Question about Epson Aculaser C1100 Printer
Epson C1100 K toner low, right hand side can't print
I got an Epson C1100 Laser printer. Y toner low so I have it changed. After installed the Y toner, the K toner shown `Low'. The problem now is I can print but some words on the right hand side went missing. It seems to be the problem of the K toner cos only words in `Black' were missing. What can I do? Do I need to change the K toner straight away? The K toner still have `1 bar' left. Please help!
  • dilysfok Sep 10, 2009
    Thank you for your prompt reply. It shouldn't be the margin, cos only the words in `black' missing, the `colour' words still print.
    Best regards
  • pickmynose May 11, 2010
    Did you check the margins in your printing? I'm not sure what is going on myself, but it seems like from what I'm reading is that maybe the margins need to be fixed before printing.
    Sergeant:
  • 161 Answers
Well if the margins are not the issue, then I would change it.
But before that, try taking a cotton swab, and cleaning the "k toner", the bottom part where the ink comes out. This way before investing more money into your printer, this 'k toner' might just needed a bit of cleaning.
Good luck
Posted on Sep 10, 2009
Testimonial: "Prompt reply and good advice! I have tried to clean the black toner but no luck, will buy a new one tomorrow. Many thanks"
  • 54 Answers
Change the toner cartridge sometimes they dry out from being old and heat from printer.
Printing faint down one side of document
First make sure that the toner cartridge has enough toner. If the toner is OK, it is most likely be due to dust/ toner dust accumulation at the laser reflecting mirrors inside the printer, which partially blocks laser beams and results in faint print. Therefore the printer requires cleaning/ servicing by a professional.
Hope it helps! Good Luck!
CreativeTECH
Apr 12, 2011 | Epson Aculaser C1100 Printer
A white streak appears on the right hand side of the print out
If faded prints happen even after replacing the toner cartridge or if your current cartridge has enough toner, it is most likely be due to dust at the laser reflecting mirrors inside the printer.
I have worked/ serviced similar Laserjet Printer with same issue.
Actually, faded prints are due the the dust/ toner dust accumulated on the optics (mirrors and lenses) inside the printer, which refect the laser beams to form prints. Hence the image is not produced properly. This needs professional hands for servicing and cleaning of the optics inside the printer.
Rest assure that the printer requires ONLY CLEANING OF THE MIRRORS, which are inside the printer. So, it is advised that you get the printer serviced by any printer repair/ service professional. (Please note that the mirrors, lenses and scanner assembly inside such printers is extremely complex and can get damaged very easily especially the mirrors).
Hope it would help. If you need any clarification, let me know
Good Luck!
CreativeTECH
Mar 31, 2011 | Epson Aculaser C1100 Printer
Faded print on right hand side
Hi Tracy,
I have worked/ serviced similar Laserjet Color Printer with same issue.
Good Luck!
CreativeTECH
Mar 07, 2011 | Epson Aculaser C1100 Printer
I keep getting a message on the printer saying install C TnrCart Ive repeated the process twice and installed a new toner but it keeps saying it?
Epson C1100 toner detection is based on freq. your chip on the toner might be old or faulty.
The toner does not have contact point.. at the right side of the printer, there is a receiver, and at the side of the toner, there is a round chip..
Apr 07, 2010 | Epson Aculaser C1100 Printer
Right hand side page print quality very poor, almost unreadable
this is cause of the lens is dirty with toner droping..
open the front cover and on the right side, there is a level for you to pull out.. at the right side of the printer, open the small cover and you will be able to find a cleaner. To clean..pull out the holder few times.. by applying slight pressure..that will clean the bottom lens..and u should be able to print out fine now..
Feb 26, 2010 | Epson Aculaser C1100 Printer
Konica Laser says no toners installed. How do you
Take the tonner catridge and shake it left to right and reinsert then it will be ok
Dec 20, 2009 | Epson Aculaser C1100 Printer
No print on the RHS of page using Epson Aculaser C1100
Two things to check,
1- clean the laser by opening the front cover, pull forward the green lever on the R/H side, take off the little panel on the R/H side of the printer and pull out/push in the lens cleaning "stick". Replace panel and push the lever back in, close the front and try a test print.
If that didn't work:
2- Open the lid, lift the orange lever and remove the photoconductor. Be careful with it as it is easily scratched. Inside the printer rotate the toner cartridges and check that the cartridge lock levers are fully locked as even a couple of millimeters can block the laser.
Hope this helps.
Sep 09, 2009 | Epson Aculaser C1100 Printer
Epson aculaser c900
When printing, as thepaper is being transported up the printer, try pressing the right door panel of the printer firmly with your hand. If the colours are much improved then the printer requires a new Transfer roller.
1. Open the Right Door.
2. Remove the Transfer Roller while opening the shaft holder (white color) levers found at the left and right shaft ends of the Transfer Roller to unlock it. Lift out the roller.
Jan 21, 2009 | Epson Aculaser C1100 Printer
Epson c1100
Yes, they do make this model, I'm using one now. I had the same problem
The solution for me was to clean inside of printer thoroughly, with the C (or whatever) cartridge removed. The sensors get dirty.
Sep 04, 2007 | Epson Aculaser C1100 Printer
Epson Aculaser C1100 Printer Logo
1,232 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
