Question about Canon PowerShot SD750 / IXUS 75 Digital Camera
Need to remove lense on Powershot 870 to clean dust out
I like to ride ATV and use my 870 Powershot for pics and videos on the trail. This weekend was a dusty ride and the lense is hanging up now. Can I remove the lense myself and blow out the dust?
    Sergeant:
  • 161 Answers
I wouldn't advise that you do it yourself unless you did your homework and know how to take it apart. I would buy a air can dust blower and try to get rid of it like that, followed by a lens brush to clear away extra dabre.
If nothing works, take it in for a service by your local camera store or into Canon.
Posted on Sep 10, 2009
1987 polaris trail boss 250 manual
hi, i have a 1987 polaris trail boss 4x4 was riding and gas was leaking from the under side front of gas tank, is there a hose from the carb there? Anyway when i noticed the gas leak we stopped and it slowly ideled down until it died and then would not start.
I have spark pulled carb and cleaned i get gas.
can you help?
Jun 01, 2012 | Polaris ATV
Predator 500cc.i was out trail riding and it started to bog down alittle, shut it off and when i went to start it wouldnt turn over. my lights were flickering
First thing to check would be the battery connections. Make sure the positive and negative cables are tight. I've chased problems on several atvs, especially Predators, to find out the battery cables were loose. They will make the atv cut out or bog down while riding and make lights flicker. Let me know if you need anything else, Daniel.
Oct 10, 2011 | Polaris ATV
Remove dust ccd ixus 75
Do these "stains" only appear on flash pics? Are they always in different places on each pic? If so, these are dust particles reflecting the flash back to the lens.
May 06, 2010 | Canon PowerShot SD750 / IXUS 75 Digital...
87 trail boss has spark and fuel but won't run
test the compression. it needs to be 90 psi or higher
Feb 14, 2010 | Polaris ATV
Change old pics from black & white to color on a canon powershot
You have it on a filter setting that extracts color...go into the menu and scroll to filters and change the setting.
Oct 22, 2009 | Canon PowerShot SD870 IS Digital Camera
Fork
loosen top pinch bolts loosen caps remove forks remove springs , fill according to manual level . re-instal everything .,,,
Nov 10, 2008 | 2003 HM Motard 250
Fork
Nov 10, 2008 | 2007 HM CRM F250X
Fork
Nov 10, 2008 | 2008 HM CRE F250X
How to Fix the lense E18
If you are technically compitent, then its simple. Open the camera and remove the optical assembly. furthur carefully open the lense assembly apart. Remove the motor and the gear assembly so that you can move the barrels manually. carefully check for any friction in the movement. If its moving hard, take every barrel apart, clean them with some hard brush, refit the assembly. Now check the focus motor.normally fine sand or dust get accumulated on the grease at the shaft of the focus motor. clean it check for any damage the the flex ribbion cable of the lense assembly. If you can do all this carefully then reconnect the optic unit to the main board, fit it , switch it on and you will find it working.
Jul 17, 2008 | Canon PowerShot SD500 / IXUS 700 Digital...
Dust or dirt beteen lenses
sir, u try only ur local repairer.and ask clean the CCD
Sep 23, 2007 | Canon PowerShot A80 Digital Camera
Canon PowerShot SD750 / IXUS 75 Digital Camera Logo
260 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
