All the lights are on, the yellow and the orange square all dicontinued.And the cartrige orange ligths are solid. what's going on?? help!! please
  • 1 more comment
  • keishajoyce Sep 10, 2009
    hp deskjet 460 mobile printer
    HP DESKJET 460 mobile printer
  • jeffrey celi
    jeffrey celi May 11, 2010
    whats your printer??
How do you know the temperature heater is running at when set on light orange 1st or 2nd square
The only way to tell is to use a thermometer as the outlet heat is based upon the surounding air temperature.
Aug 02, 2014 | Rinnai EnergySaver ES38 Gas Fired Direct...
Hello, my dir 600 Only it lights orange light of ignition, only ligths orange power . help me please.
even its the same for me i tried reseting it.. nothing worked out, i called customer care, they requested me to take it to near by service center.
Sep 05, 2010 | D-Link DIR-600 Router
I need to know the pin outs on the wiring harness for brake light,running light and turn signals.
Orange/white = Switched 12 VDC (tail light)
Red/yellow = Stop light
Solid brown = Right turn signal power/signal
Solid purple = Left turn signnal power/signal
Solid black = Ground
Aug 08, 2010 | 2004 Harley Davidson FLSTC - FLSTCI...
My orange light next to the yellow dot blinking and the printer will not print
When the orange light is solid it means the cartridge is low and you can still print. But when the orange light is flashing it means the cartridge is empty and the printer stops printing. To continue printing you will need to replace the yellow toner cartridge. The part numbers are Q3972 regular yield or Q3962A high yield.
Jun 23, 2010 | HP LaserJet 2550n Printer
Inspiron 1200 battery light continually flashing orange
If your battery LED flashes or is solid Yellow or Amber color, this usually indicates battery is beginning to go bad. Eventually it will not hold a charge and will need to be replaced.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Jan 18, 2009 | Dell Inspiron 1200 14.1 XGA LCD...
1995 Ford Windstar Speaker Coding Scheme.
www.installer.com as speaker schematics
Dec 22, 2008 | 1995 Ford Windstar
Xbox360
Orange or Yellow Indicator Light
When the Xbox 360 power supply light is orange or yellow this means there is no problem with your console but the power supply can't supply it with power.
To remedy this problem, first try unplugging the Xbox 360 power supply from the console and unplug the power cord from the wall outlet. You'll also want to uplug the Xbox 360 power supply from the power cord.
Wait for about five minutes and then reconnect everything. You might also want to try plugging it into another wall outlet without an extension cord.
If you are still getting an orange or yellow indicator light, then something is at fault with the Xbox 360 power supply. If this is the case, contact the Xbox 360 customer support to get a new one
Sep 06, 2008 | Microsoft Xbox 360 Console
Error 5C00 on Canon iP90
i took out both printer cartriges then put them back in. there was a window that asks if you replaced the cartriges; click yes then click on the black and color boxes indicating you replaced (re-inserted) both cartriges. for me the light stopped blinking (previously, it was blinking orange 4 times). next i tried to print but only yellow and black appeared. i then cleaned the head 2 times.
to clean:
-go to control panel
-click on printers
-click on printers and faxes
-find your printer, right click on it
-click properties
-find the maintenance tab
-click cleaning
(clean a couple of times if needed)
hopefully it works...
Jan 28, 2008 | Canon PIXMA iP90 Mobile Printer
Solid cooktop elements not heating,tripping breaker switch in panel box,w&w/o cartridges
By cartriges do you mean the sockets that the element plug into? If so when one of these burn out it will cause these type of problems.
Jan 15, 2008 | Cooktops
Toner light
NEWER MODLES HAVE A CARTRIGE ESTIMATING PROGRAM THAT NEEDS RESET (you need to tell the printer that it has a new cartrige). SIMPLY....
1. OPEN THE FRONT COVER.
2. TURN OFF.
3. HOLD DOWN THE GO BUTTON AND TURN BACK ON.
4. ONCE ALL 3 LIGHTS ARE SOLID, LET GO OF THE BUTTON & PRESS IT 2 TIMES RIGHT AWAY.
5. ALL LIGHTS SHOULD GO SOLID AGAIN, WHEN THEY DO PRESS THE GO BUTTEN 5 TIMES IN A ROW.
THIS SHOULD RESET YOUR PRINTER AND LET IT KNOW IT HAS A NEW CARTRIGE (even if it doesn't)!
Aug 26, 2007 | Brother HL-2040 Laser Printer
41 people viewed this question
k24674
jasbo
jasbo
