Question about Lexmark X4270 All-in-One Multifunction Printer, Copier, Scanner, Fax
How do I get my color ink to print on Lexmark x4270 series
  • 87 Answers
Most drivers default to color. In Windows, go to your printer folder, right click the driver and click on Properties. Check the settings to see if color is selected as default.
If it is color, your application is overriding the driver color settings and would have to be changed in that before printing.
Posted on Sep 10, 2009
5 Suggested Answers
  • 11 Answers
SOURCE: no color printing with lexmark x4270
Actually your printhead on the cartridges is probably clogged. I usually take the cartridges out, wet a paper towel and put in a dish and put in microwave for 20 seconds, then put the cartridge printhead on the paper towel for 10 seconds, and then blot with a dry towel. You should see the various colors in the color and black cartridges. Do it several times until ink in freely flowing. Put back in printer and run a clean cycle and try printing normaly. For additional help: http://support.lexmark.com/cgi-perl/knowledgebase.cgi?ccs=229:1:0:439:0:0&framed=&docid=ENUS18888&relevance=1
Posted on Mar 07, 2007
  • 70 Answers
SOURCE: Color Printing
from the lexmark toolbar check to make sure color is selected not black and white
Posted on Oct 02, 2008
  • 684 Answers
SOURCE: printer not printing
In this case what i would request u to do is....... Take out both the catridges from the Printer......... Take 2 Paper Towels one should be wet with Luke warm water and the other one should be dry........... Take the Colour catridge first turn it upside down and u will see a small copper plate on the catridge from where the ink comes out....... Place the wet paper towel using ur thumb on the Copper plate and press it a lit bit for 10 Seconds...... Now remove it and see whether u see any ink on the paper towel.......... U should see some ink on it now place the dry paper towel on the ink catridge in the same way........ Now do the same procedure again.......... Do the same procedure twice on the Black Catridge................. Now take the dry paper towel and turn the direction of the cartridge so that u can see a Copper plate on it with small boxes just clean that copper plate with the Dry Paper Towel.......... Know insert both the catridges inside the Printer the Colour Catridge should go in the right side and the black on the left........ Unplug the Power Supply from the printer....... Press and hold the Stop/Clear button on the Printer and Plug in the Power Supply while holding the Stop/Clear button it should say clearing on the screen at that point u can go ahead and release the Stop/Clear button.......... Now the Printer will ask for the Date Time and Country Language......... Set everything up...... Now try to Print i am sure it should work.......... Good Luck............
Posted on Jan 19, 2009
Roop1980
  • 228 Answers
SOURCE: Color Cartridge Missing
Please follow the steps given below:
1 Turn the printer/All-In-One off and unplug the power cable from the outlet.
2 Open the printer/All-In-One lid so that the cartridge carrier can be accessed.
3 Remove the print cartridges.
4 Using a dry, clean cloth wipe the carrier contacts gently from top to bottom.
5 Repeat Step 4 for the other cartridge slot (if applicable).
6 Reinsert the cartridges, slide the cartridge carrier to its original position, and close the printer/All-In-One lid.
7 Plug the printer/All-In-One back into the power outlet and turn it back on.
Next, try to perform a Self test:
1 Press the Copy button on the operator panel once (this button is located under Mode).
2 Press the Options button ten times until Maintenance appears on the display.
3 Press the left arrow button (-) once. The display should now read Self Test Page.
4 Press Select. The printer will print a hardware test page.
Posted on Apr 05, 2009
Unable to get my Lexmark 4200 off the default setting of color, want to print in Black/White and select color if I want to print in color .
Good day! Here's an article in the Lexmark website that will show you how to use the Print Properties Dialog on the Lexmark 4200 series. It has some graphics to better understand the instructions. Just click on this link: http://bit.ly/bvMxnp . You should be able to come across Print Color images in Black and White option. Hope this helps. Good luck!
Mar 18, 2010 | Lexmark X4270 All-In-One InkJet Printer
Lexmarkx4270 all-in one
Remove the black ink cartridge and examine the print head on it - you will probably find a small piece of tape (very thin) covering the jets - usually blue in color - remove it and reinstall the cartridge.
Nov 25, 2008 | Lexmark X4270 All-In-One InkJet Printer
Blurry Picture
Check that your print quality is not set to "Draft" in Windows.
Check for ink residue on your color cartridge.
Try replacing the color cartridge
If all else fails...
Update the printer driver using software from the vendor website.
Jul 11, 2008 | Lexmark X4270 All-In-One InkJet Printer
I have a Lexmark X4270 and it just stopped printing color after we changed Copy to Black print Black OK Can not get it to Print in color again Thanks
  1. Click Start onestep.gif Programs onestep.gif Lexmark 4200 Series onestep.gif Lexmark Solution Center.
  2. Click the Troubleshooting tab on the left side of the screen.
See if there is anything in there about it.
Apr 19, 2008 | Office Equipment & Supplies
Color printing
GO TO MAINTANANCE SECTION IN THE MENU TRY TO TAKE SELF TEST PRINT.
IF IT COMES THEN GO TO NEXT STEP AND TRY TO CHECK THE INK LEVEL OF THE CATRIDGES IF THE INK LEVEL IS LOW DO REPLACE WITH THE GENUINE CATRIDGE ITSELF.
Feb 29, 2008 | Lexmark X4270 All-In-One InkJet Printer
Massage unsupport ink on lexmark X4270
Sadly, not all inks are created equal, and even inks that are claimed "compatable" are not allways safe. My HP photo printer worked great for 2 years, then I put in a "will fit" from a name brand office supply store, the printer nozzles plugged on the second print, never to print correctly again. My replacement printer is a Kodak 5300 all in one, chosen for low ink costs/ hi-output, and I get photo-lab quality, borderless prints day after day. (I'm a photographer/artist) I have run 6 color and 5 blacks for thousands of graphics, in a period of 2 months getting ready for a showing, with maybe 1 or 2 misprints.
Nov 20, 2007 | Lexmark X4270 All-In-One InkJet Printer
No color printing with lexmark x4270
How may times did you use the printer to print befor this happened? If you used it a lot then you may need to buy more ink. My printer showed full ink and it turned out that they were empty.
Feb 26, 2007 | Lexmark X4270 All-In-One InkJet Printer
Lexmark X4270 All-in-One Multifunction Printer, Copier, Scanner, Fax Logo
67 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
