Question about Dishwashers
MDB9600 buttons function erratically and the display is not working Heavy wash button will not function at all.
  • 68 Answers
DSX-1 interface. Pinouts for each of the RJ-48C jacks are RCV to the DSX-1 from the span on pins 1 and 2, .... DSX-1 Drop. RJ-48 C, terminal blocks. Power Supply Options ... HiGAINMINI SHELF. INPUT: WITH PS 100/120 VAC. 1.0A 50/60 Hz
Posted on Sep 10, 2009
How i can to reset Blomberg dishwasher
first thing to do is unplug for 3 minutes plug back in. Reset?
restore the factor settings:
1.
Enter into the "Settings Menu"
(Press Function and Time Delay
Buttons together for 3 seconds)
2.
When the Main Menu is displayed,
keep the Function Button pressed
until "Restore Factory Settings? is
displayed.
3.
Factory Settings menu do not
have any submenus and it is
enough to press "Confirmation
Button" to reset the settings.
4.
Exit the menu after "** Stored! **"
is displayed
hope this helps.
Jan 07, 2018 | Blomberg Washing Machines
Tip
My Miele washing machine is locked.
Recently I received many requests from users in troubles because they could not unlock their washing machine.
I decided to publish a tip illustrating the unlock procedure.
These instructions apply to most Miele front loading washing machines. They will work on all the W4800 series washers.
Instructions on how to set on and off your Miele’s child lock function are also contained in the user manual.
If you attempt to open the door while the Child Lock function is activated you will get the message "Machine locked" and the picture below on display:
If the door lock is locked during the wash cycle, press the pause button, and the door will open.
In order to deactivate the Child Lock:
  • Press and hold the "Heavy Soil" button until the display shows an unlocked pad lock picture and says Ready to Use (hold up to ten seconds, it should be less).
If you want to re-activate the Child Lock:
  • Press and hold the "Heavy Soil" again, until the display shows a locked pad lock picture and says Ready to Use .
The drum door cannot be opened, and the machine may stay locked if one of conditions below is occurring:
  1. The water temperature is more than 55°C (130°F).
  2. The water level is too high.
  3. The Child Lock function is activated.
  4. There is a fault.
If the washer is in one of the above conditions, you will get the machine locking even if child lock is off.
If the door is locked because of a fault, and there is water in the drum, the machine will also lock up.
In that case the door will open only after accessing the drain pump.
The pump service door is opened using a tool stored behind the dispenser drawer.
The tool must be used only after disconnecting power.
I think I will post a detailed procedure on how to fix a blocked drain pump on the next tip.
I hope this tip has helped you to fix your problem.
Goodbye.
on Dec 10, 2009 | Miele W4840 Front Load Washer
How to unlock the child lock on the AEG L98690FL washing machine. Thanks
5.18 Child lock function
This function prevents children operating the control panel.
• To activate this function, touch button 12 and button 11 at the same
time until the display shows the symbol .
• To deactivate this function, touch button 12 and button 11 at the
same time until the symbol goes off.
You can activate the function:
• Before you touch the button 6 : the appliance cannot start.
• After you touch the button 6 , all the buttons and the programme
knob are deactivated.
untitled-rq2y3fnvghvfrpvxa33jafnd-5-0.jpg Display:
untitled1-rq2y3fnvghvfrpvxa33jafnd-5-6.png Dado
Apr 19, 2017 | AEG Washing Machines
Zanussi dishwasher ZDF601M 1 in 3 red light comes on and programme doesn't work through
26269906-aipk5px1bmfkdpsmrgevaqwn-3-0.jpg "3 in 1" function
This appliance is equipped with the "3 in 1" function, that
allows the use of the "3 in 1" combi detergent tablets.
This function can be selected with all washing programmes.
With the selection of this function the inflow of rinse aid and
salt from each respective supply container is automatically
deactivated and also the indicator lights for salt and rinse aid
are deactivated.
Select the "3 in 1" function before the set of a washing
programme.
Once this option is selected (indicator light illuminated) it will
remain active also for the following washing programmes.
With the use of the "3 in 1" function, the cycle durations may
change. In this case, in the digital display, the indication of the
running time of the programme is automatically updated.
NOTE: Once the programme is running, the "3 in 1" function
can NO longer be changed. If you want to exclude the "3 in 1"
function you have to cancel the programme setting (see
chapter "Starting a washing programme" - "Cancel a washing
programme in progress") and then deactivate the "3 in 1"
function.
In this case you have to set a washing programme (and
options) again.
Activation/deactivation of the "3 in 1" function
(The dishwasher must be switched off)
1. Press the On/Off button. The On/Off indicator light
illuminates (setting mode).If a programme button indicator light is on, this means that a washing programme is set. The programme must be cancelled: press simultaneously function buttons 2 and 3
for about 2 seconds. All the indicator lights will turn off (except for the On/Off indicator light and eventually salt and rinse aid indicator lights) indicating that the set programme has been cancelled and the machine is now in setting mode.
2. Press simultaneously function buttons 2 and 3, until the
indicator lights of function buttons 1, 2, 3 and 4 start
flashing.
3. Press function button 4, the indicator lights of function
buttons 1, 2 and 3 turn off while the indicator light of function
button 4 goes on flashing.
4. Press function button 4 again, the "3 in 1" indicator light
illuminates, indicating that the "3 in 1" function is active.
To deactivate the function press function button 4 again, the
indicator light turns off.
5. To memorise the operation, switch off the dishwasher by
pressing the On/Off button or wait about 60 seconds after
which the dishwasher will automatically return to setting
mode.
Dado
Aug 29, 2016 | Zanussi Dishwashers
My Fagor innovation washing machine is currently disabled by the child lock symbol we did not apply this how can it be reversed
STARTING UP AND
6
BLOCK FUNCTION SELECTION
Start/pause button
a To start up the washing machine you
have to press the start/pause button.
The minutes remaining until the end of
washing and drying will appear on the
display at all times.
Block function selection
The lock function ensures that the programme
will not be affected if any buttons are pressed.
It is used when children could press the
buttons, etc.
The block function should be activated after
the wash programme has been selected
together with all its options.
Activating the block function
a The block function is activated by
pressing the start/pause button and
holding it down for at least 3 seconds.
The display will show if it is activated.
Deactivating the block function
b The block function is cancelled when
the wash programme comes to an end.
If you want to deactivate the block
function before the end of the
programme, you have to hold the start
button down again for at least 3 seconds.
After 3 seconds, the block function
indicator will disappear from the display,
and it will go into pause status.
The ON/OFF button does not cancel
the block function
Apr 14, 2015 | Fagor Washing Machines
Start/cancel buttons no longer work
Dear Sir:
see this possible causes:
Power from the house
see for a blown fuse or c.breaker reset.
Door switch
this is important test it.
Wiring
loose or breake wires
Timer or selector switch
can be defective.
see the w. diagram for HELP. attached.
Now see if the starting relais is closed,because if are OPEN the machine will not work. Test it.
May 05, 2012 | Maytag MDB7609AWS Builtin Dishwasher
Calypso washer will not start.
Now it looks like electronic micro controller problem. This sort of erratic functioning takes place due to corruption in the programme memory.
Contact the manufacturer's service center and obtain the right one and make them fix it. You will be covered by guarantee also!
Apr 05, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Kenmore Elite H3 control buttons - some work some don't
The diagnostic function will not help you if your user interface board (UIB) is acting up because to put into diagnostic you have to select drain spin, then the no spin option, and hit the prewash button 4 times.
It sounds like your UIB is the problem.
Jan 01, 2009 | Kenmore 42822 Front Load Washer
Dishwashers Logo
62 people viewed this question
Top Dishwashers Experts
