DVD freezes up
DVD's freeze up after short playing time. I can forward but problem continues. I have tried several DVD's so that's not the problem. I've seen numerous complaints but no solutions.
  • midhungbabu May 11, 2010
    indian dance pictures
  • Televison & ... Master
  • 2,005 Answers
Slide out the DVD tray and, clean the laser with rubbing alcohol let dry
Posted on Sep 10, 2009
Testimonial: "Like new ! Thanks for the advice."
My panasonic dmr-ez48v freezes intermittantly when playing dvd's.
perhaps broken gear that moves the laser CARRIAGE contact avsystemparts.com
Feb 25, 2013 | Panasonic DMR-EZ485VK DVD Recorder/VCR
It freezes while playing dvd's about every ten minutes. It does allow you to skip forward and continue playing but makes you skip an entire chapter. What causes it to freeze?
Mt SD-1800 does the same thing, plays for awhile and then gets stuck. I took it apart and cleaned the rails and the optical lens but no help. I noticed that the head did not slide back and forth without cogging. It turns out that the little pinion gear on the motor was cracked. Every revolution it would catch on the tooth by the crack. I doubt that there are replacement parts available.
Sep 10, 2011 | Toshiba SD-1800 DVD Player
I HAVE A LG HT506 DVD PLAYER AND WHEN I PLAY ANY DVD IT PLAYS FOR A SHORT TIME THEN THE PICTURE FREEZES . IF I LEAVE IT FOR A SHORT WHILE IT STARTS PLAYING AGAIN THEN FREEZES ONCE AGAIN CAN YOU HELP...
By your description it sounds like the DVD player needs to be cleaned. You can purchase a CD/DVD cleaner at most places like Walmart, Target, or Radio Shack.
Try cleaning it first. If that doesn't work, it will probably have to be repaired by a professional, if it's not under warranty.
Jul 13, 2011 | LG HT503TH Theater System
Dear Sirs, Recently, my Sharp dvd-video combi player has been encountering some problems regarding the playing of dvd's. When I watch a movie, in several occasions the movie will freeze up. And for...
the DVD unit in your sharp is a self contained unit. IT is only repaired by replacing the DVD as a assembly. the cost of replacing may exceed the cost of purchasing a new one.
The most likely cause of your problem is in the brass gear assy that runs the optical pick up in the traverse deck. IT is not an available part.
Feb 17, 2011 | Televison & Video
DVD will play for a short time and then freeze.
Get VLC
Then try and playback the dvd , also check on the dvd to see if there are any scratch marks or dirty marks ie finger prints etc , if there is , obviously clean the disc, if not get a disc cleaner for your dvd drive / dvd player and then try again afterwards.
Also try a different dvd and see if that makes any difference
Apr 27, 2009 | Televison & Video
DVD deterioration
I would blame it on the DVD player. They are fickle when it comes to playing burned discs. Try playing the disc in your computer. If does the same thing there, the disc is garbage. You can also try burning at a slower speed, sometimes this helps. I would also try to avoid using DL (dual-layer) discs.
Apr 09, 2017 | Televison & Video
DVD video player problem
your laser is getting weaker now, if you have thoroughly cleaned then it needs a replacement now.
Apr 29, 2008 | Samsung DVD-V4600 DVD Player/VCR
Won't complete finalizing
SAME PROBLEM AND IVE TRIED ALL TYPES AND BRANDS OF DVDS. IM RETURNING MY P.O.S. , DONT WASTE ANY MORE OF YOUR TIME OFF FOOLING WITH IT
Sep 03, 2007 | RCA DRC8335
Portable DVD player
Its sounds like cpu/memory problem. the laptop can't play dvd while doing other things. Try to play dvd while all other application are close, if it doesn't freeze its a cpu/memory problem (inwhich case why should try to buy more memory)
Mar 12, 2007 | Mintek MDP-1810 Portable DVD Player
DVD player freezes
If it's a very cheap unit, it's possibly because the machine can't process the information quickly or efficiently enough, thusly causing the picture to freeze up while the processing catches up with it. Friend has a $30 unit, which happens to constantly.
Nov 07, 2006 | Sanyo DVW-6000 DVD Player/VCR
Televison & Video Logo
48 people viewed this question
Top Televison & Video Experts
