Question about Adobe Captivate 3 Full Version for PC (38043581)
I am using captivate 3 and we inserted 10 Random Questions coming from a Pool with 37 total questions. Why is it when I run it on our LMS exit and return to the same module, the questions being displayed are the same set of questions from the previous visit. Why not randomizing?
What does a car with a lock light mean
Chevrolet Malibu Questions - SECURITY SYSTEM LIGHT ...
www.cargurus.com > Questions > Chevrolet > Malibu
CarGurusFeb 3, 2014 - SECURITY SYSTEM LIGHT COMES ON - CAR TURNS OVER WON[T START ... Insert the ignition key into the driver door lock. ... When I start my car 3 keys programmed pops up on my dashboard what does that mean.
Chevrolet Malibu Questions - Why does the anti theft system ...
CarGurusFeb 23, 2011 - Why does the anti theft system keep tripping on my 03 malibu - Every other day my anti-theft system goes off in my car then I have to reset it. It's not ha... ...it needs a pass lock sensor/ ignition lock cylinder. 10 out of 10 people think ... Wait 10 minutes until the light stops flashing, then start. Repairs could run ...
No Start Due to Failed Passlock Sensor : Chevrolet Malibu ...
repairpal.com > Problems > Chevrolet > Malibu
Jan 13, 2016 | 2005 Chevrolet Malibu Maxx
Why am igetting no pressure reading on my gauge
Robert,
Assuming the pressure gauge is on a pool filter. These may be dumb or obvious questions but will start with them. Is the pump running? Is there water entering the pump and exiting the filter and returning back into the pool? Is the filter valve in the \'filter\' position? If the answer to all of these questions is yes then likely your gauge is bad. Try tapping it lightly and see if the needle moves. If needle doesn\'t move then gauge is bad. Easy to replace, use teflon tape on the threads.
Gary
Oct 17, 2014 | Pool & Spa
I cannot get the water hardness correct. This is the test results for\r\n8/15/2011-- Total chlorine - 0 --- Free chlorine - 0.5 --- Total akalinity -120 --- PH - 7.8 --- Total hardness - 100 --.The Salt...
Your local pool store will test your water and advise you on what you should do. They will know local conditions and will be able to ask the proper questions on run time, pool size and equiptment.
Aug 15, 2011 | Intex Automatic Salt Water System for ...
How can i get it unlocked for SAMSUNG CAPTIVATE GALXY S SGH-I897
To Unlock the Phone from Network Lock,You can use the unlock code,To get the Unlock code for the PDA samsung Phone You can reach here
Unlocking4u.com and Unlock it from Network Lock...
Samsung SGH-I897 Captivate Unlocking Instructions Warning : Do not enter any wrong unlock codes on your Samsung SGH-I897 Captivate mobile phones. If you enter over a certain amount of wrong unlock codes on your Samsung SGH-I897 Captivate mobile phone, your phone may get hard locked and sometimes become unusable.
Method 1:
1 - Switch ON your Samsung SGH-I897 Captivate with a NOT ACCEPTED SIM Card.
2 - Samsung SGH-I897 Captivate will ask for "Password".
3 - Enter the Unlock Code.
OR (if the Samsung SGH-I897 Captivate shows "Insert Correct SIM Card")
Method 2:
2 - Don't bother about what's being displayed on your Samsung SGH-I897 Captivate.
3 - Compose : #0111*CODE#.
NOT ACCEPTED: We mean, to use a sim card from a network other than the network your Samsung SGH-I897 Captivate is locked to.
CODE: Its the unique Unlock Code for your Samsung SGH-I897 Captivate.
Aug 13, 2011 | Cell Phones
How do I reprogram the phone to ring when a new call comes in, default to a certain line, and show caller id when a call comes in.
The answer to the Caller ID question:
Depend on the type of system that the phone is connected to. Late model Partner ACS equipment will display Caller ID info between the first and second rings, provided that the telephone line is plugged into a module that supports Caller ID.
The answers for the other 2 questions are taken directly out of the Partner ACS Programming Guide which is available for free download at Avaya's website.
Ther answer to the incoming call line ringing question:
Again, depends on the system. For the Partner ACS:
1) Press FEATURE 00 at extension 10 or 11.
2) Enter the number of the extension to be programmed for Line Ringing.
The green lights next to the line or pool buttons show the current Line Ringing settings for all
lines or pools assigned to the extension. (If a line or pool is not assigned to a button, the green
light next to that button is off.) The following ringing options can be shown by the green light
next to the line or pool button:
? Immediate Ring - on steady
? Delayed Ring - flashes slowly
? No Ring - flutters quickly
3) Press the line or pool button until the button light shows the correct setting (the setting for the
currently selected line or pool also appears on the display).
4) Continue programming, or exit programming mode.
Line selection:
For incoming calls, the line selection (hunt sequence) is set by the local service provider). For outgoing calls....again....it depends on the system. For the Partner ACS:
1) Press FEAURE 00, SYSTEM PROG, SYSTEM PROG, CENTRAL PROG at extension 10 or 11.
2) Enter the number of the extension to be programmed for Automatic Line Selection.
3) Press **.
4) Press the line, pool, or INTERCOM buttons in the desired order. The valid entries for Automatic
Line Selection
depend upon the type of extension:
? Key Extension: Outside system lines, Left Intercom (the factory setting)
? Pooled Extension: Pool 880 button 1, button 2, Left Intercom, Right Intercom (the factory
setting), Pools 881-883, individual lines
For each button pressed, a display similar to the following appears:
5) To exit Automatic Line Selection, press **.
6) Press CENTRAL PROG and enter a new extension number, or exit programming mode.
Changing line ringing and line selection are tasks that are normally reserved for the Administrator of the telephone system.
Jan 06, 2011 | Lucent 18D Corded Phone
My intex pool filter is constantly leaking and we are losing a lot of water. The water comes out of the top and leaks out. T
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Jul 15, 2010 | Intex 2500 Gal Easy Set Swimming Pool...
I have questions about Rummikub by Pressman Corporation
1. "Why stacks of seven? Is there significance to this?"
Actually a lot of games use 7 pieces/cards/... to start out, it has probably to do with being an ideal number to make combinations, not too many, not too few.... also if you deal them in stacks of 7, the shuffle will be as random as possible. For this game 1 stack of 7 is too little so we play with 14. Probably you'll find a symbolic reference too in history if you are willing to search for it... (sorry not enough time for that today ;-) but my first guess is that it has a connection to the amount of days and the believe in several cultures that 7 is a lucky number)
2. "After each players turn, does he draw from the pool to replace the number of tiles he used in that turn? Or, does the game end when a player uses all his original 14 tiles and any others he has been forced to draw by the only 2 examples given."
Edit: No, you only take 1 tile out of the pool if you're unable to lay a "meld"... but you don't have to replace the number of played tiles (my original answer according to the way I used to play: You replace the number of tiles used after your turn until there are no more. )
3. "In other words, can the game end with tiles remaining in the pool?"
edited answer: yes. (original answer: No, unless you alter the rules a bit... for example you decide to play for 30minutes max. (or you follow another playing-way!))
4. "The instruction sheet that I have states that it is Original Rummikub Playing Rules ''The Sabra Way''. Is there another way and instructions that I am missing?"
Yes, there are many other ways, the 2 other most common ways are:
"the American way"
Rules of Tile Games Rummikub
and the "International way"
And ofcourse there are plenty of different ways. Just set the rules when you start to play...
Mar 04, 2017 | Pressman Toy Original Rummikub Game
Quiz slides in the presentation
This should help:
https://www.adobe.com/creativecloud/plans.html
Jun 24, 2017 | Adobe Captivate 2 Full Version for PC
We're developing a software and totally stuck...random correct answers
Wrong path on the answer 'button' link, when wrong answer comes up, that link has to refer to the correct answer specific to that question, IE. not random. On auto answer or on "click here" for answer. Change the link path on the JScript file or whatever file it's on.
Or change the script itself, to refer to the specific answer.
I don't know what sort of set up you're using, so it's hard to work out precisely the problem. But it must be the Path address that's wrong.
Feb 23, 2008 | Computers & Internet
Adobe Captivate 3 Full Version for PC (38043581) Logo
50 people viewed this question
Top Adobe Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you an Adobe Computer and Internet Expert? Answer questions, earn points and help others
