Question about Toshiba W607 VHS VCR
Remove the vcr display from the TV screen in a Toshiba w-607 vcr
Hi
How to remove the counter display in TV when watching a tape from a Toshiba w-607 VCR, missing remote.
thanks
  • 61 Answers
Push the display button on your controller until the counter is gone
Posted on Sep 10, 2009
Sylvania (SRD3900) DVD Player / VCR Combo i can't seem to plug in the red/white/yellow cables into the right places directly to my old toshiba tv to play either tapes or dvds. can you instruct me? thanks.
Greetings - It's very simple so I'll show you how and then I think it may be another problem (nothing broken).
You need to plug the corresponding color cables into to outputs on your player I've circled above and then into the corresponding inputs on the TV. You've probably done this correctly.
PLUS - You have to, using the remote for the player, set the source to either DVD or VCR and then you have to, finally, on your TV set the input (with the remote) to what is called probably VIDEO or VIDEO1. If there is still nothing on the screen keep (with the DVD or Tape playing) hitting the TV remote input button until you see an image or you've come around to where you started.
Unless something is broken (unlikely) you should be able to watch DVD's or Tapes depending on what input you select on the player.
If it's not working you've somehow missed a step or the Video input on the TV is called something else. If that happens come back here and give the player AND TV brand/model info and someone will be able resolve your problem.
Good Luck and thanks for using Fix Ya.
Mikeywaf
Apr 21, 2011 | Sylvania (SRDD495) DVD Player/VCR
Toshiba TV/VHS/DVD
press the tv on the remote. if you want to use the vcr. press vcr on the remote.
Apr 04, 2008 | Televison & Video
We cannot get the VCR display to work. For example, if we record a program on the VCR and want to rewind the tape one hour, we do not get the tape counter (or any other display) to tell us how far it has...
I apologise if I have misunderstood the question, but you should be able to turn the LCD display on the front of the player ON and OFF alternately, by pressing the "DISPLAY" button on the remote control (next to "OPEN/CLOSE").
This is only if you are using the original Magnavox remote. If you are using any other universal remote then I can't tell you which button to press unless you can let me know the brand and model number of the remote.
If there is no display at all, try turning it on using the display button on the remote. If you then have a display but the tape counter isn't working, make sure you have the player set to VCR mode. This can be done by pressing the button marked "SOURCE" on either the remote or the front of the player.
It's possible your display has failed or has become disonnected internally, but please try the above and post back if you need further assistance.
Regards,
BElectric
Dec 22, 2010 | Magnavox ZV427MG9 DVD Recorder VCR
Tv/digital converter box & vcr-dvd hook-up
ok cable sat wire goes into input of dvd-vcr input then coming out from the dvd vcr and into the moulator then a wire out to the tv now make sure your vcr is set to the right setting ...now you can record 1 cable..2.vcr dvd..3 modulator...4...tv make sure vcr is set to monitor
Dec 04, 2008 | Philips Magnavox DVD/VCR Dual Player
I have a vhs and dvd player all in one
I have a converter box hooked up to my tv and vcr , dvd player combined
I can play my movies on the tv. ok.
you have to have your tv and vcr set on channel 3. if that is what your main tv is set up with. Or 4 if you have your tv set up with that.
Mine plays ok. My settings are for channel 3
My suggestion would be to check your hook ups. maybe they are not hooked up correctly
I had to go to www.google.com and did searches to help with hook up.
I can also record station I am watching with vcr on vsh tapes. I do not have a dvd recorder.
I found out that you have to have 2 converter boxes hooked to one tv., in order to record on on station while watching another. I have not tried that, as I don't have 2 converter boxes for one tv. I found that by doing google search also. Good Luck
Dec 04, 2008 | Televison & Video
Volume loss after VCR recording
Try adjusting tracking to detent Sounds like audio heads are miss aligned . Does your unit have audio levels if so turn them up when recording. Try adjusting tracking or try patching recording unit to the tv .If it has L/R video inputs use the same deck you recorded on for playback. .
Oct 24, 2017 | Toshiba 24 24 in. TV/VCR/DVD Combo
Dubbing from VCR to VCR
you should just have to plug the first vcr using the RCA jacks,(yellow,red,white). into the second vcr. so the output from the first vcr to the input of the other. then if you want to watch it while its recording though its not necassary you just plug the video/audio out of the second vcr into the tv. So the first vcr you play the tape in and the second you put the blank tape in and press record.
Thats all there is to it.
Let me know how it goes.
Thanks,
Lee
Jul 14, 2008 | Televison & Video
VCR/DVD player DVP3340V/17
Are you using the cable connectors to go into the VCR, and then from the VCR to the TV?
If so, turn the VCR on. Put the TV on channel 3 or 4 (depending on which one you have it set to. If you are unsure, try both channels one at a time) Press the VCR/DVD button so the display on the VCR says VCR (not DVD). Now, you should be able to change the channel with your VCR remote control. If not, you have a problem with your cables. Make sure your cable from the wall goes to RF IN on your VCR. The RF Out on the VCR should go to your TV ANT In or TV RF In.
If you have successfully gotten your TV to display the TV station shown on the front of your VCR, then all you have to do is put in a tape, select the channel you want to record and press the record button.
If you want to watch another channel while you're recording, press the TV/VCR button on the VCR remote, then use your TV remote to change channels.
When you want to stop recording, press the stop button, put the TV back onto channel 3 or 4 (depending on what you have it set to) and press the TV/VCR button on your VCR again. From here you can rewind and view your recording.
Jan 18, 2008 | Toshiba SD-V394 DVD Player/VCR
Toshiba W607 VHS VCR Logo
815 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
