Question about Samsung CLP 315 Laser Printer
Samsung clp-315 prints half a page then jams
The printer prints half the page just fine but then jams. Have to pull out the jammed page.
My CLP 315: starts printing, but paper jams every time. It's prints fine on the top half of the page, then gets blurry and will not exit printer. I have to turn off/on to get the page out. I...
at the fuser unit. thes is the part were the printer get very hot with a red and gray roller.
look in th sid of it you will find a sensor . you need to replace it
Jul 24, 2011 | Samsung CLP 315 Laser Printer
My Samsung CLP-315 Laser Printer will print about a half page and then jam...everytime!
does the jam came out to the exit and stuck there or it jam in the printer or before the pickup?
if it got jam at the exit. the exit sensor is faulty it got to replace.
if it got jam in the printer. the transfer belt or fuser is faulty. both got to replace
if it got jam before pickup. pickup roller got to replace.
May 09, 2010 | Samsung CLP 315 Laser Printer
Papr Jam, Samsung CLP310 - paper jams half way through the job
If it jams every page, it is the infamous Samsung design flaw. There are dozens of reports of this problem all over the internet. The best solution: sell it or otherwise get rid of it ASAP and buy another type or model of printer. The 2nd best solution: call trained technician and ask to replace the broken part. It could be thermistor near fuser, some people say it is a photo-interrupter.
May 02, 2010 | Samsung CLP 315 Laser Printer
My Samsung CLP 315w refuses to print a whole A4 page. Stops half way then message comes up paper jam but when I open back / front, paper not jammed and when I close it document continues printing then...
most likly hood is your exit sensor is faulty. The printer work in this way. if it does not print out all the document. it will print again. that is why you kept getting this same issue after a jam open and close door it will print again.
replace the exit sensor it will help.
Apr 16, 2010 | Samsung CLP-315W Laser Color Printer
My Samsung 310 printer is giving a paper jam message inside warning when I turn the printer on and yet there is no paper jammed inside. Cannot print. Been working fine before. Mayb 100-150 pages printed...
Chek paper size (A4, letter...etc)in driver options and compare it whit your file settings (fo example - you trying to print something whit paper size A4 but printer expect letter format...etc)
Clean paper feed roller
Apr 08, 2010 | Samsung CLP 315 Laser Printer
Sounds like the "Fuser". I have the same problem. Samsung wants $135 labor plus parts [$135+]. Printer can be purchased for less. Mine is going into the garbage and I'll stick with Epson.
Mar 16, 2010 | Samsung CLP 315 Laser Printer
Printer prints half the page and then jams.
clean the print head and reset printer to get better results
Sep 01, 2009 | Samsung CLP 315 Laser Printer
Samsung CLP-315 prints half a page and then stops & jams. Interior is clean. Our CLP-315 is doing the same thing. Only had it 6 months. The paper stops printing half way through and you have to open the...
It sounds like your fuser is causing the jame,.
when you remove the paper can you wipe the toner off the page or does it adhear to the paper ?
If it does not the fuser is causing the jam, if the toner does not wipe off the paper then the feed tires would be the cause of your jam
The fuser is at the back of the printer and will be very hot, so be careful.
May 26, 2009 | Samsung CLP-315W Laser Color Printer
Samsung CLP 315 Laser Printer Logo
306 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
