Question about IBM ThinkPad T40 2373 Notebook
Battery driver not reinstalling properly
In the process of reformatting my hard drive, I lost the original power management functions; everything was wiped clean, unfortunately. I've tried repeatedly to reinstall the battery and power management functions, but without success. What could my error be in doing this?
  • 1 more comment
  • lucadelcarlo Sep 10, 2009
    Prior to reinstalling the OS, the battery function worked normally. Now, however, there is no battery operation at all, not even at a diminished capacity; unplug the AC, and the unit goes out.
    What is this.
  • andy421 May 11, 2010
    there is no driver needed for your battery. Please try to explain your problem in more detail. I can help you setup your power management if that is all you need. Like when your computer monitor shuts off after a period of inactivity.
  • Steve Green May 11, 2010
    Power management is a function of the BIOS and OS. If you moved from say Windows XP to Vista, it's possible that a new OS may not support the power functions. If it was the same OS, then you will need to locate the correct drivers on the mfr. website. Also look to see if there is a BIOS firmware update. If so, it may address this issue with a fix.
  • 45 Answers
Goto www.thinkpad.com to download the full and any utility for your T40
Posted on Sep 15, 2009
Can you help me fixed this error code SC863-06. it is the Returned, bad sector in Hard drive. I want to know the how to format the HDD.
go to system manager to reformat the hard drive
make sure that you know what you are doing because formatting a hard drive means that everything ( operating system, files folders) --everything is lost for good
better is you find the disc repair section in the manager section and use that and not the format section or return to a previous date before the problem and reinstall to that date
May 07, 2017 | The Computers & Internet
I would like to erase my hard drive and make my laptop new again how can I do that
Most laptops come with a "recovery" disc or feature which allows you to restore the laptop to its original factory condition. This will often include erasing everything on the hard drive (HDD) and reinstalling the original operating system and included software. In most cases anything you've saved to the HDD will be lost unless you make a backup first.
Another option is to use a Windows installation disc. When the disc is inserted (or if you boot from the disc) you will have the option of reinstalling Windows. You will be warned that all data on the HDD will be lost in the process. If you choose to continue Windows will reformat the HDD and perform a clean installation.
Choosing the option to reinstall Windows from a Windows disc may require an active internet connection or you may need to provide drivers in order for certain laptop hardware to perform correctly or be recognized by Windows. It is also important to choose a version of Windows which your laptop is capable of running.
Feb 28, 2015 | Computers & Internet
How can u reformat the acer netbook by copying to other computer
Step 1:
I'm not sure end result you're looking for but I can give you the process on how you can format or reformat your hard drive by. Keep in mind that formatting a drive will erase everything on it so back up everything before starting the process. I believe it will only allow you format or reformat a secondary drive.
Step 2:
Right click on my computer on xp or right click computer in the start button on vista and beyond then select manage
Step 3:
Go to disk management (it is under storage) and right click on the hard drive you want to format and select format
Step 4:
Follow the prompt and the drive will format or reformat. Most likely it will change to NTFS.
Feb 15, 2013 | Acer Aspire One PC Notebook
I need to know how to unintall all the data on my WD hard drive and start over again fresh. Can you help me?
Mac OS X
1 Connect the Western Digital My Passport hard drive to the computer. Power on both.??
2 Open "Disk Utility," located in the Utilities sub-folder of the Applications folder.??
3 Select the drive you wish to reformat. Typically, drives appear twice; choose the furthest left.??
4 Click "Erase," and pull down the Format menu. Choose "FAT32." Enter a hard drive name, if desired.??
5 Click "Erase." A confirmation screen will appear, stating that all information on the drive will be lost if erased. Click "Erase." Once completed, the erased drive will function on both Windows and Macintosh systems.??
Windows
1 Download and install the Western Digital FAT32 Formatting Utility.??
2 Connect the Western Digital My Passport hard drive to the computer. Power on both.??
3 Open the FAT32 Formatting Utility and select the desired external hard drive. Ensure that "Restore factory original FAT32 partition" is selected.??
4 Click "Start." A warning message will appear, stating that all data on the drive will be destroyed. Click "OK" to continue. Click "Yes"' to navigate through.?
May 03, 2011 | Computers & Internet
How do I format the laptop? There is function key that does it?
Restore the pc to its original condition with HP Recovery Manager if computer can boot to the Windows desktop. Launch the Recovery manager
Note:Before doing recovery try to back up the important data like pictures and documents.
1.Click Start and enter Recovery in the search field. Select Recovery Manager from the list when it becomes available. Allow the action to continue, if prompted. The HP Recovery Manager opens.
Alternately, click Start , All Programs , Recovery Manager , and then Recovery Manager . Allow the action to continue, if prompted. The HP Recovery Manager opens.
1.Click Advanced options , System recovery , and then click Next . The PC will restart and reopen the recovery manager.
Alternately, if Advanced options is disabled, click Next , and then System Recovery . The PC will restart.
1.When the PC restarts, select the System recovery option and click Next .
1.If prompted to use the Microsoft System Restore program, click No , and then click Next .
1.When prompted, select the Back up your files first (recommended) option, and then click Next . Follow the on-screen instructions.
1.When prompted to Recover without backing up your files , please STOP before clicking Next .
WARNING: This is the final opportunity to change your mind about recovering the PC and deleting all the files and programs. Once you click Next , the restore process cannot be stopped
1.If you are satisfied that you want to begin the recover process, click Next . The PC immediately begins formatting the hard drive and destroying all data.
The recovery process may take up to several hours and will return the PC to its original condition. Any custom settings, drivers, software programs and updates, and/or hardware updates are lost and must be reinstalled.
If the PC cannot launch into Windows, it may still be possible to use the HP Recovery Manager on the hard drive to restore the computer to its original operating condition. The Recovery Manager can be launched during the start up process by following the steps below.
  1. Press the Power button to start the PC, and then press the f11 key when the standard BIOS prompts are displayed on the black screen. NOTE: Pressing the f11 key during the startup on a computer with an HP factory image will start the system recovery process even if the prompt is not displayed.
    • If the HP Recovery Manager can access the recovery partition on the hard drive, a prompt to backup the user files before beginning the recovery is displayed. Follow any on-screen instructions.
    • If the HP Recovery Manager cannot access the hard drive to fix any system errors, you will need to use the personalized recovery disc that you created to recover the hard drive to its original condition.
    • If you have not created the personalized recovery disc, or the discs are corrupted, you can order a replacement recovery disc from HP.
  2. When the Recovery Manager starts, follow the instructions.
Aug 14, 2010 | HP Pavilion dv2000t Notebook
Hp Pavilion 6701 desktop with ME. Installed Xubuntu OS and removed ME. Want to reinstall ME but recovery disc won't work.
Hard disk needs to be reformatted--start machine and press correct key when "setup" appears in first dialog. Remove hard drive in first screen, then reinstall. Restart computer, should now say: "operating system not found". You need original Microsoft OS disk to reformat drive and reinstall ME. All previous information on hard disk will be lost with this procedure. Recovery disk is used with original OS before Ubuntu. If you don't have original MS disk, suggest going to XP.
Jul 06, 2009 | Computers & Internet
How can I reformat my A20m IBM Thinkpad..
Doing a Format on your PC Should Be A Last Resort! Reformatting your Windows computer is usually the absolute last resort and is often done unnecessarily. Before you go through the process of doing a reformat of your hard drive please take a few moments to read through the rest of our website. If you are reformatting to fix problems with your Windows computer it's possible that by using some of the tips on our site, or by downloading or purchasing some of the tools or products that we link to, you might be able to avoid the need to reformat your computer. Because doing a complete reformat of your computer will erase the contents of the hard drive and require you to reinstall all software, reformatting is usually a last resort. Some Computer Manufacturers Make Reformatting Easy Many name-brand PC manufacturers include a restore-disk which makes it easy to reformat your PC and return it to the state it was in on the day you purchased it. Some manufactures supply only a standard Microsoft Windows CD, and some (usually lower-end PC manufacturers) supply neither! If your PC did not come with a restore or reformatting CD, then you will need to take extra steps to format your hard drive and get Windows re-installed. Back Up Your Files Before You Reformat your Windows PC!Because the reformat or restore process erases everything on your computer, it is critical to have a backup of any important files on your computer. You will also need your original software install disks to reinstall any software you have purchased.
Things to do before you reformat your PC hard drive
  • Write down or print out all notes and internet pages because once the format process begins, you will no longer have access to them (or anything else in the PC)
  • As already stated, BACKUP all important files and data! When you reformat your computer everything will be erased!
  • Make sure you have all the CDs and other software. All programs will have to be reinstalled after you format the hard drive. Don't forget about software that came with hardware such as printers, scanners, etc.
  • Write down the brand and information for all the hardware on your computer. Look in the Device Manager and make note of the brand and model of network adaptors, video cards, sound cards, printers, modems, and displays. After reformatting you might need this information to reinstall drivers.
How To Reformat your Windows XP PC If you're ready to take the plunge and format your computer Click here for step by step instructions to reformat your PC.
Security tips: How to prevent viruses
Guide From:
http://grownupgeek.com/reformat
Apr 13, 2009 | IBM ThinkPad T30 2366 Notebook
Don't know how to reformat my emachine T5010 desktop PC
no just put the cd/dvd in the drive and follow the instruction
Nov 15, 2008 | E-Machines eMachines Desktop PC
I own a acer aspire 5715z and im wondering how i can restore it to its original settings like when i got it? if you could help i really owe u
I believe the ACER aspires have a hidden back-up/ recovery
partition on the hard drive for just this purpose, and that there
is a magic button or key sequence during the boot up process
to activate this sequence.
This should be listed in your user manual, or the official tech
support center (telephone support) should be able to guide you
through this
The process will reformat the hard drive and re-install windows
and the original device drivers.
You will loose all Windows and device driver updates,
all user accounts, internet and desktop settings etc...
You may also loose all your user files, so back up
everything.
Downloaded and installed software licenses will
all be lost as well.
Martin
Apr 24, 2008 | Computers & Internet
I need instructions on how to use purchased external storage unit purchased, no instructions included
  • Write down the brand and information for all the hardware on your computer. Look in the Device Manager and make note of the brand and model of network adaptors, video cards, sound cards, printers, modems, and displays. After reformatting you might need this information to reinstall drivers. You might want to read from this site http://support.microsoft.com/kb/313348
Jan 08, 2008 | SimpleTech SimpleDrive 160 GB External USB...
IBM ThinkPad T40 2373 Notebook Logo
139 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
