Question about NetGear RangeMax Premium Wireless-N Gigabit Router
Trying to install a panasonic Wireless Network camera on a network that uses a Netgear WNR3500 router. http://www.amazon.com/Panasonic-BL-C131A-Network-Camera-Wireless/dp/B000NVR9SM I am thinking that the problem may have something to do with the router insallation disk not working with 64 bit Vista OS. The router indicates that it is UPnP enabled, but it will not allow the wireless setup to occur. It does work when it is wired directly to the router however.
  • 854 Answers
A. Determining the IP Address and MAC Address of a Computer:
Note: Please use the computer for which the Ports are to be opened:
For Windows 2000/XP users:
1. Please click on Start and select Run.
2. Type in cmd and click on OK.
3. In the Command Prompt, please type ipconfig/all then press Enter or Return key.
4. Please make sure that the Ethernet adapter has an IP Address that is the same range as the router (e.g. 192.168.1.2 for the computer and 192.168.1.1 for the router).
5. Please note down the IP address and Physical address.
B. Reserving an IP Address:
1. Please open any web browser like Internet Explorer or Netscape Navigator.
2. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.1.1 in the address field and click Enter or Return key.
3. A window will prompt for a user name and password. The default username is "admin" and the default password is "password".
Note: If it does not take password as the password, you might have changed it when you have run the NETGEAR Setup CD so please try other passwords. If you cannot remember the password, you need to reset the router and run the Setup CD to reconfigure it.
4. When the setup page opens, click on LAN IP Setup under Advanced tab.
5. Click on Add under Address Reservation.
6. Under Address Reservation window, please select the radio button of the computer you wish to add from the Address Reservation Table.
7. If the computer you want is not on the list, please click on the Refresh button to update the table.
8. If the computer is still not on the Address Reservation Table, please type in the IP Address, MAC Address (Physical Address), and Device Name of the computer you wish to add.
9. Click the Add button when done.
C. Opening Pre-Defined Ports for Internet Services:
1. Click on the option with the name Port Forwarding/Port Triggering under the Advanced menu.
2. Please select the service type Port Forwarding. The router pre-defined services are listed there.
3. From the Service Name pull down list, select the service that needs to be hosted.
4. Enter the IP address of the computer in the Server IP Address box.
5. Click the Add or Apply button.
6. Repeat all steps to open more ports.
Note: If the name of the Internet service does not appear in the drop down list, you may manually open the ports for that Internet service. Please follow the steps below:
D. Opening Ports for Games, Applications or Custom Ports:
1. Click on Add Custom Service button.
2. Type the service name in the Service Name box and the lower range numbers in the Starting Port box.
3. If the application uses only a single port; type in the same port number in the Ending Port box.
4. If the application uses a range of ports; type in the higher range numbers in the Ending Port box.
5. Type the IP address of the computer in the Server IP Address box. Click Apply button.
6. It will then refresh to the Port Forwarding page, and will show the list of all ports opened in tabulation.
7. Repeat all steps to add more ports for more services.
E. To Edit or Delete a Service Entry:
1. Click on the Radio Button that needs to be Edited /Deleted, under the Port Forwarding page.
2. Modify the information from the Service Name, Starting Port, Ending Port, and the Server IP Address, and then click the Apply button.
Posted on Sep 10, 2009
How to connect a linksys e1500 router to a repeater?
Run an Ethernet cable from one of the LAN ports on the downstairs router to connect to the WAN port on the upstairs router. Result: 100% connection.
Jul 08, 2012 | Linksys E1500 Wireless-N Router with...
I was wondering how do i lock my netgear wireless router wnr3500 so that other people can not use it
The manual for your router is at: -
http://kb.netgear.com/app/answers/detail/a_id/190
First you have to access the router through web browser (Internet Explorer) by typing the IP address of your router in the address bar, which is usually 192.168.1.1 or 192.168.0.1 and lookup for the options to do the following: -
1. Change the SSID (Name) of the router
2. Change the default administrative user name and password (unless you've configured otherwise, the default username is admin and the password password.)
(The above step would prevent unauthorized access to your router)
Next step is to secure it:
1.On the left-hand side, under Setup, click "Wireless Settings" 2.Under "Security Options", select your desired encryption method (preferably WPA2-PSK)
3.Choose a Network Key - it can be anything, as long as it's 8-63 characters in length
4. Click Apply
Now your router and your connection would become secure and the user has to provide the network key to access the internet.
Feel free to contract me for further assistance
CreativeTECH
Nov 05, 2010 | NetGear WNR3500 Router
Connection is intermitent. I receive signal and it works fine for 5 minutes. Then the signal continues but I do not get internet access netgear wnr1000
Do you have anything else on the network besides your computer? If you do, it may be a conflicting IP address. I was told by the Comcast tech that the WNR1000 doesn't allow additional routers on the same network. Have to upgrade to a WNR3500 for that. When I disconnected my wireless extender, it fixed the problem.
Aug 05, 2010 | NetGear WNR1000 Router
I am trying to connect another computer to my wireless network but i do not know my netgear code, where do i find this?
Netgear code? Can you be more specific?
Are you referring to the password required to connect to your wireless network called "Netgear"? I assume you're being asked for a password on the 2nd computer when trying to connect to the wireless network called "Netgear".
  1. In a web browser, enter the router's IP address - either http://192.168.0.1 or http://192.168.1.1 by default.
  2. When prompted for a Username and Password, enter the default username and password (admin; password) unless you have already changed it. NETGEAR recommends changing the default password to increase the security of your network.
  3. Select Wireless Settings from the Setup menu in the left-hand navigation bar.
  4. Under Wireless Network, enter your desired network name in the Name (SSID) box. This is currently set to "Netgear" most likely.
  5. Under Security Options, select WPA-PSK [TKIP] + WPA2-PSK [AES].
  6. Under Security Options (WPA-PSK + WPA2-PSK), enter your desired network password into the Passphrase box.
    • WRITE DOWN or KEEP NOTE of your network name, security option and passphrase - you will require them to connect wireless computers and devices to your network.
  7. Click Apply to save the settings.
Once you've set this password, you can use it to connect to "Netgear" on your second computer.
Jul 25, 2010 | NetGear WGR614 Wireless Router
Just bought a new PC with Windows 7 and the netgear wireless-g wgr614 router says it's incompatable
are you trying to run CD on new computer ?
You can do it manually without CD.
First let me know, are you trying to install the router OR you are trying to add a new computer to the existing network.
If you are trying to add a new computer to the existing network then you don't need to install the router on the computer, you just need to connect to the network.
Click Here for more information about router and networking
Feb 05, 2010 | NetGear WGR614 Wireless Router
My wnr3500 router will not detect my usb760 modem
Hi, Well, this router will not work with usb modem. For 3g usb modem purchase MBR624GU. Make sure to check if ur usb modem is listed in the compatibility list. Hope this helps.
Aug 10, 2009 | NetGear RangeMax Premium Wireless-N...
Netgear WNR3500 router hardware reset?
Get a paper clip press and hold the reset of the router for 15 seconds, you'll see that near on the power cord of the router, Then reconfigure the router again.
Mar 16, 2009 | Computers & Internet
WNR3500, PURCHASED WITHOUT CD, CANNOT CONFIG.
If the router is still functioning properly, you can access the router through its web interface. I never use the CD that is packaged with the router. It just gets in the way most of the time.
Mar 13, 2009 | Network Computing Devices Computers &...
Bridge my router
Since you have two routers, both of them are trying to assing DHCP address to the network, so all you need to do is just disable DHCP on the netgear router, there fore the westell will assing the address.
Are you just trying to use the netgear for wireless?
Jan 17, 2009 | D-Link 802.11g Wireless Router WBR-1310...
NetGear RangeMax Premium Wireless-N Gigabit Router Logo
168 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
