Question about Midland WR-100 Weather/RDS Radio
Keeps flashing check reception
My wr-100 keeps flashing check reception but when i push the weather button it receives fine and i hear the broadcasts clear as day all of my same codes are programmed properly and we recently had snow advisories and ice storm warnings and the radio never went off
  • Anonymous Jul 17, 2008
    Same thing. Strong signal. Very close to transmitter. But keeps coming up with CHECK RECEPTION. Never get any warnings.
I unplugged mine, took out the back up batteries, and waited several minutes.
I reinstalled the batteries, plugged it back in, and reset the time.
For now, it seems to have solved the problem.
Posted on Feb 13, 2009
My wr-100 was doing the same thing. I switched the SAME set to ANY and left the nearest station showing. It started working again as normal. It might have been the ice storms and weather conditions affecting mine as I am on the fringe of signal strength. Might be worth a try.
Posted on Dec 16, 2007
Message says check reception. radio is in same location as always
This message means that the radio didn't receive the weekly check-in or test signal from the station it's tuned to, sometimes the station will fail to send it. To clear this message, simply turn the switch on the side of the radio off for a few seconds, then turn it back on.
May 31, 2014 | Midland WR-100 Weather/RDS Radio
How do i get my WR 100 to stop squeaking durring a weather emergency?
Have you tried tuning to different NOAH frequencies to see if one of them gets better reception? Also, if the radio is close to other electrical devices, they could be causing interference with your weather radio reception.
Just a couple ideas tossed out there.
Good luck.
May 10, 2012 | Midland WR-100 Weather/RDS Radio
Midland Weather Radio Will not give a weather report
Have you gone into the setup mode and adjusted the voulme setting?
Just a thought. The volume may be turned down too low.
Mar 25, 2012 | Midland WR-100 Weather/RDS Radio
Where is reset button on midland wr-100 weather alert radio
I am not receiving any radio broadcast on the freq. that my radio is supposed to pick up. radio is on correct region code. What can I try?
Feb 26, 2012 | Midland WR-100 Weather/RDS Radio
Got a midland weather radio problem wr100 series. all county codes in and channel set. was working for awhile and now no alerts at all. keeps now saying check reception.
Turn your radio off and then on again. Then press the weather/snooze button. Do you hear the broadcast from your local transmitter? Check NOAA to make sure the station is broadcasting (not down for repairs). Try setting the radio to a different transmitter that covers your area.
You may need an external antenna for the radio (http://www.midlandradio.com/Weather-Radio-Accessories.BPE/18-259W ). Beware: when you use an external antenna, you may receive a broadcast from a different transmitter (farther away). In that case, the weather alerts for your county will likely not come in.
I hope this helps.
(we have two weather radios that are on full-time. The one set to a secondary transmitter does not receive the S.A.M.E. test signals or watches. (It can't be positioned to receive from the primary transmitter clearly.) It does receive warnings for the county correctly. The on/off routine has to be done every few weeks since it doesn't get the test signals. We tried an external antenna and kept getting transmitters from other states and missed tests, watches and warnings. Fortunately our main weather radio does get the primary transmitter and gets the tests, watches and warnings.)
Jun 27, 2011 | Midland WR-100 Weather/RDS Radio
How do I set for weather alerts
1. Turn switch on side of radio to "ON".
2. Press "MENU".
3. Press "UP" arrow until "CHANNEL" is displayed.
4. Press "SELECT".
5. Press "UP" arrow until you hear the broadcast of your station.
6. Press "SELECT" to save station selection.
7. Press "MENU" to close menu mode.
To turn Weather/Hazard broadcast on again, press "WEATHER/SNOOZE".
Jan 01, 2011 | Midland WR-100 Weather/RDS Radio
How do i program the radio to only give audio alerts for the county in whitch i reside? (sarpy county in nebraska
2. Press "MENU".
4. Press "SELECT".
Note you will hear only static on the channels not received in your area.
(FYI - channels are listed 1-7 on the left, and corresponding frequency numbers are displayed on the right side of display.)
At This Point You Will Receive Weather And Hazard Alerts Issued By The NWS.
Dec 24, 2010 | Midland WR-100 Weather/RDS Radio
That's because you haven't received a Required Weekly Test (RWT) for the present or past week. I just had a problem like this not to long ago. You should try unplugging the radio and taking out the batteries. Put the batteries back into the radio and plug it back in. Check to make sure your settings are still intact (you'll have to reset your time.). I'll have to check the radio this week to make sure that RWT comes in. The National Weather Service (NWS) does its Weekly Required Testing on Wednesdays between 10 a.m. & 12 p.m., I haven't had a "check reception" message scroll across the screen since everything was reset; and to enhance your confidence doing this, I actually saw a person who works on these radios, do this to my radio. As far as the weather radio going off, it really does go off when severe weather strikes, because mine just went off (my area is receiving a flash flood warning). The weather you have been receiving probably isn't "severe" enough for the NWS to sound the alarm. For more information on when and what type of event sounds the alarm, and the procedures proceeded when the alarm goes off; go to these websites:
http://www.nws.noaa.gov/nwr/nwrtest.htm
http://www.nws.noaa.gov/nwr/nwrwarn.htm#B
http://www.crh.noaa.gov/lsx/?n=nwrfaq.
Hope this helps!
Jun 23, 2010 | Midland WR-100 Weather/RDS Radio
Automatic Weather Alert
Weather Radio WR.100 was defective. Returned unit to retailor for replacement. Problem solved.
No further action required.
Krehgil
Sep 12, 2008 | Midland WR-100 Weather/RDS Radio
Midland WR-100 Weather/RDS Radio Logo
1,156 people viewed this question
Top Midland Audio Players & Recorders Experts
Van Allen II
Van Allen II
xxxxxx xxx
Are you a Midland Audio Player and Recorder Expert? Answer questions, earn points and help others
