Question about Moultrie MFH-DGS-200 Digital Camera
CAMERA WILL NOT FLASH AT NITE
HAVE READ THE MANUAL MSNY TIMES AND CANNOT GET IT TO FLASH AT NITE, JUST GET BLACK PICTURES WITH TIME AND DATE . CAMERA WAS PURCHASED AT CABELOS IN DUNDEE , MICH.IN 2008
  • 68 Answers
DSX-1 interface. Pinouts for each of the RJ-48C jacks are RCV to the DSX-1 from the span on pins 1 and 2, .... DSX-1 Drop. RJ-48 C, terminal blocks. Power Supply Options ... HiGAINMINI SHELF. INPUT: WITH PS 100/120 VAC. 1.0A 50/60 Hz
Posted on Sep 10, 2009
Setting time for pictures
In the manual I can't find any possibility to set date or time. So no dat and or time is stored with this camera. The only option is to put in a date in the album on your computer.
Link to camera manual
Nov 04, 2013 | Fisher Price J8209 Digital Camera
How do I set the date and time spamp on a Canon A490
Hello and Welcome to FixYa!
To set the date and time stamp on pictures, Follow the given instructions:
Setting Date and Time:
First of all set the exact and time if your camera:
  • Press the "Menu" button on the camera and use the right navigation button to choose the "Set Up" menu.
  • Scroll down to "Date/Time" and press the ""Func./Set" button. The set date and time will appear on the screen, and the month unit will flash.
  • Adjust the month unit by pressing the up or down navigation buttons. Move to the day unit by pressing the right navigation button. Use the same instructions to adjust each unit of the date and time.Push the "Func./Set" button to save the time and date settings.
Setting Date Stamp on pictures:
  • Press the "Func./Set" button and select "Recording Pixels" and "Postcard". The camera is now set to "Postcard" mode.
  • Open the "Rec." menu by pressing the "Menu" button on the back of the camera.
  • Highlight "Date Stamp" by pressing the down navigation button.
  • Change the "Date Stamp" setting by pressing the right or left navigation button. Your choices are "Off", "Date" or "Date/Time". Now, when you take photographs the date or the date and time will appear on the picture.
If this solution helps you then your token of appreciation in the form of Rating as Four Thumbs and a testimonial will be esteemed.
Thanks you for using FixYa!
Apr 11, 2011 | Canon PowerShot A490 Digital Camera
My D40 camera will not make night pictures consistently. About 90% of the time pictures taken at night are just black. From what I have read on the forums this must be a very common problem.What is the...
D40s are well known for flash failures...in 3-shot burst mode, due to charge time of flash circuit, 1st pic good; next 2 black. Battery life greatly reduced in this mode.
Feb 26, 2011 | Moultrie GameSpy 4.0 Digital Camera Deluxe
My sandisk is empty but my camera tells me the disk is full. Is the sandisk defective or the camera an issue? My camera is less than a year old and I've taken pictures and uploaded the disk to my MAC many...
you should format your sd-card in your camera. the exact steps you should find in the manual. if this doesn't work your flash-card is probably defective. you need to know, that the number of read and write access to those flash cards is limited (a few thousand times). so it's normal that those cards die after some time.
Jul 27, 2009 | GE A730 Digital Camera
Flash setting doesn't work
Does your camera gave a small battery in place somewhere that is used to maintain the date and time settings? (it is generally a watch battery type small flat silver disk.) You should not have to reset time and date after each battery change.
Many digital cameras eat up batteries quickly, especially when using the flash alot., that is why it is important to use good quality rechargeables whenever possible.
Jun 19, 2009 | Fuji FinePix 3800 Digital Camera
My pics come out half black when I use the X-370 flash
motley45
this happens when the shutter speed is not correct. set the speed to 1/60 sec.
if the X-370 flash is new it may not be compatible with your camera. with the flash turned on it should set the shutter speed automatically to either 1/60sec or 1/125sec. looking in the finder the shutter speed should not change to various amounts of light. if the shutter speed changes with the flash turned on it is not dedicated to your camera.
May 03, 2009 | Minolta X-370S 35mm SLR Camera
No time and date on pitures
Here is the link to Sony's website.. I have directed you straight to the owners manual section, check it out and read the guide and manual.
http://esupport.sony.com/US/perl/model-documents.pl?mdl=DSCT200
Aug 29, 2008 | Sony Cybershot DSC-T200 Digital Camera
Pulsar (Seiko) Watch Changes Date at different time.
mcdevito75 here, The manufacturer recommends you don"t try to change the date between certain hours as this could hurt the date changeing mechanism inside the watch, I don"t think you did any harm (LUCKY) and the date changeing 45 minutes before mid nite is just about right. BUT! if the date change was aliitle closer to mid nite at 1 time you can try to reset the date, here"s how, your stem should have 2 positions to change the date without haveing to cycle the watch the 24 hours 60 times. Slip a finger nail just under the crown and gently, gently lift the crown to it:s first position, it may take a little practise but you"ll get it, once you do, trun the crown and you should see the DATE change, if so set the DATE to 1 DATE before the DATE you want, now pull the stem out and set the correct gate and time of day. Your watch is now reset and date will change on time, around nid nite.
Jun 10, 2008 | Pulsar Bracelet PXQ502 Wrist Watch
Panasonic Lumix DMC TZ3
Use your USB cable or a Card Reader. Read your manual to insert Date on pictures. Note date will show on pic and cannot be removed.
Best idea is to downloand you pics asap and change each pic file name to embed date taken in filename, not on the pic itself.
I recomment the San Disk MobileMate SD+ miniature Card Reader for SD and MicroSD card reading. Just a little larger than a Flash Thumb Drive. Saves lugging around a USB camera cable and saves your camera power otherwise needed to power a download via a USB cable. About $15 at RadioShack, Staples, etc retail stores selling cameras.
Jan 07, 2008 | Panasonic Lumix DMC-TZ3 Digital Camera
How do i reset my camera
After selecting flash off mode the camera determine the shutter speed according to the available light which may be rather slow.Therefore either camera shakes or the object or may be both of them while taking pictures.That's why pictures are blurry. Keep camera steady or mount it on a tripod while taking pictures on flash off mode. Once u set the date & time and select OK I think it will not bother u again.
Aug 22, 2007 | Canon PowerShot SD550 / IXUS 750 Digital...
Moultrie MFH-DGS-200 Digital Camera Logo
175 people viewed this question
Top Moultrie Cameras Experts
Steve
AZBen
AZBen
Are you a Moultrie Camera Expert? Answer questions, earn points and help others
