The drum is not spinning. I hear a noise like when you stick something in your bike spokes.
    President:
  • 1,136 Answers
Hi, Slounds like the coupler has broken. The coupler connects the transmission to the motor. If the coupler is broke, the washer will not agitate in the wash cycle either. Here are insttructiions on how to change the coupler.
Removing the cabinet. UNPLUG the washer. There are two screws holding the control panel to the cabinet. Most models the screws are in front but, some models have the screws in back. They are on each end. Now raise the control panel up and let it rest on the hinges. Unplug the lid switch harness and locate the clips on each side (bronze in color) and release them. Now the cabinet will lift off the frame and you can set it aside.
How to replace a coupler:
Now that the cabinet is out of the way, remove the pump from the motor and set the pump off to the side. Remove the two screws holding the clips on the motor and remove the clips. Unplug the motor harness and on some models you will need to unplug the capacitor.
Now you will need to replace all three parts to the coupler. I use a ½” socket and a small hammer to force the coupler onto the motor and transmission shafts. Put the rubber part onto the coupler half on the transmission and then line up the post on the motor shaft with the holes on the rubber part and it should go on ok. Put the clips that hold the motor in place and plug in the harnesses.
Put the pump back on and the clips to hold it in place. Set the cabinet back on the frame. Make sure the lip on the front cabinet is under the front rail of the frame. Ease the cabinet on the frame making sure the two rear sides of the cabinet set down on the tabs of the frame.
Put the two clips back on that hold the cabinet and plug the lid switch back in. Fasten the control panel down and you are all set.
Please let me know if this helps you at all or if I can assist you further.
Thanks
Vic
Posted on Sep 10, 2009
2 Suggested Answers
  • 1937 Answers
SOURCE: the drum is not spinning. I hear a noise like when
Assuming that this is a Kenmore / Whirlpool top loader with a direct drive system, the first thing to check is the motor coupling.
The transmission and motor have plastic parts that connect through a rubber coupling.
pd_0026_110_285753a?$pddetailsth$ #13 on diagram Coupling, motor and isolation Number:661560Substitution:285753A $18.50 If the coupler rubber piece wears out, the pins on the motor and transmission sides will rub together making the sound.
If the coupler looks good the problem is likely in the transmission.
Posted on Sep 15, 2009
Duet washer making a loud noise on spin cycle, it squeaks on low spin and then when it gets up to high speed, it is really loud. What could this be?
In most cases it is something that is sticking between the drum and the housing. Check inside the boot by the door. If that is not helpful move the drum by hand and listen to see if you can locate the area of the noise.
Dec 30, 2015 | Whirlpool Duet GHW9150P Front Load Washer
Clicking noise
More than likely a bra wire stuck,,,get a torch,stick ur head inside drum & have a look,,,pulled hundreds out over the years
Jun 16, 2013 | Maytag Washing Machines
My jeep makes a sound from the rear for example today backed out of a parking spot and a loud clicking kinda like if u put a baseball card in the spoke of a bike only louder
Check the back brakes . I believe you have drum brakes in the back.The brake hardware. ie..Springs, clips.. come apart sometimes. And this will cause the clicking noise you hear
Nov 26, 2010 | 1998 Jeep Grand Cherokee
My maytag model no.mav4755aww makes a whinning sound at the beginning of the spin cycle
Hi
Drum bearing failure is common when the bearing seals start allowing water to enter. You can take the belt off and spin the drum by hand, and if the drum rumbles, replace the bearings.Since you hear whining it means that the bearing is damaged and the seals on bearing are gone too so it rotates without lubricant. It might be possible to hear whining while you rotate empty drum manually...
Turn the drum by hand and listen for loud noises. If the drum itself is split or the 'spider' is corroded, broken or has come apart from the back of the drum it will create a loud noise on every turn of the drum. When the bearings have gone bad, the noise is constant the entire time the drum is spinning.
Take the belt off and run the motor alone if you hear a high pitched squealing noise to check for motor bearing damage or wear. If you still hear the noise without the belt, it's the motor bearing.Then replacing the bearing is suggested.
Let us know if you want something more else accept the solution.
Thanks for contacting fixya.com
May 22, 2010 | Washing Machines
Kenmore model 80 washer will agitate but drum will not spin
Your basket drive/ clutch or the drive block may be bad . Can you hear the motor running during spin? Can you turn the drum by hand when it is stopped? I would also look for something stuck between the basket and the outer tub a sock or???? Stick a screwdriver in the lid switch slot so you can see what is going on with the lid open and see if basket will spin with a little help. Does it make any unusual noises?
Mar 19, 2010 | Kenmore Washing Machines
I have a lg washer Model# wm0642h and yesterday my wife was washing clothes and during the last spin cycle it started making a loud clicking noise kind of like when you put a baseball card in the spokes of...
Sound like something has gone in between the drum and the outertank, usually a bra wire.. unless you can see it poking through a hole in the drum the only other access points for retrieval are through the sump hose at base , or the removal of heating element.. other than that it becomes a strip down job... but usually the 2 access points are sufficient..
Dec 19, 2009 | LG WM0642H Front Load
How do I true a rimm
Take your tire and tube off remove the rubber gasket that goes around the rim on inside. Your spokes should have a square connector at the ends tighten and loosen individual spokes on opposite sides the way your rim is bent, it takes a lot of time.Then your spokes will be sticking up into the rim grind those down so the don't poke through your gasket. Do this on the the bike frame so you can spin the rim. you can get a spoke tightener at your hardware store.This is a pain in the **** i take mine to a bike shop to have it done!
Sep 22, 2009 | Cycling
Very noisy on spin
hello there.....the noise you hear is most likley due to failed drum bearings or something trapped in the drum....test as follows....isolate machine....open the door...test the drum for up and down lift...there should be no movement at all....if all is well here...remove the lid and remove drive belt....spin the drum by hand and listen for any bearing noise (rumble). or metallic sound of something trapped in drum..if all is well here refit the lid temp...Then select spin and start machine...if motor is noisy then the problem is with the motor bearings
regards Sir Galahad
Sep 21, 2009 | Hotpoint WMA64 Front Load Washer
Sep 10, 2009 | Kenmore 22422 Top Load Washer
Washer makes loud knocking noise
I think that the drum bearings have gone on the machine..
To open the door and spin the empty drum quickly by hand and you should hear the noise or say a less amplifed one.. You can also move the inner drum up and down to see if there is something wrong with it..
Sep 28, 2008 | Roper RAS6233KQ Top Load Washer
Washing Machines Logo
Top Washing Machines Experts
