Question about Averatec 3200 Notebook
Avweratec 2300 will not turn on
Same problem have replaced the motherboard and I believe it is a heat issue. I dont think my motherboard is good anymore and to replace it would only give me another 6 months and then it would overheat again. Best to just toss it and buy another non averatec computer.
Have you tried running it in safe mode? if it starts up then go to your start menu>all programs>accessories>system tools>system restore. go to a date before hand were it did work and your computer will restore itself.
Posted on Sep 10, 2009
Digital thermostat Honeywell RTH 2300 - compressor runs when in heat mode
Check thermostat wires maybe to long and touching in the back of the thermostat
Mar 21, 2013 | Heating & Cooling
I have dell studio 1558 laptop.The ATI card on the motherboard got burned.However i learnt that the whole series of i3 processors in the studio 15 were faulty and if i buy the same motherboard again t
I would not consider replacing the motherboard, in fact Dell should be replacing the laptop for a design that does not have these heat related issues, I think if you made enough noise about this particular line they may replace what you have lost.
Jul 10, 2012 | Dell Studio 1558 Notebook
I think it is the power supply. It is a Besttec ATX-200-12Z Rev D mounted in a Compaq 6450NX desktop PC running Windows XP Professional Computer will (intermittenly) start up, and shut down on it's...
While it could be the motherboard it does seem more likely that it is the power supply.
Here are two options to test your theory:
1. If you have another known good power supply or can borrow one, hook it up to the motherboard and see what happens.
2: Or, if you have a known good motherboard or can borrow one (does not have to be the same as yours of course) hook your power supply to it and see what happens.
Jun 20, 2011 | Bestec (ATX-250-12E) 250-Watt Power Supply
My Dell 5000e unexpectidly turns itself off.
There are a few things this could be, most of them are motherboard related, but there could be a cooling issue or a power supply issue. Check the BIOS log for "thermal events". Things like CPU overheating can cause weird reactions in the machine, called System hysteresis. Basically, the computer goes crazy, opening things, crashing, rebooting, etc. Based on what youve said, "restarts normally", I dont think there is a CPU issue, nor a memory issue.
The first thing I would try is replacing the power supply and remove the battery (just as a test), and see if the machine starts behaving better or exhibits the same issues.
I believe the issue you have described can be most likely resolved with a new motherboard, especially if the power supply route does not yield positive results. Bad news is, a p3 motherboard is rather hard to get, and hard to replace, and rather pricey. I would sooner consider getting another notebook pc before replacing the board.
Jan 24, 2010 | Dell INSPIRON 5000E (969PG) Motherboard
Dell PowerEdge 2300 - Monitor, keyboard and mouse will not respond
It sounds like the power supply is failing.
Failing power supplies will sometimes deliver just enough power to make the fans spin but not enough for the motherboard and drives to start.
I hope this helps.
May 28, 2009 | Dell PowerEdge 2300 Server
CD rom not working
Acer 2300 travelmate the problem with the laptop is that the drive shows up in my computer but wont read any discs I think it needs to be replaced but i dont know how to do this is there any diagrams available to show how this is done please
Thanks Stuart
Nov 11, 2008 | Acer TravelMate 2300 Notebook
Acer travelmate 2420
It could also be the CPU "heat sensor" causing a "thermal" shutdown.
Try a hairdryer on cold blow, and point it in where the CPU cooler is!
see does the laptop stay on longer. Thermal paste dosen't usualy "go" unless the heat sink has be detached from the CPU.
I think as you say either the fan or I think the heat sensor.
Aug 22, 2008 | Acer TravelMate 2300 Notebook
Pci express slot
Hi dineshcs.
When adding a new graphics card (Your's being a PCI-Express), you must change a bios setting under the title " Advanced " section. Open you're M2N-MX manual & turn to page 2-21. You need to change the boot order for you're graphics to list,
[PEG/PCI]. Change Initiate Graphic Mode Select to [Disable].
These changes stop the onboard graphics card from loading & allow the PCI-Express card to load. The issue of possible motherboard overheating can be caused by many things. Here is a list of things to check.
1). Check the CPU heat-sink fan. Make sure the fan blades are
free from dust build up. Check fan speed in bios (Its RPM will be listed). It should be running a min of 2300 RPM.
2). Also in the bios is Hardware monitor. By booting into the bios go to this & watch the temp of CPU & motherboard. If either is getting too hot suggest you add a side case 3" fan to the system to help lower the CPU & motherboard temp.
Good Luck!
Mike
Jul 18, 2008 | ASUS M2N-MX Motherboard
D865PERL Motherboard over heating
I had a problem with my P4 overheating on that same board, I cleaned all the dust out of the heat sink and the coolant fan, then also angled another fan at 45 degree from the back to the CPU sounds like alot, but worked for me.
probly just ganna be a hastle so unless you think a fan would help dont bother
Oct 20, 2007 | Intel D865PERL Motherboard
Nokia 2300
i think u need change new battery if dont work try to clean battery connetion.small metal colour gold.maybe that metal is rusty
Jun 06, 2007 | Nokia Mirafone OP201 Phone
Averatec 3200 Notebook Logo
89 people viewed this question
Top Averatec Computers & Internet Experts
Avishek Samaddar
Avishek Samaddar
Are you an Averatec Computer and Internet Expert? Answer questions, earn points and help others
