Question about GE Refrigerators
Refrigerator works on and off. Refrigerator/Freezer works a few days and then stops working. After 24 hours it works again.
  • 555 Answers
It sounds like a bad start switch - relay- (on the side of the compressor) or compressor itself. When the compressor is pulling too many amps or the compressor is overheating it goes off. if the compressor is not even running then its probably not overheating.
So either the compressor is pulling too many amps (bad compressor) or the start switch is bad and cannot handle the amps required to start the compressor.
There is sometimes a thermal over load that senses heat beside the relay, it can be bad or weak usually the start relay and capacitor and overload are changed as a group to preclude any possibility that they are at fault before the compressor is changed. Capacitors can be tested with a meter, overloads visually inspected and relays either work and draw amps or stick and blow out the start cap.
By the way, If compressor is changed be sure a new drier is installed and new freon and new start components.
Posted on Sep 10, 2009
RS267LBSH The refrigerator stopped working. The technician came and replaced the compressor. It works for 1 1/2 month and failed again. He came the second time and replaced the evaporator. A month
your getting ripped off try the defrost timer sounds like it is getting stuck, it operates on a 24 hour basis cycling between defrost, and turning compressor on and fan to cool the fridge
Sep 02, 2012 | Samsung Refrigerators
Refrig and freezer working on and off for 2 weeks
have you gone here with the model # and cked out what the site says...
https://www.repairclinic.com/?clearLs=true
without a model # is hard to help.
Jan 01, 2018 | Frigidaire PLHS67EGSB Stainless Steel Side...
Refrigerator and freezer not cooling properly even at max settings.
most likely the defrost is not working and it is choked up with ice. Turn off and leave doors open for 24 hours to completely defrost. Then try again, if it works well for a few weeks it will need the defrost looked at.
Apr 17, 2010 | Maytag MSD2756G Side by Side Refrigerator
Up box freezer works fine but low box refrigerator doesn't work
Good day,
2 hours isn't enough time. Doors open, unplugged, minimum of 24 hours, Ideally with a floor fan blowing into the machine.
Jan 15, 2010 | Kenmore 64802 Top Freezer Refrigerator
Kenmore refrigerator cools on and off
can you help me to resolve it. the model #596.52673200 Kenmore made. I replaced the defrost thermostat years ago. It works after that, now it has stopped working. I replaced another defrost thermostat and pull my refrigerator away from the wall, after it works, I push back to the wall where it was, it stopped working.
Finally, I turned the thermostat off for an hours and back on, then it works again with pull it away from the wall. what is it problem?
it will stop again. on and off. can you explain the possibility?
thanks
Luis
Feb 15, 2009 | Kenmore Refrigerators
Freezer/Refrigerator tempurature swinging wildly
The compressor is overheating and not starting. Could be just the start relay. If this happens again try unplugging it for about an hour then it should work for a while. Heat between doors is normal this is an electric heater designed to keep the doors from sweating. You just noticed it because the refrigerator wasn't cold.
Jun 26, 2008 | Freezers
Works Off and On
Do you hear any clicking during the time it is not working? The start relay on the compressor may have a bad connection internally.
Oct 22, 2007 | Kenmore 50522 / 50524 Side by Side...
Freezer works fine...refrigerator section
Have you noticed more frost in the freezer than usual? It sounds like you may have moisture building up and freezing around evaporator fan. The fan blade hitting ice will cause the buzzing until it stops it completely or the evaporator clogs with frost and blocks airflow. If you have frost on food in freezer, check the door seals and make sure nothing is keeping doors from closing completely if you release them about 6" from cabinet.
Oct 07, 2007 | Amana ABB1927DE Bottom Freezer...
Refrigerators Logo
56 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Ilia Bichin
