Question about Ace Hardware InSinkErator Badger 5, 1/2 HP Garbage Disposal
Motor is on blades will not turn - Ace Hardware InSinkErator Badger 5, 1/2 HP Garbage Disposal
  • 115 Answers
On the buttom of the motor theres a black reset button press that see if that will work,if not then put soap and leav hot water running in sink for about 10mins then turn of then get a big flat screw driver and put it in where u put the food in the dispencer on the sides of it and try to make it spin cuz it usally gets stuck due to some items u put in and gets stuck on sides if you can try hiting on scre driver side ways to make it spin if u do a little then it will work.if my info was of any help to you please leave a comment,vote,note.thankyoub
Posted on Sep 10, 2009
Lennox XC21 (7 yrs old) compressor motor does not turn fan blades
Check the motor by hand to see if it turns freely, if it does then the issue is the motor controller not being able to sense where the motor is. Check for 240 Volts on the red wires and then check for 24 volts dc between black and blue and black and yellow.
May 27, 2016 | Heating & Cooling
I can manually turn the blades inside the glass pitcher and I can turn the piece on the top of the motor base into which the pitcher blade attachment fits.
One of the parts is not being driven properly. Either the clutch on the top of the motor is not really attached to the motor shaft OR the clutch on the bottom of the blade is not engaging with the motor clutch OR the blade clutch is not properly attached to the blade shaft. On some models if you put the rubber sealing ring in the wrong place between the beaker and the blade housing it is enough to lift the clutches apart. The rubber wing goes between the beaker and the blade housing, not between the blade housing and the blade retaining ring.
Jul 14, 2015 | Blenders
Motor turns but blade doesn't
Is the shaft turning...? if so then refit the blade . If the shaft is not
turning then you need to get the motor out and check to see if the
shaft and motor are connecting or not, can you do this job yourself
if not, take it to someone who can..T.C.
Mar 22, 2013 | Saws
Motor buzzes, fan does not move, blade does not move, blade is clear of obstruction
Removing blade will not do it - there has to be an obstruction in the drive mechanism that prevents it from turning. Leave off till fixed lest you risk burning out the motor completely. Turn on AFTER you can turn the blade freely.
Sep 03, 2017 | Remington 3-Amp 17" Extended Reach...
How do i do it myself to install outdoor bower motor condensor motor 1/4 hospower 350 rpm and also the 5 amp capacitor. If i keep the 10 amp capacitor is that a problem?
Turn off power in all cases. If you are replacing the orignal motor for the 1st time. It might be easier if
you cut the wires near the control box and then wire
nut them together and wrap with electrical tape.
Remove the fan cover and unloosen bolt that hold the
fan to the frame or whatever it might be. After fan is out spray some WD40 that holds the fan blade to
the motor shaft. Measure the distance from the fan
blades to the motor.
Unloosen the screw that holds the fan blade to the
motor shaft.Take sand cloth and try to clean up
the shaft below the blades. Try to tap the fan blade
down towards the motor.If it moves sand the shaft above the blades. Take channel locks and grip the shaft below the blades, try turning the fan blade while
holding the shaft until it spins freely and the remove.
If the motor came with a 5mfd capacitor use it.
Jul 01, 2010 | Heating & Cooling
Vornado Circulating Fan - motor will run but blades will not turn.
Does the motor spin, but the blade is not turning?
The motor has a D shaped shaft. If the hole in the blade that the shaft goes in is rounded, then the blade will spin. In that case you need a new blade. Vornado can supply that.
Jun 27, 2010 | Vornado Circulating Fan
Motor can be heard going but the blade wont spin!!
There is usually a pin in the shaft of the motor, that corrosponds with a slot in the fan blades, it sounds to me like either (a) the pin somehow came out, or (b) the slot in the blades is rounded. Hope this helps
Jul 15, 2009 | Patton 20" CVT Performance Air Circulator,...
Drive gear is slipping. Motor turns but the blade fails to turn
sounds like a shear pin either on the motor or the blade assembly. If you put the blender on low without the cannister on top touch the gear on top of the unit and see if the gear slips or stops. Use a pencil or something..Not your finger. If it stoops then the pin is broken at the motor. If not, it is broken at the blade unit.
Hope this helps
Kurt
Mar 17, 2009 | Back to Basics Smoothie Jr. B Work Top...
Blade does not turn
Disconnect the electric from the saw. Remove the throat blade cover. Bring the blade all the way up. Look for wood  caught between the blade and anything else. Finding none,remove blade. Try motor w/o blade. If it runs now,w/o the blade then the motor is likely ok . Reinstall blade. Now if it stil stalls, Replace motor.
Feb 11, 2009 | Craftsman 10" Table Saw
Central A/C motor blade turns all the time
it is just possible that an air draft thro rhe fan blades is turning the motor. to check, disconnect the motor and see if it still turns. disconnect from mains before doing this
Mar 25, 2007 | Goodman CLT36AER36 Air Conditioner
Ace Hardware InSinkErator Badger 5, 1/2 HP Garbage Disposal Logo
219 people viewed this question
Top Ace Hardware Electrical Supplies Experts
handygirl911
handygirl911
Mike
Treefrog15
Treefrog15
Are you an Ace Hardware Electrical Supply Expert? Answer questions, earn points and help others
