Question about Brother Multi-Function Center MFC-240C All-In-One InkJet Printer
Brother MFC-240C Hi, I am having problems with my printer. I tried to do a test print...the quality seems to be OK... all the colors comes out right. The only problem that might be is that the blue is always missing one square in the row - always the same one. All the other colours are fine. Also, when I print a document, the characters seams to be bolded (even though they are not in the document) as well as seeming that their are two of the same character typed very closely together. I don't know if this is to do with the alignment. Please advise. Thank you.
  • 832 Answers
2nd first:
Yes. You should print a alignment test print and follow the instruction which is given on the test print.
I dont understand the first complain:
Do you miss several first squares or do you miss just one?
The latter one is no prob. You can ignore that. The first one (several 1. squares missing) is a serious prob: This indicates that a whole channel is defective!
Did you do a cleaning procedure and check the squares afterwards? If not do so. If you still miss the several 1. squares the ph needs relacement.
Posted on Dec 10, 2007
I just changed my ink cartridges but now the printer is only printing black and white
STEP 1: OPEN THE PRINTER PROPERTIES:
WINDOWS 98/ME/2000
A. Click on START -> SETTINGS -> PRINTERS
B. Right click on your Brother machine (example MFC-XXXX where X = modelnumber of your machine) and left click on PROPERTIES
WINDOWS XP
A. Click on START -> CONTROL PANEL -> PRINTERS AND FAXES (or PRINTERS AND OTHER HARDWARE, then PRINTERS AND FAXES)
B. Right click on Brother machine (example MFC-XXXX where X = model number of your machine) and left click on PROPERTIES.
WINDOWS VISTA
STEP 2: CONFIGURE THE PRINTING PREFERENCES
Depending on which version of the driver you are using, you will need tocomplete one of the following sets of steps.
A. If using the Brother Original Driver:
i. On the GENERAL TAB click the button for PRINTING PREFERENCES.
ii. Click the ADVANCED TAB.
iii.. Choose COLOR
iv. Click APPLY -> OK
v. Click OK to close the Printer Properties window. Your printer will now print in grayscale.
B. If using the Vista built in Driver:
ii. Click the PAPER/QUALITY TAB.
iii. Choose COLOR
Oct 31, 2010 | Brother MFC 240C All-In-One InkJet Printer
How can I set my MFC-240C printer to print from my computer
switch on the printer
1. install driver for mfc-240c
2. go to control panel in your computer
step to control panel
select START then control panel
3. select printer mfc-240c right click on it and then click on click on <Set as Default Printer>
4. right click again on it the select <properties> then select "print test page"
test page will printout on printer
5. now you can use mfc-240c as printer
Aug 19, 2010 | Brother MFC 240C All-In-One InkJet Printer
My mfc-240c won't print red, even with a new cartdrige.
Try running a few cleanings on the color.
Press the ink button and select cleaning,, do about five cleanings. Print the ink quality test page (from the ink button as well) and see the quality if it improved.
If it still doesnt print its possible the ink is clogged and may need servicing to replace the printer head
Apr 06, 2010 | Brother MFC 240C All-In-One InkJet Printer
The unit function to print but there is no print out in the bond paper.
Try to run test print from menu tab of the printer if it’s print normally then the problem is in the computer printer settings, review color quality under advance tab and look for black label option to check if not disabled.
Mar 23, 2010 | Brother MFC 240C All-In-One InkJet Printer
My Brother MFC-240C printer is causing me grief. It prints out in black as though it is out of black ink but the ink is full. The other colors print out ok. Any thougths?
If the colors print OK, you could try cleaning the black nozzles. (Your machine may allow you to clean just the black or the colors, or all the nozzles).
1) Press the <Ink> or <Ink management> key
2) Use <Up> or <Down> arrows to navigate to "Cleaning" and press <OK>
3) Use <Up> or <Down> arrows to navigate to color that needs cleaning, or "All" and press <OK>
4) The display will show "Cleaning" and "Please wait"
5) After completion, the printer should be ready
If the problem persists, brother advises that you may need to repeat the process up to four times. If still no results, contact brother customer service.
Jan 22, 2010 | Brother Multi-Function Center MFC-240C...
My brother MFC 240C was set for printing only black and white, since I had only installed a black cartridge. Now I have installed the three color cartrdiges also. How do I change the settings to print...
You have to change the settings in your print driver. In Windows XP or Vista, go into the Control Panel and the Printers & Faxes applet. Right click on the Brother print driver and select Properties. In one of the tabs there should be an option for either Grayscale or Color printing (probably under Color Management) -- change this to Color and then click OK or Apply to save the changes.
By changing it in the print driver settings, the change should take effect for all programs that you print from.
Jan 02, 2010 | Brother Multi-Function Center MFC-240C...
Black ink in brother 240c printer does not print new cartridge
I have a brother MFC 3240C. My Black ink stopped printing(initially printed horizontal faded lines and gradually got worse), the other colors were printing fine. I tried cleaning numerous time( 50 -100 times over 1-2 weeks ). Still no improvement. The way I print now is:
1. I go to Printer Properties
2. Change Media type from "Plain Paper" to "Inkjet Paper".
3. Change Quality to "Photo".
This takes a long time to print 1-2 minutes per page. However, this works for me since this is my Home printer and use it for printing only few pages here are there. Better than throwing the printer.
Good Luck
RK
Nov 20, 2009 | Brother MFC 240C All-In-One InkJet Printer
No print at brother mfc-24c
"Machine Error 50" (or "Unable to Print") indicates either a simple problem such as a paper or part of a paper stuck inside the machine, which of course is solved by opening the machine as much as possible and remove the reason for the jam.
However, if that doesn't work, the error is mechanical, and there isn't much you can do. If the message comes back right after turning on the machine, you'll have to have service performed on the machine.
Jun 16, 2009 | Brother MFC 240C All-In-One InkJet Printer
Cannot print blue/green colors.
I think your cartridge is defective, you need to replace a new cartridge.
May 22, 2009 | Brother MFC 240C All-In-One InkJet Printer
Brother Multi-Function Center  MFC-240C All-In-One InkJet Printer Logo
113 people viewed this question
James Cagle
James Cagle
Victorman
Victorman
Norman  J Weimar Jr
Norman J Weimar Jr
