Question about Maytag MSD2655HE Side by Side Refrigerator
Must change reservoir . . .
. . .as there is contamination.
Bought the new reservoir, which includes tubing. Anyone know how difficult it is to r5eplace the reservoir and tubing?
  • 725 Answers
Just replace the whole reservoir and the coiled tubing is now the reservoir. It isn't difficult at all to run the water line through the unit and lay the coiled tubing inside the unit. Hope this solves your problems.
Posted on Sep 10, 2009
How do you change power steering fluid on 1994 toyota pickup DLX with 4 cyl. engine
Should have done it when you had everything unhooked.
Rather than disconnect the hoses I use the trigger unit from a plastic spray bottle to pump the fluid out of the PS reservoir. Just unscrew the spray tip on the trigger unit, drop the tube section into the PS reservoir and pump out the old fluid into a container using the trigger. (If the plastic tube has a tiny filter on the end just cut it off before you insert it.) Then refill the reservoir and take the car for a short drive to circulate the new fluid. Then do it again. Empty and refill.
In a few days or a week, repeat the process (2 more empty and refills)and you will end up with nice new fluid in the system. If you like do it a 5th time in a week or so (1 more empty and fill) but at that stage you should find you are pumping pretty clean fluid out.
Not the most efficient system but it is very easy to do, takes little time and you do not need to go disconnecting pump lines which I would rather no do..
I do it this way on all my own cars every few years because it is easy, clean and works well and keeping the fluid clean and fresh means less wear on the pump due to contaminants and fluid deterioration.
If you get air in the system because you run the fluid level below where the lines fit to the reservoir don't worry. The air will be removed when you drive the car and turn the steering wheel back and forth. I don't run the fluid below the line connection when I remove old fluid from the reservoir.
Feb 28, 2015 | 1994 Toyota Pickup
My 92 wrangler is spewing oil up through the dipstick tube, does anyone know why this is occuring
sounds like a head gasket problem....is your anti-freeze reservoir pressuring up as well?
Apr 08, 2014 | 1992 Jeep Wrangler
Heater core replacement on a 1994 astro van
1 Drain the van's engine coolant. With the engine cool and the parking brake applied, remove the radiator cap, place a large container under the radiator drain and remove the drain fitting. After draining the coolant at the radiator, move the container to the engine block and remove its drain plug to drain the remaining coolant.
2 Remove the coolant reservoir by disconnecting the overflow hose from the radiator filler neck, removing the fasteners for this reservoir and the windshield washer fluid reservoir, lifting both up and separating the coolant reservoir from the other one. This is needed if the van is a 1994 model or older. On newer models, disconnect the reservoir for the windshield washer fluid by removing its bolts and moving it aside.
3 Detach the heater hoses from the heater core tubes at the firewall by loosening their hose clamps. Plug the core tubes with rubber to prevent contaminants from entering.
4 Reach under the dashboard in the van's passenger compartment and remove the screws for the heater core cover to remove it--the cover should have a half-cylinder shape. Remove the two mounting screws at the rear of the heater core and lift the core out of its housing.
5 Insert the new heater core into the housing and fasten it with the mounting screws. Connect the core cover back in place.
6 Unplug and reconnect the hoses to the heater tubes with their clamps. Reconnect any components (like the washer fluid reservoir or coolant reservoir) that you disconnected to access the hoses.
7 Refill the coolant after replugging the drains at the radiator and engine block. Add the 50/50 mix of water and antifreeze to the radiator until it's full and the reservoir to the lower mark. Run the engine in a ventilated area with the radiator cap off until the upper radiator hose is hot, shut off the engine and let it cool, then add more coolant up to the reservoir's lower mark.
Jun 27, 2011 | Heating & Cooling
My washing machine is causing the electricity to short when we put it on. Sometimes it runs for a few minutes and then it happens and sometimes it happens straight away. I did have to have a tube...
Water contamination on the electrical terminals will cause the washer to "Earth Out" and take out the RCD Household safety trip.
See where the contamination is and replace the contaminated items.
Hope that fixes your problem.
Dec 13, 2010 | Microwave Ovens
My screen is discolored and blurry. Please advise..
Sounds like contaminated fluid. Each of the 3 crt's in your set have coolant to keep them cool. This coolant over time gets contaminated and causes extreme blurry picture. ITs extremely common on the Magnavoxs. Its also a pretty big job. Replacing the fluid isnt too difficult but because the tubes have to be removed it means both physical alignment and electronic alignment will be necessary. Also dont remove the green tube until you have done both the blue and red and aligned them to the green. Then do the green.. I hated doing that job lol.. I dont recommend you trying it and probably wouldnt be cost effective to pay a shop to do it either.. I recommend buying a new set... Sorry
Oct 19, 2010 | Philips Magnavox 9P6034C 60" Rear...
Just bought a 1987 Iroc Z. Need to know why my
look at waser bottle and there is a pump . replace the pump very easy to do
Nov 12, 2009 | 1987 Chevrolet Camaro
Rear projection tv screen is dark
This unit does not have bulbs it has tubes.What is happening is the coolant fluid in the picture tubes is contaminated with a fungus( blue and green).A repair shop should be able to fix this problem for about $250.I do not recomend fixing this problem youself,but when it is fixed this unit will look like new
Jan 12, 2009 | Televison & Video
Need a new water container
I bought a Solis replacement water reservoir from Green Beanery in Canada a few years ago. They sell replacement Solis parts, but I'm not sure if they still carry the water reservoir. I had a hard time finding online merchants who sold Solis reservoirs.
Dec 31, 2008 | Solis Crema SL-70 Espresso Machine
My tv seems to be hazey how do i fix
You have contaminated fluid in the blue and green picture tubes.I do not reccomend that you try this repair.Very difficult.A repair shop should be able to get this set looking like new again for about $275.
Dec 12, 2008 | Philips 60PP9202 60" Rear Projection...
Question about a Phillips 50
All thats required is for the coolant to be changed you dont have to change the Tube as a new tube wont include the lens coolant assembly or coolant. So just change the coolant in the green and blue red doesnt get affected and you will be fine.
Jun 03, 2008 | Televison & Video
Maytag MSD2655HE Side by Side Refrigerator Logo
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
isaac johny
isaac johny
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
