Question about Sony KP-46V35 TV
KP46V15 Convergence problem
I replaced the STK ics on the D board for this TV and still have a convergence problem. The fuses do not blow. I'm also not able to realign the picture. Any ideas?
You must have checked fusible resistor?
check convergance control panel and check voltage supply to this board.If voltage are o.k than you have to change convergance control ic which is smd ic and its on the control board.
Gopal
Posted on Dec 13, 2007
The picture started getting a triple image (everything was outlined in blue and yellow). We had a board replaced by a tv repair service, over $300 and the tv was ok for about 80 hours. (warranty on new...
Ur tv convergence board that was replaced for ur tv.The 2 STK convergence ICS was old it is not new it is those 2 STK convergence ICS on the tv convegence board is dead again and some of the resistors on the board maybe shorted and dies also must replaced too.The tv convegence board was put on ur tv those parts on the convergence board are old components parts,ur must repair tv convergence board again to fixed this problems called convergence pictures problems.
Aug 22, 2011 | Mitsubishi VS-60609 60" Rear Projection...
Focus Error I am getting double picture and the colors are off. When trying to auto focus the blue lines are wavy.
Replace Convergence ICs ,Big black ICs will have PN# on them example STK 392-110
Mats has ICs 1-800-628-1118
Jun 05, 2011 | Toshiba 42H82 42" Rear Projection...
My Zenith tv picture on the screen looks like a bowtie red green and blue are seperated on screen
The tv have a problems known as a convergence problems,it dead.The tv colors lines R,G,B mis alignments,have colors shadow pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts on the tv convergence board,must be replaced to solved the tv pictures convergence problems.The shop,will cost u like $300-350 for parts and labors.
Nov 24, 2010 | RCA D52W23 52" HDTV CRT TV
Double photo
Replace both of your STK ICs STK392-110s use 150s Mats has Them 1-800-628-1118
Jun 02, 2010 | Sony KP-46WT510 46" Rear Projection HDTV
Had convergence problem; replaced 2 stk392;
100% Ur 2 STK convergence ICS are still dead.Ur ICS soldering some how,u got the ICS shorted.Or ur ICS not right kind of STK ICS,u replacing in ur convergence board.
Apr 07, 2010 | Panasonic PT-56WXF95 56" Rear Projection...
Green projection light not alligning with red and blue. Flash focus will not bring them back. Sony Rear Projection KP-48S70
This sounds like convergence output IC problem. convergence board would have to be removed - remove and replace 2 STK IC's and check the surrounding resistors. Shops usually charge between $200-$400 Be sure to vote/rate me if this helped Thanks!
See link for more detail
http://www.ehow.com/how_4575598_yourself-projection-tv-repair-convergence.html
Note:The convergence/defletion/power board (the one the IC's are on) of this model is on the left hand side (when facing the back of set) also check for blown pico fuses when replacing the convergence IC's The best way to replace the IC's resistors and possibly fuses is to remove the entire board.
Oct 19, 2009 | Sony KP-48S70 48" Rear Projection...
RCA model P61950
fl231 is the convergence fuse, and is soldered to the board in proximity of the convergence ICS, on RCA rear projection TVs.
If
fl231 has blown, TV usually does not turn on at al, if you get bowed picture, that means that the convergence ICs must be replaced.
The fuse is on the same board where you find convergence ICs, if the fuse had blown, or the pico fuses at the base of the STK convergence ics had blown, the STKs must be replaced.
There is need of purchasing the service manual to do the job.
The repair shuld be done by a technician.
This is the convergence IC, model may vary:
Dec 13, 2008 | Televison & Video
Rca d40w20 tv convergence and power on problems
The problem is most likely due to a defective convergence IC.
There are two convergence STK ICs located on the convergence board.
You need first to test the ICS, by checking for continuity the pico fuses at the base of the ICs, then replace the faulty STK.
You should trying doing it yourself only if you are a proven electronic repairer.
Nov 07, 2008 | RCA Scenium D40W20 40" Rear Projection...
Location of convergence IC's in R52WM24
i have the same problem where is the fusible link i replace 2 boards and a connector (t.v. repair man can and diagnoised the problem but did not fix it)
Feb 02, 2008 | RCA R52WM24 52" HDTV Projection Television
Televison & Video Logo
195 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
