Question about Health & Beauty
Conver from st-lbs
My scale has been switched from lbs to stones how do i get back please help
  • Stephene Turner
    Stephene Turner Sep 10, 2009
    It is a Tanita an it is digital
  • Stephene Turner
    I thought I replyed earlier,but I may not have. It is digital scale the brand is a tanita
    thankyou
  • 3,230 Answers
Well you can download a manual for the tanita from below link - (hope the manuals can help you) or it's better if you can provide the model number.---
http://www.tanita.com/en/body-water-monitors-fat/
Thanks
Posted on Sep 10, 2009
    Sergeant:
  • 336 Answers
What is the exact brand of scale? a model? digital or mechanical?
Ryan Frame
Creative Energy Associates Technical Center
How to change kgs to lb
There's a small "unit" button on the bottom/back of the scale. Press this until it goes back to lbs. It should cycle between kg, stones, and lbs. If that doesn't seem to be working, press and hold for 4 seconds or more. The screen will flash "reset" and it will have gone back to default, factory settings.
Mar 23, 2014 | Ozeri Scale. Touch Digital Bath Scale in...
ERr
Are you talking 31 "Stone"? If so, I believe that comes out to 434lbs. You are lucky if your scales can read that high. For testing purposes, remove your shoes or more if you think your right at the upper limit. Or let a slightly lighter friend try it. I assume your talking "Stone" as used in the UK. Are you from there? (I,m in the US, in Florida.) Also, there should be a switch on the bottom of the scale (upper left corner) allowing you to switch between lbs, st and kg. You can try that as well, although the limit should be basically identical. If you tell me more, I can help you more.
(By the way, I weigh 197 lbs right now, that's 14 stone.)
May 19, 2013 | Health & Beauty
Cannot configure camry ef522bw scale back to lbs
Check the bottom side of your scale. Mine has a switch to go from lbs to kg and st???. Anyway, check on the bottom ;)
Apr 16, 2013 | Health & Beauty
On my "Ideaworks" wireless electronic display
After playing with the remote on this scale for about 30 minutes, I finally found out how to change this display from kg to pounds or stones. Since this scale doesn't come with an instruction manual, I know a lot of people are totally lost. OK, first click the user button once, so that the weight and goal weight show. Then hold down the clock/set button. After a few seconds the kg on the screen will start blinking. Then use your arrow buttons to switch to stones, then to pounds. The lb will show at the top of the display above where the kg was. You can also set your goal weight by pressing the set button and scanning through after setting the lbs setting. Hope this helps!
Aug 22, 2011 | Jobar International Ideaworks Remote Read...
EKS bathroom scales Model:8901BM DC:3403 I need to know how to change weight units from Kg's to Stones and Pounds.
Turn the scales over so that you're looking at the underside. You will see a 2-way switch that says "Kg" on one side and "St" on the other... Choose either kilograms or stones.
May 08, 2011 | Home
Hi change kg to lbs
There should be a small switch on the back that allows you to select between kg/lb/stone.
Mar 05, 2011 | Health-O-Meter Health o Meter BFM681DQ-63...
I have a Producx digital scale and I can set the person, age, and heights but cannot change to pounds.
There is a small switch on the back of mine that says "lbs/kg/stone", and you slide the switch accordingly.
Jan 11, 2010 | Health & Beauty
The scale only measures in 'stone' weight
I contacted the manufacturer of the porduct here is what they suggested you do
Please insure that there is nothing inside that area that may be hindering the switch to change from mode to mode.
You can also remove the batteries for a period of 24 hours to see if that will trigger a reset in the unit.
If you continue to have problems we may be able to replace under warranty.
Your scale does carry a 10 year warranty but you will need to have a copy of the original itemized receipt (or order confirmation if purchased online) in order for us to process a warranty claim.
If you happen to have a copy of the original receipt or order confirmation, please contact our customer service line between 8:30 – 5:30, Monday – Friday, (Central Time) at 847-640-9241, and we can issue you a Return Merchandise Authorization for product replacement.
Sincerely,
Cheryl Morse
get-attachment.aspx?uid=1.22887842&folder=oldmail&partid=4
TANITA CORPORATION
2625 South Clearbrook Drive
Arlington Heights, Illinois 60005
Office: 847 434 3985
Email: cmorse@tanita.com
Apr 09, 2009 | Tanita BF681 Scale Plus Body Fat Monitor
Somehow my tanita ultimate scale has been switched from pounds to stones. How can I get it back to pounds?
Q: Why does "st-lb" or "kg" appear when taking a measurement?
A: The unit's "Weight Mode" has been set to measure your weight in units of stone-pounds (st-lb) or kilograms (kg). Tanita's Body Fat Monitors and the UltimateScales can measure weight in three different modes: lb (pounds), kg (kilograms) or st-lb (British stone-pounds). To change the setting, first find out which model you have (it should be written just above or below the display screen of the unit).
Method 1
Body Fat Monitor/Scales: TBF-611, TBF-612, TBF-621, TBF-622, BF-541, TBF-560, TBF-572. UltimateScales: 2000, 2001, 2001T. BF-662, BF-555, BF-556, BF-558, BF-559, BF-625, BF-626.
Press the Set and Up Arrow buttons at the same time. Release the buttons, the display will flash. Press the Arrow button to cycle through each weight mode until just the mode that you require is displayed. Then press Set. The display screen will flash to confirm your selection and store in memory.
Note: If weight mode is set to pounds or stone-pounds, the height programming mode will be automatically set to feet and inches. Similarly, if kilograms is selected, height will be automatically set to centimeters.
Method 2
Body Fat Monitor/Scales: BF-542, TBF-551, TBF-521, TBF-531, BF-681, BF-682, BF-679, BF-680, BF-578, all Ironman products, and all InnerScan products.
Select the preferred weight mode by using switch on the back of the measuring platform.
Mar 15, 2009 | Health & Beauty
Health & Beauty Logo
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
