Question about HP LaserJet 4350 Printer
Hp 4350 error code 51.10
What can i do to solve this error code
Posted on Jul 03, 2009
Error 49 ff 95
Posted on Mar 20, 2008
Error code 49 FF 95
The reason could be the spinning mirror in the laser unit is not rotating.
First of, turn off power and pull the plug.
Remove the top cover of the printer, check all connectors going to the laser unit.Its the unit right under the top cover where the paper lands.Take out 4 screws that secure the metal cover on top of the laser unit. You'll see a 6 sided round thing in the back. It should rotate freely if turned. If not, force it to turn and once it turns pull it off while turning. If you look inside this mirror you'll see a ringed magnet. You will need some verrry fine sandpaper to smoothe out any contamination there. Do the same at the corresponding area of the stator that you just pulled the mirror off. It sounds complicated but its not really. If you break anything, no harm done because it was broke already!
Of course you could always buy a new laser unit and plop it in.
Posted on Dec 14, 2007
  • HP Master
  • 1,113 Answers
Not the best numbers to pick, it means that the laser beam is not detected, in short replace Laser unit, all good if under warranty otherwise you will be looking at approx. Aus $300-500
Posted on Dec 10, 2007
SOURCE: hp 4350 error code 50.3
I have just changed the fuser unit and the printer is still giving the
same error [fuser error and low heating] Kindly help.
Maxwell Mpundu@technet.co.zm
Posted on May 28, 2008
jaylex
  • 417 Answers
SOURCE: HP 4350 printer
EIO is the port for the network card on the back of the machine turn off machine remove card from EIO2 and install into EIO1 turn machine on and see what happens. If this does not work then open the formatter casing and remove the memory chips (OF COURSE WHEN THE MACHINE IS OFF) after removingone turn machine on and see if it boots up.
The 49 error is normally a software issue with the machine and it has locked within the network area or the memory.
Hope this helps you and please rate me
Cheers J
Posted on Dec 31, 2007
  • 96 Answers
SOURCE: HP Z6100 error code 01.2:10
01.2:10
Problem
Description:
ISS PCA problem.
Corrective Action: Try the following:
�� Switch the Power OFF from the back of the Printer and disconnect the
Power cord. Reconnect the power cord and power On the Printer.
�� If the System Error continues, replace the Ink Supply Tubes and Trailing Cable.
Posted on Sep 28, 2009
wheatlandsvc
  • 1110 Answers
SOURCE: HP Laser jet 4350 dtn printer gets 59.40 error. I
Print Cartridge Motor Error.
Try removing then re-installing the cartridge. If that does not work then you will need to try a different toner cartridge as the toner cartridge is "locked up". These are the most common solutions. If none of these work then you have a cartridge drive problem and will need to contact a service center.
Posted on Jan 05, 2010
Testimonial: "It worked. Thanks. I' just FIXYA again"
seeker5211
  • 1089 Answers
SOURCE: LaserJet 4350 Printer: HP 4350 printer, 49.2F9D service error...
1st thing to do is upgrade the firmware. Go to hp.com and look for the software and drivers. Drill down to the firmware and read the instructions.
Posted on Jun 13, 2010
HP 4350 with a 41.3 error- Paper size is set correctly and size switch actuator is OK. I tried another tray and also tray 1 (manual feed tray). That tray jams- no lift to feed roller. Any ideas?
I have seen many diferent 41.3 errors. Start by making sure tray is set to standard instead of custom and reset machine to factory settings. Next change out the roller assembly behind the tray 1. It has the selonoid on it. I have seen that cause it before. I would just replace the entire tray 1 to solve the no lift. good luck
Apr 08, 2013 | HP LaserJet 4350 Printer
51.10 error
Thank you for contacting FixYa. I have been working on some archieved inquiries that may have gone unanswered. Your issue is a beam detect error with your laser scanner.
HP LASER PRINTERS 4200, 4300, 4250, 4350 ERROR 51.XX
1. Printer has a beam detect error
2. Replace the cable ***'y from scanner to D.C. controller
3. Replace the scanner ***'y
4. Replace the D.C. controller.
Aug 25, 2011 | HP LaserJet 4350 Printer
For the HP 4350 laserjet DTN what is the error code 50.5 fusion error tell me. Is it an easy fix?
You need to replace the fuser lamp (or ceramic fuser) and the thermistor.
If you can get the replacement parts, it's an easy fix.
Nov 17, 2010 | HP Office Equipment & Supplies
59.40 error code
That's a main motor error, something could be jammed in transport, or a generic toner cart. that is too hard to turn, try powering on with toner removed...
Aug 20, 2009 | HP 4250 Monochrome LaserJet Printer
49.c02 service error message on HP laserjet 4100
General printer error. Unplug the power cord for 10 seconds.
Jan 21, 2009 | HP LaserJet 4350 Printer
Hp 4250 error code 50.3
FALSE FUSER OVERTEMP INDICATION, POWER SUPPLY THAT DRIVES THE FUSING UNIT. MODEL 8150 DOES THE SAME THING. TRY TO GET A REFUND ON THE FUSER?
Apr 15, 2008 | HP LaserJet 4350 Printer
HP 4350 downgraded to a HP 4250
Is this affecting performance? Try new firmware. www.hp.com/go/lj4350_software.
Mar 20, 2008 | HP LaserJet 4350 Printer
Your fuser element is faulty. Check both connectors, make sure they are nice and secure on the element. Still not working replace element.
Feb 12, 2008 | HP LaserJet 4350 Printer
HP LaserJet 4350 Printer Logo
6,056 people viewed this question
Clive
Clive
