Question about HP Officejet Pro L7680 All-In-One Printer
HP 7590 **** printer... unable to scan via network. Comunication error! able to print.
    President:
  • 1,564 Answers
Try using your "System Restore" back to near a day when you remember the printer and scanner were operating correctly.
Posted on Sep 10, 2009
HOW TO FIX...PRINTER IS OFFLINE BUT IT IS ON...WE ARE UNABLE TO PRINT.
If you are getting a status message as the printer is offline on your pc,and afterward you can't ready to print the reports.
Steps to Resolve the Printer Offline Issue:
Step 1:
At first, you need to check your network through the HP Scan Doctor which encourages you to discover and fix the printing issues.
Steps To Run the HP Scan Doctor
    •Open the HP Scan Doctor tool by double tapping the symbol.
    •Start- - >Select your printer- - > Fix Printing
    •Then the list of issues displayed on the screen as result.
    •If the tool shows the white checkmarks at that point there is no issue.
    •If the tool shows the white wrench then the issues are found and repaired
    •If the tool shows the yellow shout point then the issues are found however that can't be solved or skipped.
    •If the device shows the red stamp then you have to take after the on-screen guidelines to determine the issues.
    Step 2:
      Set Your Printer as Default Printer
      •Search your gadget on your PC and select your printer and uncheck the Pause Printing and Use Printer Offline
    •If you can capable print implies your printer is online.
    Officejet 4650 keeps going offline then proceeds with following step Step 3:
    Check Whether You Connect With Correct Port
      •Go to printer- - > Printer Properties - >Port
      •For USB association utilize USB or DOT4
      •For Network Connection use WSD, organize, Standard TCP/IP Port Step 4:
      •Update the printer firmware which may resolve your issues
      Step 5:
      •Manually connect the wired or wireless connection
      Step 6:
        •For network connection just you have to add the second printer to your Windows.
        •Select your printer - > Properties - >Add Port - > Standard TCP/IP Port - > Next port
        •Now you can ready to print implies stop the troubleshooting. Still get the same issue mean you need to connect the printer customer support via +1-800-836-3987
Jan 08, 2016 | Office Equipment & Supplies
How to fix Fatal Error on printer
What operating system? HP has had problems in the past with some installs not working properly. Check the install disk for a program called SCRUB.exe. Unplug the USB cable from the printer, run SCRUB and this clears all traces of printer out of registry. Then rerun the install, making sure that you run the install as an administrator and that you disable any virus protection and firwalls while performing the install. Also make sure you follow the instructions about when to attach the USB cable as starting install with the USB attached will cause problems.
Sep 13, 2014 | HP Photosmart Premium C309g All-in-one...
Re HP 7590 printer - "printer status error" in Control Panel
follow this steps and fix it. God bless you
    • 1
      Ensure that the HP printer cables are properly connected. If in doubt, turn off the printer, unplug it and disconnect all of the printer cables. Plug it back in and reconnect the cables. Turn the printer back on again to see if the error has cleared.
    • 2
      Check the HP printer cartridges and print heads to ensure that they're installed properly. Also see if the printer cartridges are empty. If the ink cartridges have sufficient ink, reinstall the cartridges and the print heads. If an ink cartridges is empty, replace it with a new one.
    • Sponsored Links
    • 3
      Make sure that the HP printer's software is properly installed. If the device does not respond when you try to print or the printer software won't initialize, uninstall and reinstall the HP printer software.
    • 4
      See if your computer's firewall is preventing the HP printer from functioning properly. Open your firewall preferences and add the printer software executable file (*.exe) as an exception or disable the firewall temporarily to see if this fixes the error.
    • 5
      Check the print settings in the HP printer software if the pages don't print properly. Make sure that the margins are set to at least the minimum margins that your HP printer supports. Also ensure that you've selected the correct printer settings for the paper size and type of document you're trying to print. To access these printer settings more easily, open the HP Solution Center.
    • 6
      Clean and align the printer cartridges. Open the software for your HP printer or the HP Solution Center to access these maintenance features.
    • 7
      Double-click on the HP printer icon in the system tray on the bottom right of the screen, if it appears. Look under "Status" in the printing queue to read the error messages. Right-click on the entries and select "Cancel," if necessary.
    • 8
      Navigate to the HP website to search on your specific printer model if these steps fail to fix the printer error. Click on "Support and Troubleshooting." Click "Solve a Problem" to find solutions for the HP printer's specific error. Also check the "Software and Downloads" area for software and driver updates.
Read more: http://www.ehow.com/how_4999655_fix-hp-printer-errors.html#ixzz2ZOUHvWVn
Jul 17, 2013 | HP Hewlett Packard - 5187-7590 - This...
Unable to input a destination for the Button Settings Tab
Even if the printer installs OK, the scanner is not allways recognized. Try to look for new hardware>scanners in Control Panel. It migth want the HP CD or the driver from www.HP,com. Or find a picture editing program and File>Import>HP officejet Pro L 7590 AIO- twain! That works!
Mar 05, 2010 | HP Officejet Pro L7590 All-in-One InkJet...
Im having trouble scanning on the hp 7590 printer
Kindly reinstall your HP 7590 Printer to refresh and fix the error or corrupted files in your driver in order to run your device properly. Make sure also that the driver you install for your printer is support with your Current Operating system to minimize error and malfunction of the device.
Thanks
Jul 30, 2009 | HP Officejet Pro L7680 All-In-One Printer
HP 7590 office jet pro scanner does not communicate
The scanner function is not available when you are connected wireless, you must be connected via USB to your PC for the scanner to function correctly.
Buddy
Corporate Computer
Over 21 years of PC and printer support/repair
Jun 17, 2009 | HP Officejet Pro L7680 All-In-One Printer
Unable to print or scan - copy only
that is a networking problem the fact the you can copy eliminates the possibility that there is something wrong with the printer / copier
Mar 25, 2009 | HP Office Equipment & Supplies
My 3210 will not scan
I now have 2 of these and both print ok but can not scan with either, never tried to till now.
I have re- downloaded the driver from HP.com via Internet Explorer (usually use Mozilla Firefox) and i get 2 diff. error messages : network busy (impossible since it is connected via USB) and the 1 at my office connects wirelessly but error message is something to do with software.
Thanks!
Nov 02, 2008 | HP Photosmart 3210 Printer
Can't scan
This sort of thing can be down to the fact the settings for communication to the printer is separate for printing/faxing/scanning. So you will need to find the scanning device (will usually be called HP3050 regardless, or something along the lines of that) and make sure it's set to communicate through USB and no other means.
Sep 07, 2007 | HP LaserJet 3050 All-In-One Printer
HP Officejet Pro L7680 All-In-One Printer Logo
396 people viewed this question
Seeker5211
Seeker5211
