Question about Samsung S760 Digital Camera
My lcd screen is faded - it's almost white - I can see the picture / video I will be taking but I find it hard to know if picture is good
  • 797 Answers
If you can get to the menus try to set all to default. This may correct the problem. If it does not, then some problem may be with the LCD.
I have replaced some like this. Usually it is the back light which is not working any more, and you need to replace the LCD. Not too bad of a job, if you can use a small screwdriver and follow simple directions.
On Ebay there are those selling these screens and usually have instructions with ea. one. Also price vary from about $39.00 to about $50.00 or so.
Posted on Sep 10, 2009
Testimonial: "Thanks - I did the default reset function and did not work - therefore the problem is probably with the LCD - I will look into it. Thanks again."
Monitor fades to white.
Check the capacitors on the power supply board. The tops should be flat, no bulging or puffing up at all. The fading to white usually indicates a failure of one or more capacitors on the board. Here is a link to a repair kit if you find blown capacitors on the board.
http://www.ccl-la.com/catalog/product_info.php?products_id=241
Apr 02, 2013 | Samsung Syncmaster 940BW LCD Monitor
RCA l32HD31YX12 white vertical lines
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Mar 02, 2017 | RCA L32HD31 32 in. LCD HDTV
Picture flickering and faded on left had side of the screen
if rebooting the monitor would do no good, try to get a spare monitor cable if the same flickering issue took effect. If it is so, then call your pc provider to repair your monitor..
Nov 26, 2011 | Philips 47 in. LCD HDTV
I have a Sony DSLR A-300 and the lcd screen on the back of the camera goes white when I take pictures. How to fix this?
The camera has live-view, so is the LCD always white? Can you play back old pictures or view menus properly? Do your pictures turn out white or are they ok?
If it's always white and you can't see anything, you need the LCD replaced or the cable going from the main PCB to the LCD replaced. 99% likely the LCD, not the cable.
If you can playback old pictures and view menus... but NEW pictures turn out white then it's not a problem with the LCD screen at all, it's the CMOS or something else.
Without knowing more detail it's hard to say exactly what's wrong, but it definitely sounds like the camera needs repair.
Thomas
Jul 24, 2011 | Sony Alpha DSLR-A300 Digital Camera
Screen fades to white, everything freezes, then returns to normal
My first thought is a video inverter.
Install an external monitor and see if the problem persists.
If it doesn't then it is the LCD on the laptop.
Good luck
God Bless
-Carlos:
Jun 19, 2009 | Compaq Computers & Internet
No images but records sound
To start ensure that you removed the cover from the lens.
Also remove battery and put it back in place to reset the camcorder.
If you get only sound on playback, connect the camera to a computer or TV, or play the tape on a different camera. If you get picture in there, then the camcorder is recording, but the video playback does not work because of a faulty LCD display.
If when you play back the movie on a different camera, or using the compute you still get no picture then the camcorder is faulty.
Faults that can cause black screen can be:
Lens problem. Faulty CCD sensor. Faulty controller board.
All this faults are not easy to diagnose and fix, if there is a fault , then it is better to take the camera to a repair shop.
Jun 17, 2009 | Quasar VM-L153 VHS-C Camcorder
Cannot take photos; picture display is all white and white skewed
Hi
Can you see the menus on the camera or nothing at all? Are the pictures all white if you take a picture and transfer it to your computer?
If you can take good pictures but can't see anything on the LCD then you need the LCD replaced.
If you can see everything on the LCD but can't take good pictures then you most likely need the lens replaced as your CCD or aperture may be bad.
It's very hard to know without mroe information...
If we can help let us know, we are an affordable digital camera repair business.
Good luck from Darntoothysam com
Thomas
Oct 12, 2008 | Cameras
Screen has gone white
Either your LCD is damaged or the cable connecting it to the rest of the camera is loose. I would suggest taking it to be repaired.
Sep 09, 2008 | Canon PowerShot A540 Digital Camera
Panosonic 50" LCD 1080i HDTV screen picture faded
try setting your menu;s to adjust the picture settings
Aug 23, 2008 | Panasonic PT-47WXC43 47" Rear Projection...
Faded screen with lines across screen
hi Jenredd, i think there is something wrong with ccd, if so it is serious... . I experienced some disturbed picture on lcd or whole black lcd due to ccd problem. As u said you pictures are fadded it means may be ccd is damaged. If so you have to replace the ccd at any authorised repairer for fuji. as you mentioned other problem there is nothing common between both. for that i suppose there is some problem in either usb socket or cord , so first check the cord, if it is ok then we can doubt on usb socket. But in both the way you have to go to Fuji . good luck
Aug 01, 2006 | Fuji FinePix A345 Digital Camera
Samsung S760 Digital Camera Logo
218 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
