Question about Memorex Mega Travel Drive HDD 12GB 12 GB USB 2.0 Hard Drive
It is recognized by device manager and the message is that it is working properly but it appears empty and it won't format and Disk Manager doesn't see it. Properties says there are no bytes on it and that it is a Removable Disk with File system: NTFS. SO how to format or use it? I cannot copy anything to it. Thanks, soma
  • 87 Answers
I would try it in a different computer, maybe like a Mac if you can. The Disk Utility is fairly good.
It may be defective though, I have seen them go bad before.
Posted on Sep 10, 2009
Testimonial: "Great thanks, will try your suggestion. I think it may be defective too as it used to work."
My toshiba external hard drive won't be opened
Some external storage devices work poorly or not at all when connected to a hub; try connecting the drive directly to a port on the computer. Also check if it's detected in "Disk Management". Here you can verify if the partition and format are correct for the Operating System. Check the Drive's status in Device manager. This will verify if the external drive has a drive letter designation. Check Partition and Format. Log in as Administrator account in windows or any other account with administrative privileges Insert your removable disk into the USB port. Click Start, right click on computer and select manage. Now, click Disk Management. Check whether drive letter for the device is present. Check the lower window to find whether the device is detected (such as Disk 1, Disk 2, etc). If the device is detected with a drive letter, verify that no other device is using that drive letter. If it is, change it to unused drive letter. Hope this helps.
Jan 14, 2013 | Toshiba Canvio Plus 320 GB 2.0 Portable...
Doesn't work, cable problem, don't recognize
Get another lead
Jan 09, 2013 | Toshiba Canvio E05A050CAU3XW 500 GB...
Not recognice by usb hard
A USB hard drive is a portable external storage device that works just like a conventional hard drive.
The device is simply plugged into a USB port on your computer as you would connect a flash drive.
Unlike a flash drive, however, a USB hard drive can store a much larger amount of data.
If your computer will not recognize your USB hard drive, you can try troubleshooting steps to resolve the problem.
Plug one end of the USB cable into the port on your hard drive and plug the other end into the USB port of your computer. Ensure that both ends of the cable are connected securely.
Open "My Computer" (Windows XP) or "Computer" (Windows Vista/7).
The USB device should be listed as "removable disk" once it is plugged into the computer.
If it is not listed among the available drives on your computer, proceed to the next step.
Ensure that the data cable is working properly.
Try another USB cable if you have one available.
Disconnect all other USB devices from the computer as they may interfere with the operating system detecting the external hard drive.
Reboot the computer if the USB hard drive is still not recognized.
Plug the USB cable into another USB port and check to see if the device is detected.
If you are using a USB hub, remove the device and plug the external hard drive directly into a USB port.
If the computer still fails to recognize the device, the external hard drive itself may be experiencing a hardware problem.
Check the status of the hard drive in the "Device Manager" window. Under Windows XP, right click "My Computer" and select "Device Manager."
For Windows Vista and Windows 7, click the "Windows" button in the lower left corner of the screen, then type "Computer Management" in the search bar and press "Enter."
Select "Device Manager" in the "Computer Management" window. In the Device Manager window, click the "+" sign that appears beside "Disk Drives."
If the external drive is not listed, click "Other Devices" in the Device Manager window and see if an "Unknown Device" appears.
The external hard drive may have been detected but the device is not working properly.
If it is still under warranty, take the device to the computer store where it was purchased to have it repaired or replaced.
Hope this helps
Nov 07, 2012 | Computers & Internet
I have 16gb sandisk s3 USB device.. Now it turned fro FAT to RAW file system and Shows ts capacity as 0bytes... I dont know what to do... please help me... when i tried to open it shows the question as do...
> Windows cannot format
Physically, it could not write an empty "table-of-contents" onto the device, i.e., there is something SERIOUSLY wrong with the hardware.
Exercise the warranty, to get a free replacement from SanDisk.
Oct 30, 2010 | SanDisk Computers & Internet
My computer is not recognizing my Western Digital passport elite what do I do?
Have to check it in the Device Manager that the new device have been detected or not. It may happen that when the external HDD connects to the computer for the first time computer cannot detect it as it is not properly formatted in proper file-system. Open Computer Management and click on Disk Management and format the device correctly to operate.
Jun 21, 2010 | Western Digital WD Passport 250GB Portable...
Transcend JetFlash V60 16 GB Pen Drive not working properly
Sometimes when a flash memory stick fails because it was not removed from the USB port properly. If the device is removed by just pulling it out of the USB port, it can cause the flash device to fail, you must click on the Safely Remove Hardware icon on the Task Bar and select the device you wish to remove and only do so when instructed to do so.
When the flash memory device appears to malfunction it maybe possible to restore it by reformatting it. Insert the flash drive into the USB port then Click on Control Panel - Administrative Tools - Computer Management - Disk Management.
Then right click on Disk 1 removable drive and click Format. After the flash drive has been formatted it will indicate that its Healthy.
You need to format the external drive. Format the drive as primary drive and in FAT32.
Insert the external hard drive into the USB port then Click on Control Panel - Administrative Tools - Computer Management - Disk Management.
Oct 05, 2009 | Electronics - Others
My Western Digital Elements external hard drive is no longer recognised by either of my computers. When I attach it to computer it says it has found new hardware and installs it and when I look in device...
Check the Disk Manager to see if the disk has a valid partition and is recognized as being formatted. Start -> right-click My Computer -> Manage -> select Disk Management.
If not, then your MBR could be corrupted.
This troubleshooting external hard disk article should help you further.
Jules
Apr 21, 2009 | Western Digital 500GB ELEMENTS 500 GB USB...
Not recognizing DVD player
i would say for some reason your dvd player is not compatible from now on with that brand of blank dvd!
get the firmware update from the brand website all you do is download the file burnit on a cd and put it in the dvd player should fix most and eventual problems
Jan 14, 2008 | Panasonic DMR-EH75VS DVD Recorder/VCR/HDD...
Memorex Mega Travel Drive HDD 12GB 12 GB USB 2.0 Hard Drive Logo
162 people viewed this question
Top Memorex Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Piyal Perera
Piyal Perera
Jax Planet
Jax Planet
Are you a Memorex Computer and Internet Expert? Answer questions, earn points and help others
