 cable rca lead. I have 3 HDMI inputs on the tv and the problem occurs on all 3. Any suggestions?
Jun 16, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Close captioning on HDMI
The TV will not display closed caption with HDMI input. It must either over-the-air (antenna) or composite input for the TV to manage CC.
To get CC with HDMI from your Comcast DVR, you need to configure the cable box. Instructions can be found here:
http://en.wikibooks.org/wiki/How_to_use_a_Motorola_DVR/Setup
If you want CC all of the time, this works well. But since you must power-off the cable box to change the setting, switching CC on and off is a real pain.
Your set-up is similar to mine (Sharp Aquos 46" and Comcast DVR). I have the composite output from the cable box going to a DVD-recorder and on to the TV. Whenever I need CC (usually to catch some mumbled dialog), I just rewind the DVR, and switch the TV input to the composite input. Then I switch back to HDMI to continue watching in HD.
Mar 09, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Cannot get a connection with HDMI input
When the tv won't scroll to the HDMI inputs, it means that the tv does not detect a signal on those inputs. This either means the tv has an issue and can't receive an HDMI signal(very unlikely) or there is no signal being sent from the source(converter box) The first thing I would do is unplug all output connections from the box except for the HDMI output and see if this gets rid of your problem. If not, I would be more inclined to think you have a problem with your converter box than with your TV. You could also try using the HDMI ouput of a DVD player if you have one.
Jan 14, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
New Sharp Aquos LCD 46 TV
If you hooked up the satelite box to your tv Automaticly the Satelite box is the one who pick up the channels (from the satelite)
In this case your tv is acting as a monitor only. Try to connect your tv with HDMI cable or COMPONENT cable for best picture. Don't use RF antenna input to hook up your Satelite Box. Hope this Helps
J
Dec 28, 2008 | Sharp AQUOS 52" Flat-Panel LCD HDTV
My Sharp Aquos 46" LCD
Digital inputs on Aquos TV's are "always on," usually the HDMI inputs and DVI inputs. As opposed to analog inputs 1, 2, or 3, are only activated once something is plugged in.
Try plugging in another HDMI sources into input4 or 5, if its still not working, the TV needs a new Main Board. Try calling Sharp 1-800-237-4277 and locating a local service center in your area.
Mar 14, 2008 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Setting up sharp 46
Try to isolate the problem.
Try plugging in another source such as a DVD, is there audio? If yes, problem may be with the optimum box. If no, most likely a problem with the TV.
Also, if you are using HDMI with the HDTV box, make sure the box is set to output audio through HDMI.
Feb 10, 2008 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Sharp Aquos LC-42D62U 42 in. LCD HDTV Logo
1,164 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
