Question about Kenmore 94802 Front Load Stacked Washer / Dryer
I have an oil leak on a stacked washer and dryer
They are integral stacked unit and i see oil on the floor under the unit. it cost me like 1000 dolars. what do you thinks wrong wit it and what should i do?
    President:
  • Kenmore Master
  • 2,651 Answers
Oil leakin on floor is a result of a bad transmission seal, yoiuneed to replace teh tranny and clutch assy,(generally covered for extended period of time through the manufacture(check you owners manual for possible coverage
Posted on Apr 08, 2008
1978 GL 1000 left head leaking oil
Hi, Paul external oil deposits fall into 3 categories:
1. WEEPAGE is oil that is sweated pass gaskets, seals, o-rings, and crankcase seams, it's covered by dry dust and is normal for older engines with lots of miles, no repair is necessary.
2. SEEPAGE is the same as weepage except the deposit is wet and confines itself to a specific area, repair is optional depending on the owner's cleanliness criteria, the deposit location and the weight of his bag of "DRACHMA"
3. LEAKAGE is the same as seepage except it is enough to drop to the ground leaving a spot. Repair as necessary.
To find the source of your oil leak, start at the point where you see oil and trace its path going up and forward, blowing baby powder from the palm of your hand will help in those difficult to see areas if there is too much oil present then buy a spray can of engine degreaser apply it to the affected area then rinse off with a pressure wand or garden hose, use compressed air to blow off excess water or just let it drip dry, take your bike for a 15 minute ride and check for the leak.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Oil leaking from exhaust GL1000 Information Questions goldwingdocs com
Oil leaking from GL1000 exhaust manifold
Honda GL 1000 Shop Manual
http://www.partsfish.com/page/oem-parts-for-honda
Honda GL1000 Owner Manual
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Aug 01, 2013 | 1978 Honda GL 1000 (K3)
I just aquired a 1000 fzr exup.theres 2 filler caps on the engine for oil refill.which is which and where and what do i put in,is 1 for gear oil?and the other for engine oil?
Hi, there are 2 caps on the fzr1000 exup the larger of the two which is located on the top of the r/"h engine cover, this is the oil filler plug, and the smaller is infact a dipstick, the level on the dipstick should be read when the dipstick is only resting on the top of the case, and not screwed home, furthermore, the engine and gearbox use the same oil as it is a single unit,
Apr 28, 2011 | 1989 Yamaha FZR 1000
I have a 2000 Chrysler Grand Voyager. The oil light keeps coming on when the engine is at an idle, under 1000 rpms. If I am driving and the RPM's get up above 1000 the light will go off. I checked the oil...
could also be wrong type of oil but worst case is the big end bearings inside the engine have gotten to big to maintain oil pressure and as you guessed the oil pump could be worn out, i would try changing oil pump first.
Jan 25, 2011 | 2000 Plymouth Grand Voyager
Beckett burner; I notice small particles of soot under stack vent
The soot can be caused by a number of reasons, if it was recently cleaned, I would wonder if the service tech just left a little mess behind. If you are reasonablely sure that is not the case, one cause could be a faulty pump. Inside the fuel pump is a pressure regulating valve, that is responisible for pump pressure and cut off. If the valve is failing, and not giving proper cut off, then a small amount of oil will drip into the chamber (called "after drip") and upon start up this oil burns incompletely causing a soot build up. A delay valve often masks the problem by providing the positive shut off electronically. Another problem/cause could be impoper adj. of the burner during the tune-up. On a final note, with equipment that old, it would be a good idea to start looking into a newer, more efficient system.
Apr 10, 2009 | Leviton White Decora Oil Burner Rocker...
Maytag stack unit Model LSE7806ACE leaks
It is most likely the tub seal. Take the two phillips head screws out of the front cover located low on the cover lift forward and remove. Set the machine two low level and fill with water only no soap or clothes when unit starts agitating look at the bottom center of the clothes tub if water is leaking here then you will need to replace the tub seal and tub bearing assembly.
Apr 06, 2009 | Maytag LSE7806A Top Load Stacked...
Dacor oven heating coil broke on one side
no it wont work and it would probablr run between 200 to 300 dolars give or take a little
Mar 17, 2009 | Kitchen Ranges
Creda 1000 Superspeed, stacked: Motor does not run
Sounds like you have motor problem, I suggest u check the brushes in the motor, most likely cause of problem.
Also check that the belt is still on the motor.
Dec 03, 2008 | Creda W100FW Front Load Washer
Help! My basement washer
hmmm..sounds like you may be suffering from back pressure problems. here's what you try first
take about a 5 gallon bucket, and fill it up with water. then let it flow down the drain hole, and then quickly refill the bucket. you are looking for what happens when you have about 25 gallons in 2 minutes going into that hole. If it doesn't go right through, then you might want to have that pipe cored out(in an older home, that's not unusual).
try that first.
Feb 17, 2008 | Washing Machines
Stackable washer
If it wont spin or agitate, and you have a very slimey looking oil that looks like its been flung around the inside of the cabinet and all over the floor, then you have probably had a transmission go out on your unit. The problem is these transmissions are kinda expensive and take a little work to put in. Most dont replace due to cost, but they are available. Good luck!!!
Jan 24, 2008 | Kenmore 98702 Stacked Washer/Dryer
Kenmore 94802 Front Load Stacked Washer / Dryer Logo
114 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
