Question about ASUS TM-220 (generic) Micro ATX Mini Tower System Cabinet - Black Micro ATX Mini-Tower Case
What is Mini Tower ATX Cabinet - ASUS TM-220 (generic) Micro ATX Mini Tower System Cabinet - Black Micro ATX Mini-Tower Case
  • 215 Answers
Type of pc cases i.e Cabinet Form Factor (Mini Tower), Motherboard Form Factor (Micro Tower) and Platform Factor refers to the computer type (Mac, PC or UNIX), used with the ATX specifications.
http://www.formfactors.org/formfactor.asp
Posted on Sep 10, 2009
    President:
  • 1,187 Answers
It is one of the most typical cases used by non-laptop computers.... Also mis-called a "desktop".
ATX refers to the motherboard, power supply and case format class. All ATX-designed hardware "fits" together.
This type of case is meant to stand upright (tower), as opposed to "on its side" (desktop).
Most older servers are "Full-height Towers" .... most home computers and/or work computers are "Mini-Towers".
ATX Mini-Tower cabinet is a "safe" buy today; however, some do not include a power supply (extra $50).... Some have small (300watt) power supplies, which is ok in 80% of systems.
Hope this helps!
  • ASUS Master
  • 32,281 Answers
A mini tower is a PC desktop case which is approx half the height of a full size desktop tower case. ATX probably refers to a ATX switch mode power supply.
Intel D945GTP power comes for one second and suddenly off
open the tower/ ATX cabinet and then check the two small power cable pins that connects the power button on the ATX cabinet and the motherboard, remove the same from the motherboards end (make sure you note down from where you removed the 2 power pins and then using a insulated screwdriver short the power pins on the motherboard for a second until you see the power coming on let go of the pins as soon as you see the CPU fan moving if it stays on and works normally it is a faulty power switch on the ATX cabinet and then you can either replace only the power switch or get a new ATX cabinet to fix it
you can also check if motherboard stays on if you remove the RAM chip from the motherboard. if yes its a faulty Ram and replacing the same should do the trick
you can also try cleaning the dust accumalated under the CPU fan and between the heat sink as some motherboard cuts off the power depending on the temperature
also if nothing works you can try using a different power supply unit to see if that's the case,
if still no luck then its time to buy a new motherboard.
Feb 06, 2012 | Intel D945GTP Motherboard
I need help installing a cd drive in an Antec Sonata III 500 computer case. How do I do it?
Unplug the power from the computer. Open the case cover. Carefully remove the placeholder on the front of the case where you wish to install the CD drive. Make sure you have the proper ribbon cable for the type of drive you are installing and that you know where to plug it into the motherboard (consult your motherboard manual).
Use the screws provided to secure the drive to the chassis rails (make face of drive flush with front of case). Attach an available power supply connector to the new CD drive. Close the cover.
Dec 04, 2009 | Antec Sonata III 500 - mini tower - ATX ...
Need to add a second hard drive. case only has rack for one
Use an external USB 2.0 drive. If you have a Firewire or eSATA port you can use that kind of external drive instead.
Oct 11, 2009 | Foxconn Mini ATX Mini-Tower Case
Dell Dimension 5100 - Will not turn on
open cpu cabinet.
Reattach ATX power supply connection to motherbord. ATX from SMPS to motherbord.
then check if it still not power ojn then clear cmos.
Pul away your cmos cell for 15 minutes from motherbord then check .
ALso change cmos cell if it is old.
Jun 26, 2009 | Dell Dimension 5100 (D51L1) PC Desktop
My computer wont play sounds it says i need a mixer or something, i formatted my computer yesterday and upon getting it working again i have had no sound... HELP?
Probably just need to update your drivers.  Check your device manager and if you have any yellow exclamations in the sound section.
May 02, 2009 | ASUS TM-220 (generic) Micro ATX Mini Tower...
Motherboard model H1290
Any ATX mini/middle/tower case. PSU ATX 300-350Wt and higher.
Oct 24, 2007 | Computers & Internet
NetVista M42 8305 mobo jumpers & pins settings
GET ALARGE TOWER CASE TO FIT IT CONVINIENTLY
Aug 27, 2007 | IBM NetVista M42 PC Desktop
Power failure
your power pack is bad.replace it.
Apr 12, 2007 | Ultra (ULT31586) ATX Mini-Tower Case
ASUS TM-220 (generic) Micro ATX Mini Tower System Cabinet - Black Micro ATX Mini-Tower Case Logo
1,150 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
